Tundra polishing pad help
Discussion in 'Detailing' started by Boxerdog, Apr 16, 2023.
  1. Apr 16, 2023 at 8:51 PM
    Boxerdog
    Boxerdog [OP] New Member
    Greetings I am planning on polishing my 2015 tundra before applying geyeon can coat in the next few weeks. This truck is new to me and I haven’t polished it before. The paint doesn’t need a serious correction but I am stuck between these two pads due to the fact I do not have any experience with tundra paint ( it’s soft from my research here). I would rather play it safe when it comes to polishing.
    Using a da polisher with 5inch pads….using 3d one
    Should I use the lake country blue polishing pad?
    https://www.detailedimage.com/Lake-...shing-Pad-P61/55-inch-S2/#product-description
    Or go “safer” with the black pad?
    https://www.detailedimage.com/Lake-Country-M7/Black-Finishing-Pad-P60/65-S1/
    Opinions and advice appreciated
  2. Apr 17, 2023 at 2:15 PM
    briarpatch
    briarpatch New Member
    You'd be fine with either one...neither is particularly aggressive. This is an instance where a test spot will be your best friend. The more aggressive pad would take advantage of the abrasive technology in 3D One more than the other.
    Runway and panicman like this.
  3. Apr 24, 2023 at 6:03 PM
    Boxerdog
    Bp…I want to play it safe especially when I read how soft tundra paint is….thanks for your input
  4. Apr 25, 2023 at 6:38 PM
    briarpatch
    Been giving this some thought....have you considered just using a true polish as opposed to a hybrid like 3D One?
  5. May 2, 2023 at 4:42 PM
    Boxerdog
    I should probably that sonax polish a try….the 3d is kind of a do all and being in Texas it’s already hot so I know a lot of people talk about the ease of it coming off.
    I ended up buying one Lake country orange pad and 5 black finish pads ….will test but I don’t need heavy correction.
