Tundra Horn Upgrade
Discussion in 'General Tundra Discussion' started by BlueBottle, Dec 31, 2016.
  1. Dec 31, 2016 at 9:40 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I feel the stock horn is crap compared to other vehicles I have had. Anyone else agree?
    Had to use it the other day due to someone going into my lane and they didn't even budge.
    So now I am looking into a replacement horn kit. I do NOT want train horns or air horns, I want something that I can re-use the original wiring without a relay kit.
    I have used PIAA Sport horns in the past, anyone else have an experience or recommendations?
    https://www.amazon.com/85110-115db-...rd_wg=0beX8&psc=1&refRID=HD4C1BWB2PN0XCHHTFN0
  2. Dec 31, 2016 at 5:10 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Have you removed the tin covers that snap over the horns? They get a bit louder with them off.
    Sleeper16plat likes this.
  3. Dec 31, 2016 at 5:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I have no idea what our horns sound like. I'm not much of a honker... more a fingerer.
    Alex987br, Toe404, Ducarius and 12 others like this.
  4. Dec 31, 2016 at 5:22 PM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
  5. Dec 31, 2016 at 5:31 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Sub'd
    I would also like to upgrade. Something really easy (like plug & play) and really loud.
    The youtube video comparison on the toyota fj of the horn linked above might not do it justice because other than sounding different, it really doesn't sound all that louder.
  6. Dec 31, 2016 at 5:51 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I didn't know about that. I may look into it but is it even worth it? Removing the grill is a pita and I may just replace it if I remove the grill.
    It should be louder according to the specs.
    If you want louder you can do air horns but you would have to run a relay for that. The Piaa horns can use factory wiring which is why I was looking in them.
  7. Dec 31, 2016 at 5:53 PM
    The horn is an emergency button, not an emotional button. Just an FYI :)
    Tundyfundy, BMET, jfrd30 and 3 others like this.
  8. Dec 31, 2016 at 5:53 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    There are several replacement horns that are extremely loud compared to the stock horns. These horns by hella are 118 decibels! Each 10 decibels means that it's twice as loud. IMG_5458.jpg
  9. Dec 31, 2016 at 5:57 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I've seen those but those have that higher pitch European tone. I was looking at something lower pitch.
    Check this out.
    PIAA 85115 Superior Bass Horn https://www.amazon.com/dp/B0060ZB43G/ref=cm_sw_r_cp_api_4fgAybFZA3GDW
  10. Dec 31, 2016 at 6:02 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I installed these about a year ago. Much deeper sounding and somewhat louder than stock. I'd like them louder but they do get my point across when I use them :) . Overall happy with them.
  11. Dec 31, 2016 at 6:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Right, 3rd gen. 2nd gen the grill stays with the hood, so horns are in your face with the hood open.
    I haven't removed the shields from my Tundra horns yet, difference was notable on the Tacoma, but not shockingly louder.
    I had three hella horns from '80's VW's - low, mid, and high tone, all stuck together on a bar with a relay. Had a triple tone train horn sound, but deeper. I built it for my '83 hilux back in the day, then they spent a couple years on my wife's corolla, until they were broken last year when she had a bit of a tangle with a curb.
    They did not get ignored, unlike the weak sauce excuse of a horn the stock one is.
  12. Dec 31, 2016 at 6:20 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Let's hear it... I tried taking off the metal plates off of the stock horn, but it became shrill
  13. Jun 21, 2017 at 3:31 PM
    tschiaffo
    tschiaffo New Member
    Travis
    Red 2012 Toyota Tundra SR5 Double Cab
    N/A
    Following this thread, looks like good stuff. My horn won't work! I've checked the fuse and it's intact. My engine bay is clean-no melted or chewed wiring. What else can I do short of taking it to the shop?
    MotoTundra likes this.
  14. Jun 21, 2017 at 3:41 PM
    dandailey
    Dan D
    Newport News Va.
  15. Jun 21, 2017 at 5:15 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    How do you like them?
  16. Jun 21, 2017 at 5:18 PM
    dandailey
    Dan D
    Newport News Va.
    BlueBottle[OP] likes this.
  17. Jun 21, 2017 at 5:20 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ah didn't realize your post above !
    Thanks!
  18. Jun 21, 2017 at 5:26 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    I'm not a tech but if you have the skills, maybe disconnect the horns and use a multimeter to see if the proper voltage is going to the horn. If so, it may be the horns. If not, then the problem is elsewhere and may be tough to diagnose. You would have to trace it back. I know it is common in Jeeps for the clockspring to go bad and the horn, blinkers, and steering wheel controls all have issues.
    tschiaffo[QUOTED] likes this.
  19. Feb 2, 2021 at 5:47 PM
    TundraLLama
    TundraLLama New Member
    Massachusetts
    2015 Black Platinum Tundra
    Color matched mirror caps and door handles TRD dual exhaust TRD shift knob TRD Pro FOX shocks Spray in LINEX bed liner TRD 18” wheels FOX TRD Pro suspension Michelin 275/65r18 LTX AT2 Soft top Roll up bed cover Go Rhino RB10 running boards TRD Pro LED blackout headlights TRD Pro LED blackout fog lights TRD Pro grille AJT DESIGN blackout vent/shift/cup holder Wireless charging tray Remote starter Upgraded alpine speakers, amp, dual sub box. Rear underseat storage.
    It’s rare that I actually laugheout loud reading a comment. This is one time I had a good belly laug. thank you!
    joonbug[QUOTED] likes this.
  20. Feb 2, 2021 at 6:49 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    The stock horns on my 07 are very loud. Horn is a safety device; not a headunit. Treating them any different is silly.
