Tundra solid driveshaft swap
Discussion in 'Performance and Tuning' started by Cg13055, Sep 18, 2022.
  1. Sep 18, 2022 at 7:06 PM
    Cg13055
    Cg13055 [OP] @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    Hey guys long time no see!
    Long story short, my center support bearing went bad, just replaced it last year. I am in a community surrounded by alot of diesel guys who do custom work on their trucks. They are pushing me towards swapping to a single, less failure points, better efficiency since there is less drivetrain power loss, etc. Has anyone done this yet? Is it economically viable? The toyota replacement is $281 work will probably be $100 with my mechanic. I am being told a steel shaft is $300 aluminum is upwards of that.
  2. Sep 21, 2022 at 8:58 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    If you wheel, then you’ll lose what shitty break over angle you have left as the single shaft will hang down lower than the 2 piece. If that is not a concern to you then go for it.
    You’ll likely need to adjust the angle of your rear diff.
    Cg13055[QUOTED][OP] likes this.
  3. Sep 21, 2022 at 9:41 AM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    One piece driveshafts are not capable of as many RPM. With the 4.30 gears that the Tundras run you may have problems getting a single piece shaft to run well without vibrations etc. Let alone the failure of the driveshaft at too many rpm.
    At the 108 governed top speed on the Tundra with 32" tires the driveshaft is approaching 5,000 rpm.
    Keep in mind that very few of the guys running diesels are running a 4.30 gear.
    Here are a couple of resources:
    Driveshaft critical RPM: https://pstds.com/critical-speed-chart, https://spicerparts.com/calculators/critical-speed-rpm-calculator
    A fairly simple explanation: https://www.streetmusclemag.com/tech-stories/critical-speed/
    Jernik, Cg13055[OP] and Cruzer like this.
  4. Sep 21, 2022 at 9:48 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    That is some interesting shit.
    Jernik likes this.
  5. Sep 21, 2022 at 12:26 PM
    Cg13055
    South Florida
    Sounds like it’s a bad idea considering I am on 35’s
