Show us your ham radio installations
Discussion in '2.5 Gen Tundras (2014-2021)' started by fours, Nov 30, 2019.
  1. Jul 29, 2020 at 1:26 PM
    #361
    Zero One Actual
    I have @brimy311 ditch light brackets and I purchased @ragofabrication extensions.
    Here is link.
    SC_TRD[QUOTED] likes this.
  2. Jul 29, 2020 at 1:28 PM
    #362
    SC_TRD
    SC_TRD Big BASTRD 4x4 Enthusiast
    Colin
    Round Rock, Tx
    2012 CrewMax & 2008 Sequoia
    Awesome, thank you!
  3. Jul 29, 2020 at 2:30 PM
    #363
    Zero One Actual
    No problems. Watch out for Vampires.....and Cowells on a Saturday.
  4. Aug 1, 2020 at 8:51 PM
    #364
    P_D
    P_D New Member
    2015 TSS CrewMax
    SC-TRD
    Thanks!
    The bracket is from CBI Offroad. I suspect that it’s just a ditch light bracket that they sell as a single instead of a pair. It is plenty stout. One issue I had was finding an NMO with a long enough throat to pass through the thickness of the bracket. That took some searching, but I found one made by Laird.
  5. Aug 4, 2020 at 10:28 AM
    #365
    SC_TRD
    Colin
    Round Rock, Tx
    Post 19 shows how 1 member did it :thumbsup:
    unless you meant the whole unit and not just the faceplate
    Zero One Actual likes this.
  6. Aug 16, 2020 at 3:34 AM
    #366
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Well... picking up my new 2020 Platinum on Monday so today I need to pull the Kenwood and everything else out of my 2015 Limited, I'll install the radio in the new truck just like I did on the old Tundra but the Platinum has the tilt/sliding sunroof and my preference is to always pop a hole and install a NMO. So a lot measuring will be made for clearance along thought on how the RF cable will be run to make sure it's clear of any mechanical equipment so I might be radio-less for a week or so and that'll be the first time in 30 years or so. Also considering on installing one of my TM-D700s instead of the TM-V708 only for the fact it's computer programmable. Wish me luck my fellow hamsters for my 65 Y.O. body doesn't twist and tuck like it used to.
    KK6PD, GodlessPro and Zero One Actual like this.
  7. Aug 23, 2020 at 10:17 AM
    #367
    OverlandHiker
    OverlandHiker New Member
    Bennett
    SF Bay Area, CA
    2019 Tundra Limited / TRD Off-Road
    I am late to the party here, but if you are still looking for a mic clip, here is a really nice one.
    https://magneticmic.com/
  8. Sep 1, 2020 at 6:48 PM
    #368
    Dragracer_Art
    Dragracer_Art New Member
    Dawsonville, GA
    2020 Crewmax 4x4
    5100's/+2.5" Eibachs, 18x9 +25 Methods,37x12.5 BFG KM3's
    Wish I had a better solution... but this is the best I could come up with for my Kenwood TM281. Its a fairly large radio and there just isnt any nice way to mount it.
    Wasnt gonna drill a hole in the roof of a brand new truck... so I used the NMO trunk lip mount on my hood.
    KK6PD, jeremyd and Zero One Actual like this.
  9. Sep 1, 2020 at 7:24 PM
    #369
    Zero One Actual
    What about under the drivers seat with Velcro or on a bracket? Then your mic can come out from under the seat between the center console and your seat.
  10. Sep 2, 2020 at 3:21 AM
    #370
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    That would work if the faceplate was removable and could be mounted in a visible location... but as it is, I need to be able to see the radio to operate it.
  11. Sep 2, 2020 at 6:28 AM
    #371
    Zero One Actual
    Ahhhh, ya my bad. My Icom has a detachable faceplate. Sorry for the bad idea.
    I think some other members have put it vertically in their center console also. There are pics of this earlier in this thread.
  12. Sep 2, 2020 at 6:59 AM
    #372
    Dragracer_Art
    Dawsonville, GA
    2020 Crewmax 4x4
    Yeah... eventually I will upgrade to the Kenwood dual-band V71... and with that I can detach and relocate the faceplate to a better spot. :thumbsup:
  13. Sep 2, 2020 at 7:04 AM
    #373
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Is this considered a Ham radio or a CB radio trash talker? Lol Thinking about sticking this in the center console. Any recommendations on a not so blatant antenna?
  14. Sep 2, 2020 at 8:30 AM
    #374
    Zero One Actual
    That looks like a 10/12 meter HAM radio. As far as antennas, people use hood magnet mounts, ditch light mounts, middle of the roof mounts, bed rail mounts, etc. as far as the length of the antenna, that is up to the bands you are transmitting on and where you want to put it really.
    jeremyd[QUOTED] likes this.
  15. Sep 2, 2020 at 8:31 AM
    #375
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Roger beep AND echo? Most assuredly a CB. I found this at a local CB/Stereo/Alarm installer, maybe something like this would make for a stealth antenna.
  16. Sep 2, 2020 at 8:36 AM
    #376
    Zero One Actual
    https://m.youtube.com/watch?v=BoZSpb80V7s
    jeremyd likes this.
