tundra radio install with IDATAlink
Discussion in 'Audio & Video' started by jimg, Jan 17, 2022.
  1. Jan 17, 2022 at 11:07 AM
    jimg
    jimg [OP] New Member
    2016 Tundra Limited 4x4
    will be installing a JVC KW-Z1000w
    I have the IDatalink and all the parts to do the install
    NON JBL radio installed from the factory
    My question is this. What module flash would I use? DO I use the non JBL flash?
    I will be installing two aftermarket amplifiers. one for Subs, and a 4 channel for an active 2 way.
    I will be installing a tweeter with 6 1/2 speaker in the front doors. We will be using all new speaker wires, rca's ect.
    The only thing going to the JVC will be the power wires, ground wires, and the microphone.
    Going out of the JVC will be the RCA's and a new remote turn on wire to the amplifiers.
  2. Jan 17, 2022 at 11:32 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    It should gave you option. But you want to tick off anything that have factory amp option since you will be running aftermarket amp.
    At the 9:20 mark. He tells you to turn this option off. So you need to do that. So the module know not to look for factory amp.
    https://youtu.be/WC5sHuGOwOs
  3. Jan 17, 2022 at 12:30 PM
    The Maestro setup is really weird. When you look at the instructions for the wiring, whether it is JBL, no -JBL, etc, the wiring is all the same when it comes to replacing the whole system. I don't know about the 2016, but on my 2020, I found out that the dash speakers run directly off of the head unit.
