Tundra owner Newbee
Discussion in 'New Member Introductions' started by Naz948, Jun 10, 2024.
  1. Jun 10, 2024 at 11:56 PM
    Naz948
    Naz948 [OP] New Member
    2016 tundra
    Tinted windows all around
    What’s up fellas, got a 2016 tundra that I absolutely love. Had an other gem (97 tacoma).
    New tundra is the
    SR5 w TRD package
    5.7L
    4x4
    All stock.
    just picked up 17” rims with 35 tires (Toyo)
    Trying to figure out the suspension and where to go with it. Thinking 4” lift with good suspension, that’s the question that I’m still tackling.
    From Oceanside California
    RUSTYNUTS likes this.
  2. Jun 11, 2024 at 12:47 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Welcome. Stock truck is a blank canvas, eh? So close to the desert, might as well go long-travel. Post pics
  3. Jun 11, 2024 at 2:31 AM
    Welcome from NY.
  4. Jun 11, 2024 at 3:56 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Jun 11, 2024 at 8:21 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    2 to 2.5 lift will clear 35s and it much easier to deal with, less components and easier install. 4 in lift on tundra usually means a bracket type lift, cutting cross member and any lift approaching 3 inches will need new UCAs.
    Lots of good offerings in the 2-2.5 lift range at good prices. Bilstein, OME, Eibach, dobinsons, toytec all have good products at a reasonable cost to clear larger tires and perform better than the factory suspension. Depending on the offset of your rims, you may need new UCAs and or body mount chop to run 35x1250s without hits/rubbing.
