Tundra Newbie 07 TRD 4X2
Discussion in 'New Member Introductions' started by Ronmat4X2, May 7, 2018.
  1. May 7, 2018 at 6:51 PM
    Ronmat4X2
    Ronmat4X2 [OP] New Member
    2007 4X2 TRD
    Well folks, got my first Tundra hope I didn't make a mistake by buying one with 176,000 miles but it sure runs good. TPMS light stays on, all tires have 50 PSI. Might be too much pressure not sure. Any suggestions?
    Thanks in advance for sure.
    Ronmat in alabama
  2. May 7, 2018 at 6:54 PM
    Professional Hand Model
    Hand Protectors
    Try lowering the pressure in 5psi increments and see what happens. Welcome!
  3. May 7, 2018 at 6:58 PM
    Welcome from CO. Check the TPMS sensors.
    TheBeast likes this.
  4. May 7, 2018 at 7:01 PM
    Ronmat4X2
    2007 4X2 TRD
    Will I have to get Auto zone or someone like that to read the codes?
  5. May 7, 2018 at 7:03 PM
    TheBeast The Beach
    welcome. probably a dead sensor.
    joonbug and 831Tun like this.
  6. May 7, 2018 at 7:21 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME! 176,000miles is nothing for these trucks! :thumbsup:
    Nickhood23 and TheBeast like this.
  7. May 7, 2018 at 7:55 PM
    Welcome from Ohio!
  8. May 7, 2018 at 8:05 PM
    Welcome from Texas
  9. May 7, 2018 at 8:09 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  10. May 7, 2018 at 8:10 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. May 7, 2018 at 8:13 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome,
    Not codes, they can communicate with sensors, if unable, dead sensor or sensor battery. Discount Tires can take a look.
    As mentioned, lower pressure in 5 lb. increments, take a couple mile drive. Turn truck off and back on. If still on at 40 lbs. have someone diagnose.
  12. May 7, 2018 at 8:21 PM
    Ronmat4X2
    2007 4X2 TRD
    Sure appreciate all the help folks!!
  13. May 7, 2018 at 8:34 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  14. May 7, 2018 at 9:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome from Ca.
  15. May 7, 2018 at 10:28 PM
    TheBeast The Beach
    btw tpms sensors go dead all the time.7 or 8 years on the oem tpms battery.
    usually one go dead and the others follow not too long after. If you planning on changing the tires, install 4 new TPMS at the same time. my 0.02
    rons23 likes this.
  16. May 8, 2018 at 2:15 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx, what size tire ya got? If there factory definitely air down some. :cool:
  17. May 8, 2018 at 4:40 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Welcome from Georgia!
    I purchased my '07 last September when it had 270,000 miles on it.
    The PMS light stays on because I removed the stupid sensors... no worries.
    Black Wolf likes this.
  18. May 8, 2018 at 6:12 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  19. May 8, 2018 at 6:18 AM
    Welcome from CO! You may not even have the TPMS sensors. I don't. TPMS light stays on constantly. Don't even notice it anymore. I check my own tire pressure pretty much every week. 07owner here too!!!
    Rex Kramer likes this.
  20. May 8, 2018 at 6:20 AM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Welcome from AZ
  21. May 8, 2018 at 6:23 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  22. May 8, 2018 at 6:58 AM
    Ronmat4X2
    2007 4X2 TRD
    Well I lowered the pressure about 5 and that might have solved it only time will tell.
    My tires are 33X12.50 R 18LT. Is this a pretty common size for this truck without 4WD?
    There brand new so want be getting new ones anytime soon, thanks for all the input and
    im sure i will have more questions.
    Thanks
    ronmat
  23. May 8, 2018 at 6:59 AM
    Ronmat4X2
    2007 4X2 TRD
    Oh i forgot to mention it says max. 80 PSI on the tire
  24. May 8, 2018 at 7:12 AM
    Trooper2
    JR
    80 PSI might be a bit much. The tire mfg. cannot recommend a given pressure for all vehicles. Inside your door there should be a recommended psi, but for stock tire size. Thinking your tires are upsized some, original size in door jam. No big issues, if no rub good, lower mileage and speedo error (unless correct in ECM).
    The info on this link will get you close to an ideal tire pressure. Some do ignore the TPMS light, no effect on performance.
    https://www.tundras.com/posts/577561/
  25. May 8, 2018 at 7:59 AM
    Ronmat4X2
    2007 4X2 TRD
    Man can't tell you how much you folks have helped.
    Thanks
    Ronmat
  26. May 8, 2018 at 8:39 AM
    JAMES
    JAMES COLORADO TUNDRA
    2016 Colorado Tundra Crew Max MGM
    6" PC Stage II Coil Over 37x12.50x20 Toyo RT 20" Fuel Recoil Wheels N-Fab black Step Bars Splash 5% Window Tinting Clear Mask Protection Premium leather interior with 2-front Heat/Cool seats Viper 5806v Alarm w/ remote start Garmin 2589 Garmin Dash Cam Dual Flo-Pro 3.5 18" Glass Packs Black Chrome exhaust tips Bakflip Bed Cover Weather Tech Floor Mats Bushwacker Pocket style with matching paint TRD Pro Grill Tesla 12.1'' Head Unit Oh Shit handle on Drivers Side Under seating Storage 4.88 Gears NSV LED Light bar Upgraded Sound system with JL Audio Speakers and Sub
    Welcome from Colorful Colorado!
  27. May 8, 2018 at 10:12 AM
    TheBeast The Beach
    you can run between 40 and 50 psi safely on A/T tires. what brand are they ?
  28. May 8, 2018 at 10:16 AM
    Rex Kramer
    Georgia
    Rule of thumb: ignore what it says on the tire, go by what is printed on the door sticker.
  29. May 8, 2018 at 11:07 AM
    Ronmat4X2
    2007 4X2 TRD
    I will look at brand tomorrow. On my decal it says P275/65R 18. And it says 30 lb cold.
    But what is actually on it is 33X12.50R 18LT
    and it just says 80 max. Hope these larger tires want be a issue.
  30. May 8, 2018 at 11:14 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
