Tundra newbie from Alabama
Discussion in 'New Member Introductions' started by Machine Gun J, Jun 13, 2019.
  1. Jun 13, 2019 at 9:38 AM
    Machine Gun J
    Machine Gun J [OP] New Member
    AJ
    2013 Blacked out Tundra TSS
    I’ve done zero mods. But I think it came from the factory with something done. That’s part of the reason I’m joining this forum. Want to learn more about my truck.
    Hello everyone. I’m a long time fan of the big bad tundra. Until recently I’ve not been able to afford one. While the wait was long, my patience paid off and I bought a used 2013 Tundra TSS w/ 20” BF Good. A/T’s. I am not at all knowledgeable in vehicles or engines. I was hoping to learn something from some of you guys here on Tundras.com. I’d like to learn a little about my truck and what’s been done to it. I also want to possibly have a new dual exhaust put on the truck as the exhaust was the only thing on my set of “must haves” for a truck when I bought it. I am familiar with the TRD exhaust that Toyota will install from the factory and I really like the sound it makes. But I went to my local Toyota dealer and the price for the parts alone was well more than I’m in a position to want to pay for an exhaust. Does anyone here have any suggestions on some duals for my truck that won’t break the bank? Something that sounds similar to the TRD and would get me some extra performance out of that big 5.7L motor? Any and all suggestions and input would be MUCH appreciated. Thanks for y
    GNTundra, OR18TRD, TuFerLife and 2 others like this.
  2. Jun 13, 2019 at 9:44 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome
  3. Jun 13, 2019 at 9:52 AM
    Welcome from NY.
  4. Jun 13, 2019 at 9:56 AM
    Welcome from
    Black Wolf likes this.
  5. Jun 13, 2019 at 9:56 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
  6. Jun 13, 2019 at 10:04 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  7. Jun 13, 2019 at 10:17 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  8. Jun 13, 2019 at 10:17 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Howdy from DFW and:worthless:
  9. Jun 13, 2019 at 10:54 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
    Pinay likes this.
  10. Jun 13, 2019 at 11:06 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  11. Jun 13, 2019 at 11:51 AM
    Xtaco16
    Xtaco16 New Member
    2018 Tundra TRD sport
    Hello from NJ
  12. Jun 13, 2019 at 11:55 AM
    First.toyota
    First.toyota New Member
    David
    S.W. Washington
    2019 Tundra TRD Pro, Super white
    K&N Cold air intake, wireless charging, JDM Astar led front blinkers
    Hello from Washington state
    jewsNbrews likes this.
  13. Jun 13, 2019 at 12:02 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Welcome from Middle TN.
  14. Jun 13, 2019 at 12:04 PM
    Xtaco16
    Xtaco16 New Member
    Hello from NJ
  15. Jun 13, 2019 at 12:12 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Welcome aboard from here in lil ole Hoover, Alabama.
    Where you be???
    Machine Gun J[OP] likes this.
  16. Jun 13, 2019 at 2:27 PM
    Welcome from Colorado.
  17. Jun 13, 2019 at 2:40 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    Welcome from Tennessee. The more research you do, you’ll find out that unless you have long tube headers, our exhausts run better off a single pipe exhaust. Duals will cause you to lose low end torque.
    @dirtydeeds is a vendor here who makes the best exhausts for ours tundras. Plus you joined at the perfect time! He has a group buy going on until Saturday which has his budget system (which is a direct bolt on) at like $125 off it’s normal price.
    You should check it out!
  18. Jun 13, 2019 at 3:06 PM
    Tundra17Tom
    Tundra17Tom Passin Thru
    South Carolina
    2017 4X4 Tundra SR5 Double Cab 1G3
    HR LED interior HR LED Cargo Light HR LED Backup Light Raised black TUNDRA letters on tailgate Rear and Front bumper painted black Bilstein 5100s front and rear Method NV305 Matte Black Blacked out badges Debadge Iforce and SR5 AVS window vent visors TRD Pro Headlights Auxbeam LED headlight bulbs Driver side Oh Hell Handle
    Howdy from SC
    Trooper2 likes this.
  19. Jun 13, 2019 at 3:12 PM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from Western NC.
  20. Jun 13, 2019 at 3:13 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from Texas!
  21. Jun 13, 2019 at 3:36 PM
    Xtaco16
    Xtaco16 New Member
    Welcome from NJ
  22. Jun 14, 2019 at 9:56 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  23. Jun 14, 2019 at 10:10 AM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from AZ.
  24. Jun 14, 2019 at 11:19 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  25. Jun 14, 2019 at 11:50 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Welcome from Washington
  26. Jun 14, 2019 at 3:07 PM
    Machine Gun J
    AJ
    Hey mvgov. I’m in Hoover as well. Small world. Shoot me a text 205.541.6982
    My name is allen
    Pinay likes this.
  27. Jun 14, 2019 at 3:11 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I’ll shoot you a text later! :)
  28. Jun 14, 2019 at 3:14 PM
    Machine Gun J
    AJ
    Lol. I am super sorry. I obviously don’t know how to use this forum yet. That text me wasn’t for you. But could you tell me how to respond to someone on the forum? Do you use the “quote” button?
    Pinay[QUOTED] likes this.
  29. Jun 14, 2019 at 3:19 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Hahaha, no worries!! Just :boink:
    Use quote for responding to a member’s post but if you want it to be confidential under the user’s name is “Start a Conversation” - use that for private direct chat with one or more members.
    You can go back up and edit your post if you want your number gone :)
  30. Jun 14, 2019 at 3:22 PM
    Machine Gun J
    AJ
    Lol. Yeah. I appreciate your help. I think I MAY have it now. And I’m not worried about the number. Nobody wants to call some dude from Alabama who’s posting on a tundra forum. I’ll be fine. I never answer my phone anyway.
