Tundra Noise
Discussion in '2nd Gen Tundras (2007-2013)' started by bmtrujillo98, Jul 17, 2018.
  1. Jul 17, 2018 at 8:49 PM
    bmtrujillo98
    bmtrujillo98 [OP] New Member
    Hey all,
    I've got a 2013 Tundra Crew Max Limited, about 97,000 miles. I installed a TRD air filter recently, and now I've got a sound that sounds like air being forced through the filter prior to revving the engine in park and when accelerating in drive. Any ideas what this could be? I'll upload a sound file so you guys can hear the noise. Ignore the initial "pop", as that's the sound of me putting my phone down for recording. Thanks!
    -Ben
    https://instaud.io/2rFB
  2. Jul 17, 2018 at 8:58 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Are you getting rough idling or throwing any codes? Does it go away when you put the stock filter back on?
    bmtrujillo98[OP] likes this.
  3. Jul 17, 2018 at 9:03 PM
    bmtrujillo98
    Normal idling, not throwing any codes. Unfortunately, I don't have the stock filter anymore to test for the noise. I took it to a Toyota Dealership and a mechanic that specializes in Toyotas, and they both said that they thought it was just the filter getting worn-in. Not sure how convinced I am as I've owned many Yotas and have never had this happen when replacing or upgrading the air filters on the 5.7. Going to try to take it back in after making an appointment, as I was a walk-in at the dealership that seemed more than eager to dismiss the sound and get on with their other servicing jobs.
  4. Jul 17, 2018 at 9:08 PM
    Sas
    OKC, OK
    It definitely sounds like some sort of intake "cough". I would pop the filter box open, take the filter out and inspect it for tears/holes, then reinstall it making sure it's seated properly and latch the box back up. Fire up the truck again and see if it's still doing it. If it is, open the box again, take the filter out and start the engine w/o it in there and see if the sound is still there. It could be further down the intake if so.
  5. Jul 17, 2018 at 9:16 PM
    bmtrujillo98
    Hey Sas,
    Thanks for the speedy replies. I think I’ll do that tomorrow on my way to work. I’ll keep you updated, hopefully will know more soon. Also hoping that someone else on the forum has run into this. Thanks again.
    -Ben
  6. Jul 17, 2018 at 9:19 PM
    Sas
    OKC, OK
    More than welcome, hopefully it's something simple. I'm sure you know this, but don't go driving around w/your filter off lol. Good luck!
  7. Jul 18, 2018 at 6:17 PM
    bmtrujillo98
    Lo and behold,
    After removing the air filter and running the truck again: the noise persisted. However, it sounded even louder. Hoping to go in for that appointment at my Toyota dealer to get it diagnosed. Not sure what it is, but does sound like a "cough" from the intake of some sort. Let's hope it's simple and cheap. Any other input would be appreciated. Thanks!
    -Ben
  8. Jul 18, 2018 at 6:31 PM
    Sas
    OKC, OK
    Because you're not throwing any codes I'm guessing it may just be a dirty ICV (IAC) and/or throttle body. If it were my vehicle I'd take off each section of intake tube one by one and inspect them for tears/cracks just to be sure you don't have any vacuum leaks past the MAF sensor. Start by disconnecting the air box from the MAF sensor (don't physically touch the MAF sensor itself BTW, the housing is fine to handle tho) and work my way down to the throttle body and ICV. I'd probably clean the MAF sensor with some CRC Electronic cleaner or MAF cleaner (spray in the same direction that the air flows) while I'm at it. I haven't been under the hood of a Tundra in any detail yet, but I'm assuming Toyota's put the ICV and throttle body close to one another. I'm sure someone here can verify where it's located. It could be something as simple as a dirty part that needs a some love from a can of carb or intake cleaner. If you get that far DO NOT TOUCH THE THROTTLE BODY FLAPPER!
  9. Jul 18, 2018 at 6:32 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  10. Jul 18, 2018 at 6:56 PM
    Sas
    OKC, OK
  11. Jul 18, 2018 at 9:43 PM
    bmtrujillo98
    Sas,
    Your help has been incredible thus far. I deeply appreciate it, you've made my first real experience on this forum one to remember. I'll check that out and keep you updated. Might spend the afternoon Friday after work cleaning the IAC and throttle body. Thanks so much!
    -Ben
    Sas likes this.
  12. Jul 18, 2018 at 9:56 PM
    Sas
    OKC, OK
    You bet, happy to help. Hope you get it figured out!
