Tundra spacer lift questions
Discussion in 'Suspension' started by Gearhead22, Feb 9, 2020.
  1. Feb 9, 2020 at 3:24 PM
    Gearhead22
    Gearhead22 [OP] New Member
    Corning, Ny
    I’ve had quite a few lifted vehicles over the years. Some with spacer lift, some with actual suspension lifts (coilovers). I’ve never heard of an issue with snapping suspension components with a spacer lift until I stumbled upon someone stating it happens in tundras. I started to look into it and have found a few instances of it happening to people. I was going to throw a spacer lift on the 2020 tundra I’m currently waiting on, hopefully the truck comes in soon, just for looks mainly. I don’t offroad, other than occasionally driving on the dirt roads of upstate NY to go on trips or to friends houses. My question is how common is this issue? I haven’t ever heard of it with other manufacturers and really don’t want this to happen to me. The spacer lift is appealing due to the cost. I don’t want to throw a bunch of money into suspension. I know the benefits of bilsteins 5100/6112’s or high end coil overs but for me it’s not worth sinking that much into it. I just wanted to do a 3/1 or 3/2 kit fit some 295/70/18’s or 295/60/20’s (can’t decide on rim size yet lol) to give it a nice clean look, but this has me worried
  2. Feb 9, 2020 at 3:31 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It only happens if you do not put a spacer on your bump stops. The OEM shocks that are used with the spacers don't have the stroke length to work with the longer assembly. A bump stop spacer keeps it from traveling too far and hit the bottom.
    aussieaarons and 15whtrd like this.
  3. Feb 9, 2020 at 3:49 PM
    Gearhead22
    Corning, Ny
    The bump stop spacer that I see some kits come with is only like 1/4”, is that long enough?
  4. Feb 9, 2020 at 3:58 PM
    Blueknights75
    Ron
    Clayton, NC
  5. Feb 9, 2020 at 4:11 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    It all depends on the lift kit. I had the rough country n2.0 3" lift struts, it came with 1" bump stop spacers, I switched to the boss coilovers and they came with just a washer to space them. Where in NY?
    Boerseun likes this.
  6. Feb 9, 2020 at 4:22 PM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    My brother has been running top spacers on OE TRD coilovers for 100k miles. Tires are 35's. No idea what brand it is, dealer installed.
  7. Feb 9, 2020 at 4:24 PM
    Boerseun
    Ferdie
    Sarasota Florida
    Whatever comes with the kit should be sufficient. It is different depending on the kit, for instance a top spacer and an in-coil spacer will affect the assembly differently. Also, due to the geometry of the suspension, 1/4" at the bump stop location may result in an inch or more at the wheel location. The bump stops are close to the pivot point, compared to the wheel.
  8. Feb 9, 2020 at 5:02 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That kit includes taller spindles that maintain factory geometry. He has no more suspension travel than a stock truck. It just sits taller.
  9. Feb 9, 2020 at 5:07 PM
    Buster1
    Buster1 New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    IMG_20200201_163326.jpg Just my opinion, but unless you're doing some serious off-roading, a spacer lift/level kit is perfectly fine. I debated for a long time about going the Bilstein 5100 route, but after doing a bunch of research and talking to several people, including a trusted friend who is a mechanic, I went with the Tuff Country 2" billet aluminum leveling kit and couldn't be happier. Looks good, price was reasonable, rides the same as factory, the kit included a differential drop, and my TSS still works perfect.
  10. Feb 9, 2020 at 5:08 PM
    InsaneAuto86
    SE PA
    2020 Tundra SR5 TRD
    Ok. I dont know much about it. Thanks!
  11. Feb 9, 2020 at 5:59 PM
    Gearhead22
    Corning, Ny
    Elmira Corning area, I see you’re not too far away!
    Berdine[QUOTED] likes this.
  12. Feb 13, 2020 at 7:52 PM
    I have the Readylift 3/2. Amazon has the best price on it. Perfectly fine for what your goal is. I run 18x9 0 offset wheels with 285/70/18's. The 285 is a 34 and only about a half inch smaller that the 295/70, and 10 pounds per tire lighter. Just another option to consider.
  13. Feb 13, 2020 at 8:24 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
  14. Feb 14, 2020 at 4:49 AM
    Boerseun
    Ferdie
    Sarasota Florida
    This is what I have. Just make sure you order the right kit depending on what you want to do in the rear. They have one that is just the front and one that includes a 1.5" spacer block for the back.
    aussieaarons[QUOTED] likes this.
