Tundra kept stalling
Discussion in '2.5 Gen Tundras (2014-2021)' started by nikatnite79, Mar 29, 2023.
  1. Mar 29, 2023 at 6:34 PM
    nikatnite79
    nikatnite79 [OP] New Member
    David
    2016 Tundra Limited
    None
    Hello all! I just bought my 2016 tundra last week and I was super stoked until tonight. I went to a buddy’s house and went to move the truck and it stalled. It kept stalling out it would not start at all and it did this for about 15-20 mins and then suddenly it was fine. Made it home perfectly. Truck has 77k miles. I’m kinda freaking out cuz I traded in my beautiful 2019 Tacoma for this truck to pull my trailer. Any ideas? Thx all.
  2. Mar 29, 2023 at 6:38 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    You pull codes?
  3. Mar 29, 2023 at 6:42 PM
    nikatnite79
    David
    2016 Tundra Limited
    None
    Yeah it didn’t show anything.
  4. Mar 29, 2023 at 6:55 PM
    Blueknights75
    Ron
    Clayton, NC
    Have you checked battery and alternator?
  5. Mar 29, 2023 at 6:56 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    An intermittent problem like yours will probably be very difficult to diagnose from here, especially without codes. If it were mine, I would check the fuel pump first. Good luck.
    ZappBrannigan likes this.
  6. Mar 29, 2023 at 7:36 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Flexfuel?
  7. Mar 29, 2023 at 7:43 PM
    nikatnite79
    David
    2016 Tundra Limited
    None
    No it isn’t a flex fuel.
    Joe333x[QUOTED] likes this.
  8. Mar 29, 2023 at 7:45 PM
    Joe333x
    Joe333x Member
    Boston
    All knowledge I have comes from reading these forums and mostly I've seen your issue with flexfuel that's why I asked. Many people experience wierd issues when their battery is dieing also though.
  9. Mar 29, 2023 at 7:48 PM
    Check the battery. You can go to AutoZone or somewhere similar and they can test the battery for free.
    Terndrerrr likes this.
  10. Mar 29, 2023 at 8:17 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Not sure if it’s the same issue, but my wife’s 2007 Lexus GX470 had a similar problem. At first I thought it might be the battery, but it checked out good at Autozone. Turned out to be the positive battery terminal connection was a bit loose and corroded. I replaced it and tightened it on real tight, and now it starts up fine. Double check your battery terminals just in case.
  11. Mar 29, 2023 at 10:13 PM
    TILLY
    Massachusetts
    Its great advice to check the battery first, since our trucks do some really funky things when they start to go south. That being said, people here with this problem usually get lots of dash lights along with the crazy problems. Any dash lights OP?
    nikatnite79[OP] likes this.
  12. Mar 29, 2023 at 11:08 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    If just bought from dealer, let 'em know. Batt/fuel pump or starter is my guess.
  13. Mar 30, 2023 at 6:06 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Fuel pump?
  14. Mar 30, 2023 at 6:20 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I bet on fuel pump.
  15. Mar 30, 2023 at 7:46 AM
    nikatnite79
    David
    2016 Tundra Limited
    None
    I did see some lights come up but they are the same as to when you turn the key. I didn’t notice anything other than that.
  16. Mar 30, 2023 at 7:55 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    My guess fuel pump or ECU for fuel pump
  17. Mar 30, 2023 at 8:01 AM
    2mchfun
    Have adjustable column? Could be breaking or broken ignition wiring where it flexes frequently.
  18. Mar 30, 2023 at 9:13 AM
    Mission Critical
    Mission Critical New Member
    2014 TRD
    Its a banana in the tailpipe... said with a perfect Eddie Murphy tone..
  19. Mar 30, 2023 at 9:42 AM
    Rocko9999
    Rocko9999 New Member
    Rodent damage?
  20. Mar 30, 2023 at 9:45 AM
    nikatnite79
    David
    2016 Tundra Limited
    None
    So I did some more digging around and found that it is a flex fuel model. Not sure if it’s a good thing or a bad thing.
    2mchfun likes this.
  21. Mar 30, 2023 at 9:46 AM
    nikatnite79
    David
    2016 Tundra Limited
    None
    I did adjust the column Tuesday night.
    2mchfun[QUOTED] likes this.
  22. Mar 30, 2023 at 9:47 AM
    It’s both. It probably explains your problem which is good. It’s likely causing your problem, which is bad. Fuel pump replacement and ECU flash are the fixes, although I’m not sure the flash is permanent fix, or just a reset. The computer incorrectly reads the ethanol percentage in the fuel creating the hard starting issue.
  23. Mar 30, 2023 at 9:47 AM
    nikatnite79
    David
    2016 Tundra Limited
    None
    I don’t see anything abvious but I will look it over again.
  24. Mar 30, 2023 at 10:23 AM
    16CMTXED
    16CMTXED New Member
    Gary
    Central Texas
    2016 Tundra CM
    Eibach Pro Sport Shocks (1.25in), RAS HD, Sumo Springs, HAWK Talon Rotors, OEM Tow Mirrows, Lund Hard Fold Tonneau, ESP Storage, Stampede Flares, Husky xAct Fit liners, General Grabber ATX 275/60R20
    Check if your last 5 digits of the VIN match the "additional information" on this TSB. If it does, then you might be in luck. TSB is good for 96mos or 80K miles. Your 2016 w/77K miles should qualify. Print this and take to a trusted Toyota Dealership. This happened to my Flex Fuel 2016 at around 73K miles. Good Luck OP!
    nikatnite79[OP] and 2mchfun like this.
  25. Mar 30, 2023 at 10:27 AM
    2mchfun
    Please don't forget to post your findings here for the next person to reference! Wish you much luck and TIA for posting!
  26. Mar 30, 2023 at 11:24 AM
    Joe333x
    Joe333x Member
    Boston
    I'm sure you can probably search and find the thread on here but I believe with Techstream you can reset the ethanol reading with is supposed to fix the situation.
  27. Mar 30, 2023 at 11:51 AM
    nikatnite79
    David
    2016 Tundra Limited
    None
    Omg thank you very much. How do I find what vin numbers are effected? I looked over the papers and could find it.
    16CMTXED[QUOTED] likes this.
  28. Mar 30, 2023 at 12:32 PM
    nikatnite79
    David
    2016 Tundra Limited
    None
    Is that like an ecu flash? I had that done on my Tacoma but I wasn’t crazy about it. It made the throttle very touchy. I did gain an mpg or 2 out of it tho.
  29. Mar 30, 2023 at 1:58 PM
    agrestic1
    2016 CrewMax
  30. Mar 30, 2023 at 2:41 PM
    Joe333x
    Joe333x Member
    Boston
    No Techstream is the tool the dealers use but you can buy it on Amazon and it gives you many different OBD options and diagnostics more than a typical reader and one of the options is to reset the alcohol % that the truck thinks its getting which is only present on flex fuel trucks.
