Tundra for towing
Discussion in '2nd Gen Tundras (2007-2013)' started by Giantsox, Jun 12, 2021.
  1. Jun 12, 2021 at 4:26 PM
    Giantsox
    Giantsox [OP] New Member
    Casey
    Well, I always wanted a T100 when I was a teenager. Fast forward 25 years, I have a chance. Tundra 5.7 V8 Crew Max with TRD and Tow package rated to 10,100 lbs of towing. That is around the minimum of what I am looking for in towing capacity. Anyone have a gooseneck hookup in theirs? And will I be happy with this to tow horses around or should I wait for a 3/4 ton truck. I have been looking for a Silverado, but my garage just got this Toyota in and he called me up because he knows I have been looking. 118k miles, they are asking $22,500.
    Thoughts?
  2. Jun 12, 2021 at 5:08 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    Most people on here have trouble getting close to max towing capacity without maxing out the payload on the truck first. The payload is pretty low compared to a decent sized 3/4 ton.
  3. Jun 12, 2021 at 5:22 PM
    Giantsox
    Casey
    I think payload was around 1600 lbs. How's that all factor in though? I drove a car all my life but my wife loves horses so here I am LOL!
  4. Jun 12, 2021 at 5:49 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    The tongue weight of the trailer + any thing in the truck ( including passengers, but not driver) need to be less that the payload to maintain the gvwr.
    Many people go over this, but it's not legal depending on who you ask and where you live.
    That being said I tow cars around all the time and my tundra tows great, just make sure to do some research first
  5. Jun 12, 2021 at 5:53 PM
    Giantsox
    Casey
    What's your Tundra capacity?
    My thought was to put a gooseneck hitch in and get a lightweight hire trailer that could pull 4 horses. I figured 4000 lbs for them. 1000 lbs for humans. Leaves me about 4500-4800 for trailer weight which leaves a few 100 lbs for gear.
    But maybe I should just hold out for a 3/4?
  6. Jun 12, 2021 at 6:29 PM
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    Goose necks are supposed to have at least 15% of the trailer weight on the ball. Trailer + horses = 8500 lbs * 15% = 1275 lbs in your bed which only leaves 325 lbs for passengers, the actual hitch and gear.
    It's possible... But you're at the limit of the truck towing that.
    Most tundras have similar capacities. The gvwr is ~7200 lbs, so it's just that minus the weight of the truck.
  7. Jun 12, 2021 at 6:38 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    I just upgraded to a 1 ton gasser. The tundra or any half ton doesn’t even come close to towing. I would wait. It’s night and day. I’m going to do a full write up now that I have 10k miles on the new truck
    DaBoro54, AircareTundra and The Dude like this.
  8. Jun 13, 2021 at 4:43 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    I have had a Crewmax for 14 years, towed a 5,000 lb (loaded) travel trailer for years. The Tundra towed this trailer without a hiccup. A few years a go, I moved up to a 8,500 lb TT. After a few tows, I bought a Super Duty Diesel because the Tundra just wasn't as capable with the weight increase. (I kept the Tundra). The Tundra is a very capable tow vehicle, but, as the weight increases, it begins to show its rated design and power limitations.
    IMO, you would be much happier with a 3/4 - 1 ton tow vehicle towing 8,000 plus pounds.
    The Dude and Lake.Life24 like this.
  9. Jun 13, 2021 at 4:51 AM
    timsp8
    NY
    If 10,100 lbs is the minimum you are looking for then you won’t be happy in a tundra. It seems around 5000 lb is the sweet spot for a 1/2 ton. Any more and your payload is gone or trailer is too big.
    GODZILLA and The Dude like this.
  10. Jun 13, 2021 at 4:52 AM
    Giantsox
    Casey
    Thanks for the response. I have been focusing on a 3/4-1 ton but this Tundra popped up and besides the 10,100 tow rating which is at the low end of my needs, this one checks all the boxes.
    ColoradoTJ likes this.
  11. Jun 13, 2021 at 6:56 AM
    The Tundra is a great truck that pulls well within a certain range. Personally, anything over 8000 lbs towing regularly should be handled by a bigger truck.
    GN trailers typically are 15-20% pin weight and will totally soak up all your trucks capacity. Horse trailers are not light either.
  12. Jun 13, 2021 at 7:20 AM
    Giantsox
    Casey
    Yea, my bumper pull 2 horse trailer will likely be fine in the Tundra but I want to someday be able to pull 3 or even 4 horse trailer so the whole family can go out with the horses together. 4 horses and leaving 1000 lbs for humans and cargo is around 5000 lbs. Plus the trailer weight I would likely need to be able to pull closer to 12,000 lbs. Maybe I'll still look at it for now while I have my 2 horse trailer though.
  13. Jun 13, 2021 at 7:31 AM
    Giantsox
    Casey
    Gooseneck or bumper pull?
  14. Jun 13, 2021 at 8:13 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Not too many horses in there?
    Also Tundras are too tall for the Scamp if stock.
    Hbjeff and landphil like this.
  15. Jun 13, 2021 at 8:19 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  16. Jun 13, 2021 at 9:43 AM
    slider hitch
  17. Jun 13, 2021 at 9:47 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Go with a 3/4 or 1 ton forsure if towing a 5th wheel weighing 10k lbs
    GODZILLA likes this.
  18. Jun 13, 2021 at 9:58 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Interested in reading the review. We can get a 1 ton LT Chevy for around the same price as decent trim tundra
  19. Jun 13, 2021 at 10:13 AM
    Xspurt
    Xspurt New Member
    Unless you want to be featured on THIS site, go for the 3/4 or 1 ton.
  20. Jun 13, 2021 at 12:23 PM
    Lake.Life24
    Shawn
    Upstate, NY
    Yup I got it for around the same price as a SR5 crewmax. I will probably post it tonight or tomorrow. And it’s nothing against the tundra. But HD trucks are in a different class which I didn’t realize until I got to tow with it
    DaBoro54[QUOTED] and ColoradoTJ like this.
  21. Jun 20, 2021 at 11:32 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    to get close to what you would want you would need a double cab (since family , not large crew max) with a 8ft work bed ( 8ft only available in DC an RC not in CM) also 2wd to maximize your towing/hauling weight potential. honestly you would be better off for 3/4 or 1 ton especially a dually would be ideal thing for the weight you want to haul plus live stock towing issues (weight shifting)
