Tundra In Stress!!!!!- need help with wiring
Discussion in '1st Gen Tundras (2000-2006)' started by Kappa82, Jul 5, 2017.
  1. Jul 5, 2017 at 5:53 AM
    Kappa82
    Kappa82 [OP] New Member
    Brenham Texas
    Green 01'Toyoya Tundra
    I took some pics here. That red wire. Where does it connect to. And what is that. The Camshaft sensor is in the back there. Their is a red and green wire that connect there. The only problem is with the red and green wire have a yellow with the black striped ????? Where does it go????? Someone please explain @Nor7 20170705_064929.jpg 20170705_064955.jpg
  2. Jul 5, 2017 at 8:16 AM
    15whtrd
    15whtrd Mr. Blonde
    I remember seeing a picture the other day and I think that yellow wire goes right here. Let me see if I can find that other photo I saw. IMG_3117.PNG.jpg
  3. Jul 5, 2017 at 8:30 AM
    15whtrd
    15whtrd Mr. Blonde
  4. Jul 5, 2017 at 8:31 AM
    15whtrd
    15whtrd Mr. Blonde
    NM just saw you posted in it
    Kappa82[OP] likes this.
  5. Jul 5, 2017 at 8:59 AM
    Kappa82
    Brenham Texas
    Yes. Ok well mine has a red wire coming out. And the harness to cam has a red green amd a yellow/ w blk stripe
  6. Jul 5, 2017 at 9:55 AM
    flynbyu2
    flynbyu2 I'm your huckleberry...
    NorCal
    2015 SR5 CrewMax 2WD
    Flowmaster Super 50 / Dual In - Dual Out Exhaust BakFlipG2 Tonneau Cover TRD Rear Sway Bar
    Cut the red wire first, then cut the green wire. NEVER CUT THE BLUE WIRE.
    Wait, sorry........that's for diffusing a bomb.
  7. Jul 5, 2017 at 10:37 AM
    Kappa82
    Brenham Texas
    Idk it's got me going crazy. I've been without my truck for a week
  8. Jul 5, 2017 at 11:34 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Can I get a few more details? What are we looking at here? Where on the truck is it? What system is this connected to (exhaust? mechanical? Lubrication?)?
  9. Jul 5, 2017 at 11:44 AM
    15whtrd
    15whtrd Mr. Blonde
    He called it camshaft position sensor but im sure its the crankshaft position sensor. Looks like the wires got ripped out of it plus another wire from something in the vicinity. I tried to find a wiring schematic for him but failed. Trying to figure out what wire goes where.
  10. Jul 5, 2017 at 11:45 AM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    if the yellow thing is attached to the block, it might be the knock sensor?
  11. Jul 5, 2017 at 11:48 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I just watched Armagadon again last night. He cut the blue wire on the nuclear bomb.
    CM-LENNY and GNTundra like this.
  12. Jul 5, 2017 at 3:48 PM
    Kappa82
    Brenham Texas
    These wires go to the crankshaft sensor.way up behind the fan. They hook up there,pig tell. But the factory wire are all together. Their is a yellow wire that runs with them but it is not in the same housing. The other wire that concerns me is the one that is in that other sensor thing or whatever it is. I will post more pics
  13. Jul 5, 2017 at 4:14 PM
    Kappa82
    Brenham Texas
    20170705_175123.jpg 20170705_175951.jpg 20170705_180108.jpg 20170705_175818.jpg 20170705_175225.jpg 20170705_175132.jpgthe blue wire has A Green and red wire they plug in the sensor. The yellow??????? The thing down there with that red wire coming out is lonely. Where does it go to. Does this truck have a cam sensor if that the crank where's the CAM sen. You can see the crankshaft sensor. That other tho g with the red wire comin6from connector is about 6 Inchez in front of it behind the fan.
  14. Jul 5, 2017 at 4:24 PM
    Kappa82
    Brenham Texas
    This is other truck. Looks identical. It was posted above. But the one I'm looking at has a red. Or perhaps pops wired that red there bit it's suppo6ti be yellow idkPicsArt_07-05-06.20.04.jpg
  15. Jul 5, 2017 at 6:53 PM
    Nor7
    Which engine do you have? I think we're looking at the Camshaft Position Sensor
    NewImprovedRon likes this.
  16. Jul 5, 2017 at 6:57 PM
    Nor7
    Well still not sure, hard to match up the picture to the diagram. Need some more info OP. Is your picture taken on the front of the block? The pic is so close I can't really see surround landmarks.
  17. Jul 5, 2017 at 7:18 PM
    Kappa82
    Brenham Texas
    V8. 4.7
  18. Jul 5, 2017 at 7:21 PM
    This hasn't been resolved yet???? With all the 1st gen guys here? Surely this is a no brainer fix......
  19. Jul 5, 2017 at 7:21 PM
    Kappa82
    Brenham Texas
    So does it ha e a CAMSHAFT and crankshaft sensors. I know that From the top of the motor they run down in why the wires come to AY1 side goes on top and connect to the compressor and the other half go behind the pulleys and belts and go down into that sensor but there's 3 wires A red a green and they're inside AA to me and a yellow wire with black stripe is going down there with them now the other thing is that that thing that looks like the oil sensor I have no idea where the wire coming out of the all sensor or whatever goes so maybe could possibly be the red wire goes the yellow wire goes into where the red wire is those are the only 2 wires that don't connect
  20. Jul 6, 2017 at 3:15 AM
    Mike Tread lightly.
    south carolina
    @GNTundra... No sh!t with a mess.
    @Nor7. I need a electrical diagram please.
    On the road I don't bring my laptop with me.
