Tundra headache
Discussion in '1st Gen Tundras (2000-2006)' started by Doorjam, Sep 1, 2025 at 3:44 PM.
  1. Sep 1, 2025 at 3:44 PM
    Doorjam
    Doorjam [OP] New Member
    Monday
    The alternator went out on my 2006 Doublecab SR5, 2wd. Put a new one in and a new battery. Now the ABS light is on. The brake light is on. Windows won't work, including the back full window. Door locks do work. The speedometer doesn't work. I've checked fuses. Still scratching my head as to what it could be. Any help getting pointed in the right direction is greatly appreciated.
  2. Sep 1, 2025 at 4:12 PM
    You checked both the fuses in the dash AND the fuses inside the engine bay? Because it sounds like one of the fuses in the engine bay is blown based on the circuits that are out. Inspect all of them, including the square fuses.
  3. Sep 1, 2025 at 4:26 PM
    Probably that big 120amp fuse is blown
    shifty` likes this.
  4. Sep 1, 2025 at 5:37 PM
    Aerindel
    Aerindel New Member
    Montana
    Sounds like a bad ground to me.
    ZappBrannigan and ATBAV8 like this.
  5. Sep 1, 2025 at 7:11 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Check those grounds.
  6. Sep 2, 2025 at 12:16 PM
    Doorjam
    Monday
    Replaced both of the square fuses and checked under the dash and in the engine bay. I'll start checking grounds next opportunity I get to work on it. Thank you all for your input
