Tundra stock specs
Discussion in 'Wheels & Tires' started by tacobritt, Oct 17, 2017.
  1. Oct 17, 2017 at 7:28 AM
    tacobritt
    tacobritt [OP] New Member
    Hey guys!
    Anyone with a tundra crew max sr5
    Trying to find rims for my truck but having a hard time getting the specs of my wheel dimensions
    Is it 18x8 or 18x9
    Thank you!!
  2. Oct 17, 2017 at 7:32 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    do you have an upgrade package or a special edition package?
    post a pic of your wheel.
    you can also look on the back side of the wheel. the specs are usually stamped there.
  3. Oct 17, 2017 at 7:43 AM
    tacobritt
    Basic sr5 package
    4x4_Angel likes this.
  4. Oct 17, 2017 at 7:45 AM
    Netmonkey
    Georgetown, TX
    then its probably an 18x8 with a +60mm offset.
  5. Oct 21, 2017 at 9:06 PM
    mscroggi
    mscroggi New Member
    I have a 2017 basic SR5 CrewMax. I need to learn about that offset. But this is the info I was able to pull in-
    Stock: Wheel Size
    SR, SR5 and TRD Pro: 18 x 8 in.
    Standard Wheel Type, SR/SR5:
    Steel Wheel P255/70R18
    Bolt pattern - 5x150 - 5 lug 150mm High Positive Offset
    Wheel Center Bore: 110.5 mm
    Rim width for Michelin LTX M/S2 255/70R18 is 6.5-8.5"
    2017 Toyota Tundra SR5 Crewmax 4.6L
    Stock tire info - https://www.tires-easy.com/255-70-18/michelin-tires/ltx-m-s2/tirecode/08782
  6. Oct 22, 2017 at 4:41 AM
    Netmonkey
    Georgetown, TX
    I seriously doubt that. even if you found documentation that says the offset is +150mm, it is wrong.
    At almost +6" of offset, the wheel would be hitting all sorts of suspension parts and the tire would be hitting (at minimum) the upper control arm.
    For that size wheel on the tundra, the offset should be +50mm.
  7. Oct 22, 2017 at 6:16 AM
    mscroggi
    mscroggi New Member
    Yeah I was curious about that too.. That info came from the 'Official Tundra Wheel and Tire Setups - Pics and Info' thread. I was guessing that in that context it meant something about the lug placement and not the wheel offset. .. I dunno.. But I did search out the wheel offset of the stock wheels and just like you stated earlier, it came in at 60mm.
    Netmonkey[QUOTED] likes this.
