Show us your ham radio installations
Discussion in '2.5 Gen Tundras (2014-2021)' started by fours, Nov 30, 2019.
  1. Feb 5, 2020 at 6:36 AM
    #181
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    So far it sounds great. I have not taken it out on a long drive for testing yet. The speaker does come with an 8’ cord and I did need to extend that a few feet to reach under the driver seat.
    Here is the speaker:
    https://www.amazon.com/dp/B000ZIC18Q/ref=cm_sw_r_cp_api_i_jgToEb73997NJ
  2. Feb 5, 2020 at 7:30 AM
    #182
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's awesome Scott!
  3. Feb 5, 2020 at 3:47 PM
    #183
    Zero One Actual
    I just noticed we are ICS fab twins.
    InfernoPRO[QUOTED] likes this.
  4. Feb 5, 2020 at 6:31 PM
    #184
    InfernoPRO
    Scott
    Sacramento
    It’s a great place to mount my tablet. Rago fab plate was not out when I bought the ICS. Would like to see Rago’s in person to compare.
    GodlessPro likes this.
  5. Feb 6, 2020 at 2:26 PM
    #185
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    BalUn = Balanced to Unbalanced, coaxial cable is unbalanced and the BalUn allows you to use twin lead cable. You might be able to find an impedance matching network to allow it but I don't think you'd gain anything but I say if Foghorn TX want's to try I say go for it I'm just thinking the antenna trimming would be tough and with the mismatch you might get some strange frequency response but if it's not in the 2 meter band what the heck just make sure you post your results for the rest of us. Ham radio is for experimenters.
  6. Feb 6, 2020 at 4:54 PM
    #186
    fours
    fours [OP] New Member
    Wichita, KS
    2017 Tundra SR5 Blazing Blue Pearl
    Any elmer tips for an inspiring CWer!? FB KDOLAS
    The problem is, is that, I have a degree in music performance (with an emphasis) in percussion. 10 wpm, 20 wpm, etc... the QSOs just all sound like drum beats to me.
    The problem that I have is that it's nothing like listening to James Brown when in-the-pocket beat patterns occur... there's a different beat (or hum)... almost like an "Sri Lankan tabla drum cycle"... which makes it difficult to learn from my point of view.
    It would be awesome to get my expert license, but I gotta learn this stuff = DE GNRL
    73
    KDOLAS
  7. Feb 7, 2020 at 12:14 AM
    #187
    Zero One Actual
    This post makes me have so many more questions while at the same time giving me an inferiority complex. I like it.
    shellshock likes this.
  8. Feb 7, 2020 at 3:37 AM
    #188
    coTony
    Tony
    Montrose, CO
    What brand/model are you running there?
  9. Feb 7, 2020 at 4:38 AM
    #189
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Yaesu FTM-400.
  10. Feb 9, 2020 at 8:32 PM
    #190
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    TransNone, which antennae are you running? I'm about to buy that same hood mount and want to make sure 1-the antennae I buy will fight and 2-it's a good one for my radio reception. I can tell it's a Diamond from your picture. And looks like the mount is the K/400 3/8C.
    Thanks in advance mate.
  11. Feb 9, 2020 at 9:27 PM
    #191
    TransNone13
    TransNone13 New Member
    I have these, and run the 770 most often, I might be moving it to my bed rack when it arrives.
    NR73BNMO Dualband Mobile Antenna
    NR770HBNMO Dualband Mobile Antenna
    K400SNMO Trunk/Hatchback Mount
    Petrone likes this.
  12. Feb 10, 2020 at 7:10 AM
    #192
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    The 3M vinyl will protect the paint, but it also defeats the grounding that the antenna needs. Running a braid from the hood to the body, and from the body to the frame, will also improve the transmit pattern and lower the noise floor. If you decide to run HF mobile, run braids from the front, rear, and center of the exhaust to the frame. This will eliminate most, if not all, of the interference from the engine.
    KK6PD and Petrone like this.
  13. Feb 10, 2020 at 7:50 AM
    #193
    TransNone13
    While ground is always good, those two antennas don't require it and I have zero issues with noise. I did add an inline DC noise filter though.
  14. Feb 11, 2020 at 11:39 AM
    #194
    TransNone13
    Prepping for delivery... technically still HAM. Will be moving the antenna to the bed likely.
  15. Feb 11, 2020 at 8:01 PM
    #195
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    What is that that requires the antennae move??
  16. Feb 11, 2020 at 9:15 PM
    #196
    TransNone13
    Nothing, I just think I'd rather secure it and ground it to the rack i just installed.
    fours[OP] and Petrone like this.
  17. Feb 11, 2020 at 9:27 PM
    #197
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    So..... Is it worth it to get your license and own one of these? And how much will it cost to get the license and a set up for the truck?
    I have a CB.... It works for what I need and my kids can "play" on it too.... But I wouldnt mind having an alternative to it....