  17. Sep 2, 2020 at 9:39 AM
    #377
    Randy Morton
    Randy
    Ok, glorified CB. Anything with built in Roger Beep and echo is still just another CB. This one snuck in with a single wire jumper blocking the CB freqency range to avoid the FCC type acceptance requirements for CB radios.
  18. Sep 12, 2020 at 4:53 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    anyone play with cross band repeat or a mobile digipeater?
  19. Sep 12, 2020 at 5:32 PM
    #379
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    I cross band repeat with 2 of my mobile radios. I use the Ft 8800 for 2M to 70 cm and vice versa. I use my TYT 9800 for Crossing over to any of the 3 bands from 70 cm and back.
    smslavin and Zero One Actual like this.
  20. Sep 13, 2020 at 4:06 AM
    #380
    ezdog
    ezdog New Member
    Gateway To The West
    Sure!
    I do it with Yaesu and Kenwoods all the time but I also have a full duplex cross band repeater that I built for eventnwork that we do where we need to run 2 nets at the same time from the same place but without using can filters for the same band .
    smslavin[QUOTED] likes this.
  21. Sep 13, 2020 at 8:37 AM
    #381
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    ok, so what i would like to do is set something up to bounce aprs from my handheld when i'm out for a ride or a hike. i have a yaesu ftm-400 in the truck and the handheld is a ft3d-r.
    one option is to use a kantronics kpc-3 tnc box. kantronics does have a tnc to din cable for yaesu but i can't seem to figure out if the ftm-400, or any yaesu, can digipeat. if the 400 cannot digipeat, then i'll pick up an extra 2m to just use as the digipeater.
    another option is to put the 400 into crossband repeat mode but there are potential issues. heat build up on the 400, callsign on transmit and disconnection if something goes awry. if i'm out for a ride or a hike, it'd take awhile for me to get back to the truck. also, it seems a few of the repeater stations here in colorado aren't big fans of this. it looks like you can do it if you have prior approval from the repeater owners.
    third option is this mobilinkd tnc3 box combined with the aprs.fi app on a phone. my guess is that once cell service drops out this will be a paperweight. need to dig out some more info.
    i also came across this article but i'm not really in the mood to get all hacky with linux and raspberry pi...
    the tnc box feels like the best option. does anyone know if i can use it with the ftm-400? if i can't, what would be a good radio to pair with it?
  22. Sep 13, 2020 at 12:30 PM
    #382
    ezdog
    ezdog New Member
    Gateway To The West
    Have you looked at Byonics?
    We use the shit out of his stuff and it just works!
    Also the 400 probably would be OK just digipeating I bet much lower stress than voice.
    I also have a few kenwood and Alinco rigs with tnc already on board
  23. Jan 11, 2021 at 10:07 PM
    #383
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    This is my next big project. Get my HAM radio license and figure out how I want to set it up. Just like this Discussion, there's alot of information out there. Definitely alot to take in. Thanks for giving me ideas of what everyone has done.
  24. Jan 12, 2021 at 3:11 AM
    #384
    jeremyd
    NV
    2014 SR5 CM 4X4
    I know this is a base station, but what do you ham guys think about this? Ham or cb, just curious.
  25. Jan 12, 2021 at 3:19 AM
    #385
    needsmoresalt
    needsmoresalt New Member
    Patrick
    2020 Tundra TRD Pro
    A few
    That is a very spendy CB radio.
  26. Jan 12, 2021 at 5:35 AM
    #386
    Kung
    KG, VA
    Same - supposedly an 'amateur' CB radio, but most amateurs don't have $800+ to spend.
  27. Feb 12, 2021 at 6:39 PM
    #387
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    I’ve seen some photos in here where some of you have put the external speaker in the center dash.
    wondering if I’ll have any problems just disconnecting the factory speaker there and running wire to it and use it as my external. I think the stock dash speakers are weird like 6 ohm or something
  28. Feb 12, 2021 at 6:51 PM
    #388
    ezdog
    ezdog New Member
    Gateway To The West
    No way to tell other than just trying it?
    It is really tough I think to find a decent comms speaker overall so I have little hope that the center speaker would be decent for that either but you never know.
    Mine has no speaker there and the grill just snaps out so it should not be to hard to see how it sounds,or to replace it with any known good comms speaker for that matter!
  29. Feb 12, 2021 at 6:55 PM
    #389
    eick
    eick New Member
    Yea good point. I’ll try it but I’ve never seen the need to buy an overpriced ‘ham’ external speaker. It’s just a speaker I could pull one from a 78 Datsun and use it if I had to.
    If it sounds like ass I’ll try a different one that fits there
  30. Feb 12, 2021 at 6:58 PM
    #390
    ezdog
    ezdog New Member
    Gateway To The West
    I never mentioned any overpriced ham speaker.
    I just know from experience that it is not all that common to find any random speaker that sounds good for our radio.
    I like the old Motorola speaker and most of the radio shack speakers usually but I never pass on the chance to test any new ones that I find that might be better too.
    YMMV clearly.
