Tundra Grill Better than plasty dip for the grill
Discussion in '2.5 Gen Tundras (2014-2021)' started by CJ21, Oct 3, 2016.
  1. Oct 3, 2016 at 5:18 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
  2. Oct 3, 2016 at 5:26 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Def looks awesome.
  3. Oct 3, 2016 at 5:28 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Thank you!
  4. Oct 3, 2016 at 5:45 AM
    757TUNDRA
    757TUNDRA Not a New Member
    Illinois
    2018 Barcelona Red Metallic Platinum 4x4
    OEM Bed Cover, OEM Bed Rail System, OEM Bedmat, OEM Doorsill Protectors, OEM TRD Rear Sway Bar, OEM Color Matched Door Handles, OEM Color Matched Mirror Caps, OEM Bed Net, OEM Driver Side Grab Handle, BFG K02 LT275/60/20, WeatherTech Digifit FloorLiners, Salex OCD Console Organizer, Salex Console Tray
    Looks awesome! I may have to borrow this idea when I install the color matched grille surround, bulge and front bumper ends.
  5. Oct 3, 2016 at 7:47 AM
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Plasti dip does have it's uses, but I prefer paint or bedliner. The only good thing about dip is that you can remove it "easily".
  6. Oct 3, 2016 at 7:51 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I agree with you 100% I used the plasty dip on the prior vehicle on the front grill and it lasted for like a year just when it was time to go over it because of the Little Rocks and road debris. it started to becoming a pain because I would have to respray the entire grill.
  7. Oct 3, 2016 at 7:58 AM
    kurtwp
    kurtwp What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    Did you have to lightly sand the grill?
    Kurt
  8. Oct 3, 2016 at 8:07 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Is that permanent? Just bought some plastidip yesterday to do my bumper ends.
  9. Oct 3, 2016 at 8:21 AM
    csuviper
    Broomfield, CO
    Yes the bed armor would be permanent.
  10. Oct 3, 2016 at 8:21 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    Yes it is permanent and no I did not have to sand anything .
  11. Oct 3, 2016 at 8:44 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Looks great! You said no sanding. Did you have to do any special prep before you spray it on? Did you need more than 1 coat?
  12. Oct 3, 2016 at 8:51 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I wash the grill with some Dawn dish detergent dried it off very well then I went over the complete grill with rubbing alcohol 91 grain from Walmart let that dry and then sprayed it .
  13. Oct 3, 2016 at 8:56 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I put on about 6 to 7 light coats I waited about 15 to 20 minutes in between each spray session . I remove the Toyota emblem out of the grill . I bought two cans of the spray and I used half of each can .. The reason why used half of each can as I noticed it starts to get thick at the end of the nozzle and it would gunk up and it was gunking up from the inside of the nozzle so I just stopped and opened up a new can .
    Viper3G likes this.
  14. Oct 3, 2016 at 8:58 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    I did no sanding at all .
    Viper3G likes this.
  15. Oct 3, 2016 at 9:05 AM
    Viper3G
    Rick
    Awesome! Thanks for all the tips @CJ21!
  16. Oct 3, 2016 at 9:23 AM
    TheBeast The Beach
    that's a shiny black truck ! ( coming from a black truck owner :) ) :thumbsup: ..looks great
  17. Oct 3, 2016 at 9:28 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    :crapstorm: Thank you !! I try to keep it clean .
  18. Oct 3, 2016 at 9:32 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Wow! That looks sharp!
  19. Oct 5, 2016 at 9:51 PM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    Switched from 16 Taco
    I wonder how well it would stick to chrome.
  20. Oct 6, 2016 at 4:06 AM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
    From what I read with chrome it seems like you have to take a little bit of sandpaper and scuff it up lightly so the spray has something to grab too.
  21. Oct 6, 2016 at 5:43 AM
    Looks real good. I may consider using that on my front bumper.
  22. Oct 6, 2016 at 6:48 AM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    I sprayed bare rock sliders with same stuff and I didn't sand it. It came out ok and stick pretty well. But chrome is different story. I like it and I would like to do the same, just not sure about spraying over chrome without sanding or removing chrome completely. For now I dipped it. :playball:
  23. Oct 6, 2016 at 8:47 AM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    I wonder how well this stuff would hold up if I sprayed some nerf bars or sliders how long before it starts wearing off?
  24. Oct 6, 2016 at 9:05 AM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    That I can't answer because I had my rock sliders only for a month or so. But I read that people are pretty happy with it on sliders. Easy to touch up vs powder coating which is hard to repair because it usually breaks by pieces.
  25. Oct 6, 2016 at 11:47 AM
    SuperSilverTundra
    Nick
    that's a good point would be easy to touch up
  26. Oct 6, 2016 at 11:55 AM
    4RNR
    4RNR トヨタ
    America
    16 Tundra SR5 CM
    When plasti dip on my grill gives up I will probably try dupli.
  27. Oct 6, 2016 at 1:48 PM
    SuperSilverTundra
    Nick
    looks good do you have any close up pictures?
  28. Oct 6, 2016 at 1:50 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
  29. Oct 6, 2016 at 1:51 PM
    SuperSilverTundra
    Nick
    :thumbsup:
  30. Oct 6, 2016 at 1:52 PM
    CJ21
    CJ21 [OP] CJ-21
    DELAWARE
