Tundra Level Fix
Discussion in 'Suspension' started by Kaatahdin, May 4, 2019.
  1. May 4, 2019 at 11:19 AM
    Kaatahdin
    Kaatahdin [OP] New Member
    2016 Tundra TRD
    Hello All, I figured I would post a quick update and note..
    A few months ago I installed OME 612 fronts and Coachbuilder +3 in the rear. The truck looks and drives great; however, it was too level for me. I prefer a little factory rake and that was gone..
    Today I installed a pro-comp 1" block in the rear and it sits great now with a couple of side notes.
    1. I noticed a youtube video about placing a wood block under the leaf pack & jack from there, to get space for the block instead of dropping the axle. This was much quicker, and no re-alignment issues with the spring pearch :)
    2. I had to hammer to e-brake line brackets to get a little more room over the spring pack.
    3. Per Coachbuilder advice, I will install an brake line bracket extension this afternoon.
    4. No driveline vibrations, but I do have the Coachbuilder carrier drop bracket ( .75")
