Tundra front bumper.
Discussion in 'New Member Introductions' started by Tundra 2021 Bob, Nov 16, 2021.
  1. Nov 16, 2021 at 12:42 PM
    Tundra 2021 Bob
    Tundra 2021 Bob [OP] New Member
    Bobby
    2021 Toyota Tundra
    Hello, first time in here. I have recently introduced my tundra to a metal post and it won sad to say. So now I am searching out ways to dismantle the right front corner with least amount on and not wrecking anything else. Is there anyone that has preformed this before and best way of doing it. Thanks for your help
  2. Nov 16, 2021 at 12:48 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Some pics might help. The normal way of dismantling the bumper may not work, depending on the damage.
    Tundra 2021 Bob[OP] likes this.
  3. Nov 16, 2021 at 12:58 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  4. Nov 16, 2021 at 3:12 PM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Welcome from Mesa and good luck on taking apart the bumper!!
  5. Nov 16, 2021 at 3:18 PM
    newemi
    newemi New Member
    2020 Tundra CM Ltd CB
    This weekend I went to swap my chrome corners for color matched ones, plus install my Baja Designs Fog lights. Research told me that most people were removing the bumper, but I was hoping I could do it without. That said, I tried... and failed... and I removed the front bumper. It's possible, but not worth the insane effort in tight spaces.
    There is a way to remove the front bumper skins by seperating it from the impact bumper, however after getting through it I would say don't bother and just remove it as a whole... it's really not that bad. Only hard part is the 8 nuts (bumper to frame) with limited wrench access (I refused to take off the tow hooks). Once it is off then you can remove the impact bumper and have easy access to the corners. I was able to man handle the bumper by myself while watching two kids under 5.
    :benchpress:
