Show us your ham radio installations
Discussion in '2.5 Gen Tundras (2014-2021)' started by fours, Nov 30, 2019.
  1. Apr 10, 2020 at 8:41 AM
    #241
    Zero One Actual
    @TransNone13, @P-Factor, @GodlessPro, @fours
    This just arrived today (10 April). This is for the roof mount idea that I may still go with.
    2m/70cm DB antenna. 46cm/18in long.
    Diamond NMO mount with 13.5 feet of RG316.
    If anyone thinks I should return these items for something different, I am open to all suggestions because I have nothing but free time and want to do this right the first time. So for example, no 13.5 feet isn’t enough cable and you should get 16 or 17 feet or whatever.
    smslavin and GodlessPro like this.
  2. Apr 16, 2020 at 4:14 PM
    #242
    Damie Street
    Damie Street New Member
    Edsel
    South Carolina
    2016 MGM CrewMax SR5 TRD OffRoad
    This is the sexiest mount I've seen! Definitely going to look into doing a similar mount when I get my set up.
    I'm new to the HAM Radio world. And I read through the thread. Going to download the app and start taking the tests through that. And hopefully by the time the COVID 19 pandemic is over I will be able to find a local testing.
  3. Apr 17, 2020 at 5:42 PM
    #243
    Wallygator
    Damie Street likes this.
  4. Apr 17, 2020 at 5:54 PM
    #244
    Damie Street
    Edsel
    South Carolina
  5. Apr 19, 2020 at 11:44 AM
    #245
    Zero One Actual
    Did everyone in this thread go underground or die?
    GodlessPro likes this.
  6. Apr 23, 2020 at 4:19 PM
    #246
    Zero One Actual
    Got 17 feet of RG58 from Laird and a spring kit for my antenna.
  7. Apr 23, 2020 at 4:29 PM
    #247
    P-Factor
    P-Factor New Member
    Working on both but thanks for asking!!:hattip::)
  8. Apr 23, 2020 at 4:29 PM
    #248
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Yes, I died. What did you decide for mounting?
  9. Apr 23, 2020 at 6:38 PM
    #249
    Zero One Actual
    The center of this beautiful roof.
  10. Apr 23, 2020 at 8:14 PM
    #250
    Damie Street
    Edsel
    South Carolina
    Let's see some pics!!
  11. Apr 24, 2020 at 3:03 AM
    #251
    Zero One Actual
    Instal will commence in a few days and I will get pics of full instal here for others to reference if necessary.
    GodlessPro and P-Factor like this.
  12. Apr 24, 2020 at 5:02 AM
    #252
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    not sure about a ham antenna but i know it's possible for a cb one.
    http://wagongear.com/shop/antenna-mount/
    i have the parts for this but i have not yet dug into the fender to try and make it work. i still need to finish my ham install... :anonymous:
    GodlessPro and Zero One Actual like this.
  13. Apr 24, 2020 at 9:39 AM
    #253
    Zero One Actual
    I have "been doing my instal" for about four months now.
  14. Apr 24, 2020 at 12:22 PM
    #254
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'm going to finish up my solar stuff this weekend. since everything will be unplugged, i'm planning on getting the radio in too.
    Wallygator and GodlessPro like this.
  15. Apr 24, 2020 at 1:28 PM
    #255
    GodlessPro
    Matthew
    NorCal
    I applaud you for the commitment.
  16. May 8, 2020 at 3:29 PM
    #256
    fours
    fours [OP] New Member
    Wichita, KS
    2017 Tundra SR5 Blazing Blue Pearl
    Thanks NH2BV, you talked me into the Xiegu G90 for the future Airstream/mobile/HF... much obliged!!
    I'm still convinced that I can transmit on 2m/70cm via the Tundra using Android and SDR.
    I ordered the Phoenix radio (for 2017 SR5 Tundra): https://www.phoenixautomotiveinc.co...9&utm_source=google&utm_medium=smart_campaign
    I also ordered the add-on for HDTV, just because the connectors seemed to match those of SDR contraptions...
    I'm not sure if I should buy the HackRF One or the LimeSDR to accomplish this goal of transmitting on 2m/70cm?
    Anybody got any ideas!?
    73
    W2PAN
    (follow along: http://W2PAN.xyz)
    Zero One Actual likes this.
  17. May 8, 2020 at 3:48 PM
    #257
    ezdog
    ezdog New Member
    Gateway To The West
    Wait a second,you really need to get the Metal into the air as much as possible.
