Tundra Ham Radio!?
Discussion in '3rd Gen Tundras (2014+)' started by fours, Nov 30, 2019.
  1. Dec 30, 2019 at 8:43 PM
    #151
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    And order placed. Happy birthday to me. Ordered the FTM-400XDR, $140 discount so can't argue with that.
  2. Jan 1, 2020 at 10:14 AM
    #152
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Currently in a transitional period.
    2018 Blue SR5 4x2 4.6L CrewMax Short Bed
  3. Jan 1, 2020 at 10:51 AM
    #153
    abomb60
    abomb60 New Member
    Massachusetts
    2018 Tundra 1794 MGM
    Yeah for the price point that is a good place to start with SDR but if you think it's something you might get in to a little more seriously you might want to spend a couple extra bucks and get something like this instead ... https://www.amazon.com/dp/B079C4S2BT.
    Gives you a couple antenna options, has a SMA antenna port and includes a bias T in case you ever need to power an active patch antenna or a LNA.
    With any SDR or radio your weak point is going to be the antenna. If you really want to pull in signals you need the correct antenna and you need to mount it as high up as you can. For most of what I listen to with SDR I run a wideband discone antenna mounted high up in my attic and that works great for anything from 25MHz to 1.7GHz (https://www.amazon.com/gp/product/B00QVPGKHU/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1). If you want to go lower into the HF & shortwave frequencies you'll need an antenna for that as well as something like a Spyverter to get you below 25MHz. This is where the better SDR with SMA connectors and the bias-t comes in :)
    Feel free to PM me if you have any questions!
    FoghornTX likes this.
  4. Jan 1, 2020 at 11:05 AM
    #154
    abomb60
    abomb60 New Member
    Massachusetts
    Also if you have a spare laptop you can put that close to your antennas up in an attic or such and run Spyserver which is included with SDR Sharp (and it's free). That allows you to connect to the Spyserver from another computer and use the SDR it's connected to.
    I'm actually using it right now to connect to my laptop in an upstairs room that is connected to a L-band patch antenna so I can work some Inmarsat satellites from my main computer in the basement office. Also saves you from having to buy tons of good quality antenna cable :)
    Petrone likes this.
  5. Jan 2, 2020 at 8:58 PM
    #155
    TransNone13
    TransNone13 New Member
    Got the HT up and running, works pretty well. It's ridiculous that the two transceivers don't use the same programming software and that certain things like beacon status wildcards don't seem to be the same. <head scratch>
  6. Jan 6, 2020 at 8:07 PM
    #156
    TransNone13
    Has anyone had to upgrade their stock battery? There's a gnarly voltage drop directly wired with the truck off.
    Edit:
    Screw it, I just bought a northstar battery after seeing how many more amp hours were over stock and well, AGM.
    https://vimeo.com/383210211
  7. Jan 13, 2020 at 6:40 PM
    #157
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    How's that antennae working from the hood?
  8. Jan 13, 2020 at 7:04 PM
    #158
    fours
    fours [OP] New Member
    Wichita, KS
    2017 Tundra SR5 Blazing Blue Pearl
    Woo hoo, I made a contact on my Yeasu ht-60 that hadn't had a battery charge in over four years plus!!!
    73s
    KD0LAS
    Petrone likes this.
  9. Jan 13, 2020 at 7:08 PM
    #159
    TransNone13
    Absolutely zero issues, coming in clear and strong most of the time depending on topography.
    Does it do APRS? I guess no.
    Petrone likes this.
  10. Jan 13, 2020 at 9:30 PM
    #160
    Petrone
    Petrone New Member
    2010 Base Tundra
    None Yet
    Hey Adam, which suction cup attachment to the windshield did you use? Just got mine in the mail a couple days ago and still looking at all the options. Thanks in advance!
  11. Jan 13, 2020 at 10:22 PM
    #161
    TransNone13
    For what it's worth I used the Yaesu one, I believe he did as well
  12. Jan 14, 2020 at 4:04 PM
    #162
    TransNone13
    How are people routing cables through the bed for.those who have those mounts? I would like to see how that looks on mine with overlander stuff.
  13. Jan 14, 2020 at 4:10 PM
    #163
    fours
    Wichita, KS
  14. Jan 14, 2020 at 6:18 PM
    #164
    fours
    Wichita, KS
    For now, as this is my only current option, this works pretty good in the cup holder with natural amplification!
    Mountun Goat likes this.
  15. Jan 14, 2020 at 6:46 PM
    #165
    fours
    Wichita, KS
    For any noob HAMs out there, download one of the many ios/android apps to study for an exam. It's pretty simple and you can do all three exams at the same time- "Technician", "General", "Amateur Extra" at any testing location (http://www.arrl.org/find-an-amateur-radio-license-exam-session). At the very least, get your "Technician" license. This way you can communicate via the amateur radio bands and not just "CB Radio" (Citizens band). Just find your testing location and study for a few weeks on your smart phone and you'll pass no problem ;=
    Besides simply poking around on "Ham 2m radio" (most common when local [5-100 miles]), one could poke around with "APRS" which transmits location data. This would be relevant to any Tundra owners that go off-road and would like their family to know what's yo ass is doin`!!! If this is your case, check out this site that's running Toyotas: (https://myoffroadradio.com/) . I have no affiliation with them, but, I just found it and thought I would share ;-)
    Sunnier likes this.
  16. Jan 14, 2020 at 6:47 PM
    #166
    TransNone13
    Major updates to come, early promotion present to me!
  17. Jan 14, 2020 at 6:51 PM
    #167
    fours
    Wichita, KS
    :worthless:
  18. Jan 14, 2020 at 6:54 PM
    #168
    TransNone13
    I posted a list of the items I just ordered.
  19. Jan 14, 2020 at 6:58 PM
    #169
    fours
    Wichita, KS
    Oops... Okay, "This Thread is Worthless WITHOUT more Vids!!!", lol... is that better ;-)
  20. Jan 16, 2020 at 5:35 PM
    #170
    fours
    Wichita, KS
    Are any of you guys/gals programmers and Mac users? I just converted EchoMac (EchoLink) from `svn` to `git` and published it on github.com. We're looking for programmers with time to kill ;-)
    https://github.com/panreach/EchoMac2
