Tundra gas mileage
Discussion in 'New Member Introductions' started by Cottonww, Dec 8, 2020.
  1. Dec 8, 2020 at 12:46 PM
    Cottonww
    Cottonww [OP] New Member
    2013 red Tundra w 6' bed
    I have a 2013 Tundra with 72K miles with a 6.5' bed and have a Hallmark Milner poptop camper on it. My gas mileage is like 12mpg. Is there anything I can do to improve that? I had hoped for more like 14mpg.
    Bill
    YardBird and Blue Thunder like this.
  2. Dec 8, 2020 at 1:13 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    Welcome from Oregon.
    First rule about Tundra gas mileage... don’t talk about Tundra gas mileage...
  3. Dec 8, 2020 at 1:16 PM
    Blue Thunder
    Washington
    No there isn’t. Not unless you can magically put more energy into a gallon of gas.
    Welcome from WA
    Tundyfundy, YardBird and djhase like this.
  4. Dec 8, 2020 at 1:17 PM
    ckkone
    ckkone New Member
    SLC, UT
    No
  5. Dec 8, 2020 at 1:18 PM
    Kanobi13
    Kanobi13 New Member
    Thats pretty good gas mileage with the camper on it. How much does it weight
    YardBird likes this.
  6. Dec 8, 2020 at 1:20 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    You can eek out some MPG by using mild highway tires, in the stock size. May gain .5 to 1 more by installing DD exhaust. But any cost for those items and the little MPG they would offer would take a lifetime of driving to recoup the cost of the purchases.
    Tundras do not get good MPG. Your MPG sounds right for hauling any real weight in the bed or mild towing.
  7. Dec 8, 2020 at 1:21 PM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Here we go !
  8. Dec 8, 2020 at 1:25 PM
  9. Dec 8, 2020 at 1:45 PM
    Kanobi13
    Kanobi13 New Member
    Where we going?
  10. Dec 8, 2020 at 1:49 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The second rule about Tundra gas mileage... don't pass a gas station once you're under 1/2 a tank (especially with a 26-gallon tank).
    :crapstorm:
    You don't mention tire size. If you're running oversized tires (and don't have an in-line speedometer calibration device installed and properly adjusted), you may not be getting a fully accurate reading on your MPG. Oversized tires cause your speedometer to show a lower speed than you are actually travelling, but also cause your odometer (including trip odometers) to show LOWER miles than you have actually travelled. The MPG computer (and your own math if you are relying on the odometers) will be off due to that discrepancy. For example, a 275/70R18 tire can be off by ~3% from the factory tires on an SR5 truck, which would make your actual MPG closer to 12.4 from what the computer was calculating. Not a lot, but that's something.
    And, as others have said, the load and the lack of aerodynamics in a camper is also gonna smack that mpg down pretty quick.
    Oh, and welcome from the wet side of WA.
  11. Dec 8, 2020 at 2:28 PM
    Cottonww
    Ha! I guess I won't talk about it! :) It has factory standard tire size but 10 ply BF Goodrich AT's. I keep it down to 65mph on the highway. My son has a 2011 Tundra with a FWC Hawk which is a bit lighter(my cry weight is about 1250lbs) and he gets 13.5 to 14mpg. I had a Tacoma before pulling a Chalet folding camper and it got 14.5 to 16mpg. The Tundra is so much more comfortable and I love its zip!
    YardBird and Black Wolf like this.
  12. Dec 8, 2020 at 2:39 PM
    Pics of that red tunny? Welcome from Colorado.
  13. Dec 8, 2020 at 2:47 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  14. Dec 8, 2020 at 2:54 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The best thing that ever happened to "gas mileage" is the US becoming oil independent. The price of retail gasoline is miniscule.
    So rerun your calcs. And this time calculate MPGPD (miles per gallon per dollar). The Tundra shines brightly on MPGPD.
    Welcome aboard sailor. We've been waiting for you.
    szabo101 and YardBird like this.
  15. Dec 8, 2020 at 3:00 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  16. Dec 8, 2020 at 3:58 PM
    Toolaholic
    Toolaholic New Member
    David
    2021 black tundra SR5 SX 4x4
    TRD rear sway bar
    I got a new 2021 SR5 4x4 . 672 miles on it. I got a high of 17.9 keeping tach below 2k. On and off throttle varying engine speed to help break in engine, 14-15 with a low of 12.
  17. Dec 8, 2020 at 3:59 PM
    Kanobi13
    Kanobi13 New Member
    Show off what did you have in the bed of your truck?
  18. Dec 8, 2020 at 4:10 PM
    Toolaholic
    David
    TRD rear sway bar
    The spray on bedliner!
  19. Dec 8, 2020 at 4:35 PM
    Kanobi13
    Kanobi13 New Member
    Lol he has a camper in bed of his truck! His mpg is not that bad
  20. Dec 9, 2020 at 6:09 AM
  21. Dec 9, 2020 at 6:44 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    DAMN!!!! I get about 14 mpg not pulling or hauling anything at all.
  22. Dec 9, 2020 at 9:38 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
