Tundra grill question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wildcardtundra, Feb 24, 2020.
  1. Feb 24, 2020 at 4:06 AM
    Wildcardtundra
    Wildcardtundra [OP] New Member
    2016 Tundra Platinum AWD
    Can this fit my 2016 tundra platinum?
  2. Feb 24, 2020 at 4:13 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
  3. Feb 24, 2020 at 10:43 AM
    iamkeith
    iamkeith New Member
    2001 --> 2018
    I believe that one has the TSS radar unit, which didnt appear until 2018 trucks. (Somebody correct me if I'm wrong.) You'd be better off with the older pro grille.
  4. Feb 24, 2020 at 11:24 AM
    Yes it will fit.
    The 2017 & prior grill is different and half the price because of the TSS Senor Cover.
    If You go with the 2019/2020 grill I would buy the knock off TSS Sensor Cover because you don't have the TSS Sensor and a knock off cover wouldn't be a safety issue just cosmetics.
  5. Feb 24, 2020 at 11:31 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    This. Dont waste money on the oem sensor. If im not mistake it costs as much or more than the grill itself
  6. Feb 24, 2020 at 11:38 AM
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
  7. Feb 25, 2020 at 3:34 PM
    upnorth
    upnorth New Member
    Joe
    2018 Limited TRD - Cement
    The TSS was around on 2018 Limited and above trim models Tundras I believe.
  8. Feb 25, 2020 at 5:55 PM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    There’s also a cover piece on the to of the grill that you see when you pop the hood with that grill. It’s like $12 or something like that
  9. Feb 25, 2020 at 6:16 PM
    YotaNC
    YotaNC New Member
    2017 Black Tundra SR5