  18. Feb 11, 2020 at 9:38 PM
    #198
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    Very nice!
  19. Feb 11, 2020 at 9:40 PM
    #199
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    The license is only around $30 and takes a little studying to take the test. Capabilities are much great with a HAM radio vice CB. Nice radios aren't cheap but you can get started with inexpensive walkie talkie like radios that range further and can leverage local repeaters.
    4x4_Angel[QUOTED] likes this.
  20. Feb 11, 2020 at 10:27 PM
    #200
    4x4_Angel
    Bree
    Funky Town, Texas
    So worth it....ok. well I guess I'll get rocking on that then. Studying doesn't bother me
  21. Feb 11, 2020 at 10:35 PM
    #201
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    I passed mine with the free Ham Test Prep app.
    4x4_Angel likes this.
  22. Feb 11, 2020 at 11:05 PM
    #202
    TransNone13
    I recommend Hamstudy and the Gorden West books. It's pretty cheap for the license if not free, but depending in your proclivity for gadgets it can get pretty expensive lol.
    Zero One Actual and 4x4_Angel like this.
  23. Feb 12, 2020 at 12:38 AM
    #203
    Zero One Actual
    I may be the newest technicians license in the group and I used the HAM test prep app on my phone and iPad to go section by section until I was scoring ninety percent or above in each section. Ended up missing two total on the test.
    http://www.arrl.org/find-an-amateur-radio-license-exam-session
    Use the above link to enter search info for your area. See what dates on the horizon work for you and set one as a deadline and go from there.
    My setup for the radio and accessories was about $600 and that setup came from here.
    https://www.gigaparts.com/icom-ic-2730a-dual-band-mobile-radio.html
    Everyone in this thread is super helpful and experienced which is nice because you do not get caught up reading online arguments or opinions that just make your head hurt. Also it helps because everyone is a very similar truck as well for setup and they have proven the setups work also. It’s like having ten Yodas to teach you.
    P-Factor and 4x4_Angel[QUOTED] like this.
  24. Feb 12, 2020 at 3:00 AM
    #204
    4x4_Angel
    Bree
    Funky Town, Texas
    Thank you!!
  25. Feb 12, 2020 at 8:48 AM
    #205
    TransNone13
    What's your call, do you have APRS setup? How you liking the Icom? One of the reasons I didn't get that brand was simply my association with Icom chatter and the Taliban lol.
  26. Feb 12, 2020 at 9:05 AM
    #206
    Zero One Actual
    I totally understand the association with ground df’ing “icoms” and where that mentality would stem from. But, if you really think about it, their radio of choice being utilized in the harshest terrain on the planet with repeater stations and the ability for them to communicate successfully day and night actually shows you how good the Icom brand is.
    Now, understand, I have absolutely no other radio or brand to compare mine to, so I could have the worst radio ever made, but until one of you tells me that I will have no clue.
    I have not started with APRS but will look into once I have a reputable source relocate from cannery row to skid row.
    P-Factor likes this.
  27. Feb 12, 2020 at 9:22 AM
    #207
    TransNone13
    I wasn't sharpshooting iCom, it's good stuff. They're solid just like Codan. Also an Afghan thing haha. Get that APRS up! :)
    Zero One Actual likes this.
  28. Feb 12, 2020 at 5:04 PM
    #208
    fours
    Wichita, KS
    I used the paid apps. I haven't tried their 'Lite' apps. I studied for a couple of weeks (ten years ago) on this app and passed Technician and General easily.
    There are three different apps... one for each test Technician, General, Extra.
    iOS/iPhone:
    Technician: https://apps.apple.com/us/app/ham-test-prep-technician/id297951496 ($5.99)
    General: https://apps.apple.com/us/app/ham-test-prep-general/id298756574 ($5.99)
    Extra: https://apps.apple.com/us/app/ham-test-prep-extra/id298760002 ($5.99) (Keep in mind that the new Extra questions are changing on July 1st, 2020 and it might take a little while for this app to update to the latest questions/answers. See: https://forums.qrz.com/index.php?threads/new-amateur-extra-question-pool-released.690055/)
    I'm now starting to study for the Extra. Is it true that S**ff get's harder as you get older!?
    Android: (Not sure?)
    Totally worth the cost!
    Also, once you get your license, this chart is your friend: http://www.arrl.org/files/file/Regulatory/Band Chart/Band Chart - 11X17 Color.pdf
  29. Feb 12, 2020 at 5:18 PM
    #209
    fours
    Wichita, KS
    TheyCallMeBruce84 and Petrone like this.
  30. Feb 12, 2020 at 6:49 PM
    #210
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Got this little guy off a talib who didnt need it anymore..............144442.jpg
    Think I could use it as my comms???:anonymous::anonymous::rofl:
    fours[OP], coTony and Randy Morton like this.
