Tundra Low idle cold start
Discussion in '1st Gen Tundras (2000-2006)' started by Trythewifi, Sep 6, 2022.
  1. Sep 6, 2022 at 3:18 PM
    Trythewifi
    Trythewifi [OP] New Member
    2002 Toyota Tundra TRD/ 2003 Toyota Tundra SR5 RWD
    Truck idles around 600 rpm at cold start and doesn't idle after unhooking battery, I've cleaned the throttle body and replaced the iac valve. Any suggestions on how to fix this? Ill post a video link when i get home from work of the symptoms
    2uz-fe V8
  2. Sep 6, 2022 at 3:24 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Sounds like an alternator issue. Measure the voltage across the battery to insure its around 14 volts when running.
    Why are you unhooking the battery?
    w666 likes this.
  3. Sep 6, 2022 at 3:28 PM
    Trythewifi
    Ive already checked voltage and was around 14.2, I Replaced the battery, I unhooked the battery after cleaning the throttle body to reset the computer.
    The truck also has 330,000 miles on it
  4. Sep 6, 2022 at 3:30 PM
    Jack McCarthy
    Bill
    North of Boston
    I haven’t tried disconnecting the battery before when running. My guess would be there’s no stable/acceptable load for the alternator to regulate? I dunno.
  5. Sep 6, 2022 at 3:34 PM
    shifty` All my rowdy friends have settled down
    Any time you reset the computer, it has to go through an exhaustive run/test cycle to re-learn how to run. It'll run like shit until you've managed to complete the cycle. This is 100% normal.
    w666 and Jack McCarthy like this.
  6. Sep 6, 2022 at 4:17 PM
    Trythewifi
    It still doesn't idle normally after 2 months of driving it
  7. Sep 6, 2022 at 4:25 PM
    Jack McCarthy
    Bill
    North of Boston
    I’d definitely post a video to get others honest opinions here.
