Tundra nation HELP a first timer ,
Discussion in '2.5 Gen Tundras (2014-2021)' started by TUNMESHIZNIT, Apr 20, 2023.
  1. Apr 20, 2023 at 10:31 AM
    TUNMESHIZNIT
    TUNMESHIZNIT [OP] New Member
    joseph
    2014 SR5 Tundra
    none
    i have replaced fuse link under hood and new fuse block under dash and still have no radio , no AC control, door locks etc... 30 amp acc fuse still pops and i have pulled my hair out searching for my issue,
    can any one relate to this
    thanks
  2. Apr 20, 2023 at 12:37 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    First, Welcome from LA (Lower Alabama)!
    You might want to give a bit more history. If this just started out of the blue, I would suspect rodents chewing through a wiring harness somewhere.
  3. Apr 21, 2023 at 2:29 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Search in here. https://www.tundras.com/forums/electrical.130/
    Specifically this thread for your years' wiring diagram - https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
    Figure out what all is in play and then cut the problem in half and work your way backwards from there. Good luck!! Share your findings when it figure it out.
  4. Apr 21, 2023 at 2:32 PM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Check the ecu fuse in panel above the driver footwell
    I had similar issues when that fuse blew
    I think it’s the first couple of fuses
    AverageJoe likes this.