    If you can not clear the truck with the antenna then it is probably not worth burying one inside the metal structure either in my experience.
    One of the beauties of the MNO mount is that you can run a dinky little antenna when needed and a full wave when you need to and can get away with that!
  18. May 8, 2020 at 3:55 PM
    #258
    ezdog
    ezdog New Member
    Gateway To The West
    Yaesu FTM-350
  19. May 10, 2020 at 10:56 PM
    #259
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    what antenna is this with the mount? are you happy with the signals?
  20. May 11, 2020 at 4:50 AM
    #260
    ezdog
    ezdog New Member
    Gateway To The West
    Its a Comet SB1 Dual Band and the only really short antenna that I have liked and is an NMO mount!
    I also have 2 longer Diamonds that I interchange with it as needed and as I posted there already the key is ALWAYS to get the antenna as high as you can and the performance adjusts considerably as it clears the Cars Metal.
    I have also lost a few long antennas on this mount as my street and many streets have low hanging branches and even with springs I hear what sounds like a gunshot and bam the antenna is gone!
  21. May 11, 2020 at 8:22 AM
    #261
    GodlessPro
    Matthew
    NorCal
    Always good to have options and backups for antennas. I had a tree steal my Comet SBB-5 a couple years ago. My Comet 2x4 with a spring has a semi-permanent bend due to repeated tree strikes. I keep a Comet SBB-1 in the truck for when there is a high likelihood of low branches and if I know I won't be hindered by the distance hit.
    Coolhardy and ezdog[QUOTED] like this.
  22. May 11, 2020 at 12:28 PM
    #262
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    What other Diamond antennas you have? Height is not an issue for me. I need something with great signals. I will be installing Yaesu FTM 400XDR
    Randy Morton likes this.
  23. May 11, 2020 at 1:15 PM
    #263
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Diamond makes good antennas all the way around. Pick the one that matches your needs. The most important thing in any installation is grounding and bonding. Connect bed to frame, cab to frame, hood to cab, exhaust to frame (in three places, front, center, and rear), and use both copper strap and copper braid everywhere except the exhaust. The flex will break a strap there, braid will survive. Make sure the antenna mount has a good ground as well. The better the grounding and bonding, the better the signal. The best mobile antenna ever made will perform poorly if it's not properly grounded. I have both Comet and Diamond antennas. Both work well, but the Diamond seems to be a little more resonant than the Comet. I've also had to replace two Comet coils. They lose resonance for some reason. I don't know if it's tree strikes, water leaking into the coil, or something else.
    KK6PD and Coolhardy[QUOTED] like this.
  24. May 11, 2020 at 1:19 PM
    #264
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'm running that radio as well but with two comets, ssb-1 and ssb-5. the 1 is for trail days since it's short and flexible. i trade out for the 5 when i want a little extra range or on more open trails. both are NMO mounts.
  25. May 11, 2020 at 2:15 PM
    #265
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Thanks. Would it be possible to run a splitter on the back of 400XDR and have both antennas connected? I apologize in advance if its a stupid question. I am newbie to this technology.
  26. May 11, 2020 at 3:14 PM
    #266
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    honestly, i don't know a full answer. i've got too much stuff in my head as it is so, i know just enough about HAM to be dangerous. :D
    from what i do know, i don't think this is something you'd want to try. the antennas may be out of phase and your swr is likely to be pretty high as a result of some impedance issues and a bunch of electrical math that is slightly beyond me.
    Coolhardy[QUOTED] likes this.
  27. May 11, 2020 at 3:29 PM
    #267
    ezdog
    ezdog New Member
    Gateway To The West
    No not a practical idea at all.
    You could use a switch and select one or the other though.
  28. May 12, 2020 at 9:39 AM
    #268
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    anyone ever tried one of these compactennas? i like the idea of the low profile but my nmo mount is right in the middle of the roof between the solar panels. not sure how well it would work right there. any opinions?
  29. May 12, 2020 at 10:26 AM
    #269
    GodlessPro
    Matthew
    NorCal
    That looks interesting. I read up on a few low profile antennas in the past and they were a crap shoot, this one looks like it might have some promise.
    smslavin[QUOTED] likes this.
  30. May 12, 2020 at 10:34 AM
    #270
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    yea, i'm curious. hro catalog showed up yesterday and i saw it in the back. i don't think i would have seen it otherwise.
    GodlessPro[QUOTED] likes this.
