TUNDRA Tailgate Letter Inserts-Removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by harrydunn, Apr 2, 2018.
  1. Apr 2, 2018 at 2:24 PM
    harrydunn
    harrydunn [OP] New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    My Inferno '16 TRD has chrome TUNDRA letter inserts which are most decidedly uncool. Has anyone had any luck heating this up and removing them? I've removed badges on previous vehicles but they were flush mount which made it easy to get fishing line behind after heating them up. I did some searching but only found posts about installing the letters. If I get them removed, I may go with matte black in their place.
    Thanks,
    Mark
    Columbia, Missouri
  2. Apr 2, 2018 at 5:10 PM
    Use a blow dryer or heat gun. Should be the same like any decal.
  3. Apr 2, 2018 at 5:41 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    The actual letters are kind of soft plastic (unlike the badges). Heat them up a little with a hairdryer and the use a 90 degree pick and stick it into the individual letter and you can pull it out the recessed area. Be careful, don't put the pick in to deep or you might damage your paint.
    NewImprovedRon likes this.
  4. Apr 2, 2018 at 5:46 PM
    17CREWMAX
    17CREWMAX New Member
    orange county, CA
    2017 Crewmax 4X4
    these are harder to remove then the emblems.
  5. Apr 4, 2018 at 6:30 AM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Got them off fairly easily with a heat gun. Put a decent scratch under one of them inadvertently. Not a big deal as I've ordered the matte black letters to put back on.
  6. Apr 5, 2018 at 6:25 PM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    I definitely like the matte black better. Happy with it.
  7. Apr 5, 2018 at 6:34 PM
    Nebz
    Nebz New Member
    Orlando
    2014 Magnetic grey SR5
    Front Mesh Grille upper and Lower, Factory Steps, Flipbak cover, Spray in liner, Ballistic Sythe wheels, weather tech liners with tundra badges
    I just removed mine. Little heat gun and bought a trim removal set from harbour freight which made it much easier.
    harrydunn[OP] likes this.
  8. Apr 5, 2018 at 7:26 PM
    SNO BUS
    SNO BUS Professional Moneywaster
    Nick
    Washington
    White '18 CM 4x4 Limited+
    LEER Canopy, Line-X, Bed mat, Wireless charging
    JNorman84 likes this.
  9. Apr 5, 2018 at 7:29 PM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Sorry. That wasn’t very nice of me. To each his own! :thumbsup:
  10. Apr 5, 2018 at 7:30 PM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    I should have bought a kit like that. I had the heat gun but used a large, sharp knife edge to pick up the lip. Ha.
  11. Apr 5, 2018 at 7:42 PM
    SNO BUS
    Nick
    Washington
    Oh jeez don't worry about it, I know I'm in the chrome-badge minority, I was just being silly :)
  12. Apr 5, 2018 at 7:44 PM
    harrydunn
    Columbia, MO
    Call it, Friendo.
    Ha! ;)
  13. May 28, 2019 at 5:13 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Good thing for this thread becuz I’ve noticed that some tailgate inserts are different and thicker. Like the 3M ones which look great. So i want To removal the ones the matte black ones i have And replace with the thicker 3M ones. So heart gun & trim tools it is?
  14. May 28, 2019 at 9:36 PM
    Greg Marmalard
    Greg Marmalard New Member
    2019 Tundra TRD Off Road Double Cab
    Mine peeled right off!
    Warm day but not hot. Used a spoon to grab a corner and lift and with slight effort and removed!
  15. Jun 3, 2019 at 8:38 AM
    MAN N BLK
    MAN N BLK New Member
    Rickie
    2015 Black Tundra TRD CrewMax
    In time
    Mine also has the chrome from previous owner. I thought about just getting black letters and putting them over the chrome. However the letters on mine are the flat ones. Probably wouldn’t work to well laying them over the bubble letters.
