Tundra Sirius xm antenna
Discussion in 'New Member Introductions' started by gordosc, Jul 30, 2023.
  1. Jul 30, 2023 at 4:55 PM
    gordosc
    gordosc [OP] New Member
    2015 crew max grey trd
    none
    I recently bought a 2015 Tundra Crew Max with the Entune + original equipment radio. It says Serius XM on the face of the radio and there is an XM app on the radio. When I select xm, I get a message check antenna. Well, to me that means that I need to install a Sirius antenna. Took the head unit out and there is a tuner attached to the head and Sirius says that I do not need another tuner. The problem is there is no port to connect the XM antenna. There is a port for the regular antenna which is connected and everything works great except no place to connect the antenna. There must be some adapter that I hope someone knows about.
  2. Jul 30, 2023 at 5:08 PM
    Azblue
    The Dirty T ( ^_^)_且
    Every 2014+ Tundra SR5 and up has both the XM and GPS antennas installed even if you don't have the navigation feature. This is why it's so easy to upgrade to Nav just by swapping out head units. Sounds like your is just unplugged. If I recall correctly, it's a square plug.
  3. Jul 31, 2023 at 4:32 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    ^^^ What he said ^^^
  4. Jul 31, 2023 at 5:04 AM
    Welcome from NY.
  5. Jul 31, 2023 at 8:07 AM
    gordosc
    none
    Thanks for the info,but where is the wire? The only spare plug I have is in a wire bundle with the 12v plugs. Could that be the xm antenna conection?
  6. Aug 8, 2023 at 8:53 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Welcome from State 48, East Basin area, AKA, New Mexico to some locals.
