Tundra Hybrid Oil filter question
Discussion in '3rd Gen Tundras (2022+)' started by turbohardtop, Aug 4, 2025 at 10:05 AM.
  1. Aug 4, 2025 at 10:05 AM
    turbohardtop
    turbohardtop [OP] New Member
    For those that are changing your own oil filters, what is the OEM part number you are using? The parts search shows 90915-YZZN3 which is what I ordered from an online Toyota dealer. However, I received 90915-YZZN1 instead. are these parts interchanegable? I assume the N1 was superceded with N3 but I received N1 instead. I also have a case of WIX filter, 57145, which seems longer than YZZN1. Let me know what you are using?
  2. Aug 4, 2025 at 10:08 AM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    They are different filters. The N1 would probably work just fine to be honest, but it is NOT the correct filter
  3. Aug 4, 2025 at 11:00 AM
    turbohardtop
    It looks like the N1 is a bit short. With the way the motors are having issues, I do not want to give Toyota reasons to deny me if anything to happen.
  4. Aug 4, 2025 at 11:11 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    The 90915-YZZN1 fits almost every Toyota including the Tacomo but does not fit the Tundra. Since Toyota parts says it does not fit, I'd take a hard pass on that filter. I bought several filters from my dealer, 90915-10010, and apparently they are made in Japan
    kirkb likes this.
  5. Aug 4, 2025 at 1:14 PM
    NimbusDog
    NimbusDog New Member
    Tampa, FL
    2022 Tundra
  6. Aug 4, 2025 at 1:34 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    90915-10010; made in Japan.
    90915-YZZN3; made in Taiwan.
    Physically and functionally identical.
  7. Aug 4, 2025 at 1:37 PM
    BlackNBlu
    Rich
    MN
    AI results; take with a grain of salt:
    Toyota oil filters: 90915-YZZN1 vs. 90915-YZZN3
    These two filters are different, primarily regarding their thread size and the engines they are designed for.
    Toyota 90915-YZZN1
    • Thread Size: 3/4 inch-16 UNF.
    • Outside Diameter: 3 inches.
    • Item Dimensions (L x W x H): 3 x 3 x 3.5 inches.
    • Item Weight: 6.4 ounces.
    • Designed for: Toyota and Lexus engines.
    • Note: Also known to be a replacement for the factory filter (90915-10009) in 2025 Tacomas.
    Toyota 90915-YZZN3
    • Thread Size: M16 x 1.5.
    • Outside Diameter: 3 Inches.
    • Item Dimensions (L x W x H): 3.25 x 2.6 x 3.24 inches.
    • Item Weight: 7 Ounces.
    • Designed for: Toyota engines, specifically for V35A engines like the Tundra (2022-2024) and Sequoia (2023-2024).
    Key differences summarised
    • Thread size: The 90915-YZZN1 uses a 3/4"-16 UNF thread, while the 90915-YZZN3 employs an M16 x 1.5 metric thread.
    • Engine Application: The 90915-YZZN3 is particularly designed for the V35A engine, found in models like the Tundra and Sequoia. The 90915-YZZN1 is compatible with a broader range of Toyota and Lexus engines.
  8. Aug 4, 2025 at 1:48 PM
    turbohardtop
    Thanks everyone. I returned the N1 filters for the correct N3.
    BlackNBlu likes this.
  9. Aug 4, 2025 at 5:20 PM
    JohnF4x4
    JohnF4x4 New Member
    US
    2025 Platinum Windchill Pearl with AVS
    Just go to your local Toyota, they are $5.50 a pop. Cant get any better than this.
