Tundra dont see a trailer ?
Discussion in 'Towing & Hauling' started by AlexOd, Aug 28, 2025.
  1. Aug 28, 2025 at 2:27 PM
    AlexOd
    AlexOd [OP] New Member
    Hi guys
    I own a 18' TRD OF, CrewMax.
    I owned this since 2020, first time ever I was towing a trailer. Never towed in my life.
    So I went to Uhaul and hooked a transport trailer to get my dad's Ford Taurus 14', when I hooked the trailer , my Tundra was displayed- No Trailer.
    But my lights was working - brakes and turn signals.
    Anyway , any suggestion why it won't recognized the trailer ?
    Again, lights was working on trailer...its just weird..
  2. Aug 28, 2025 at 2:32 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    There was a dealer update to the integrated brake controller in 2018 because it was having a ton of issues. Maybe you don't have it?
  3. Aug 28, 2025 at 2:34 PM
    AlexOd
    Thank you very much.
    Btw they connected a 4 pin connector .. some say it can be issue...
  4. Aug 28, 2025 at 2:35 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Most Uhauls don't have electric brakes I thought, they are surge brakes where the trailer pushing into the truck mechanically engages the trailer brakes. I would assume that's why the truck might not see the trailer since it was only a plug for the lights.
    sbxx312 likes this.
  5. Aug 28, 2025 at 2:37 PM
    snivilous
    SW UT
    If it was a 4 pin plug that goes with my above post, 4 pins are only for lighting. The brakes may have felt bad but that's because the uhaul needs to lean into the truck to get the brakes to engage. If you had slammed on the brakes it would stop well enough, though keep in mind with any trailer your braking distance is longer since the truck has a lot more weight to slow down even with trailer brakes helping.
    sbxx312 likes this.
  6. Aug 28, 2025 at 2:42 PM
    AlexOd
    I tried, press manualy brakes controller, but still no response from trailer. It was moving like a train..
    Does adapter 7 pin to 4 pin wuld work ?
    And shuld a stop at dealer to get firmware update just in case ?
  7. Aug 28, 2025 at 2:57 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    you won't be able to use electronic trailer brakes if you're hooking a trailer up with a 4 pin connector, has to be a 7 pin (adaptors will not work for trailer brakes either)
  8. Aug 28, 2025 at 3:02 PM
    Retired...finally
    The 4 pin or flat 4 trailer connector does not control trailer brakes. Period. It has ground, running lights, right stop and left stop. As for the error you're getting, do as advised and check to see if your truck has been updated. My 21 doesn't give any errors when using the flat 4 pulling my boat.
    caboj and AlexOd[OP] like this.
  9. Aug 28, 2025 at 3:09 PM
    AlexOd
    Thank you guys. Will go to dealer and ask them .
  10. Aug 28, 2025 at 3:48 PM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    (T-SB-0036-19)
    This is the TSB number you can research for 7 pin issues and it detecting a trailer.
    Tunrod likes this.
  11. Aug 28, 2025 at 4:11 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Save your money with dealership if you don't tow regularly. You will probably fail on step 1. of TSB as it pertains to electric/electric-over-hydraulic braking systems that are activated through 7 pin connector. Like mentioned above the 4 pin doesn't do anything except lighting and as far as I know any indications or warnings in MIDS.
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10159681-9999.pdf
  12. Aug 28, 2025 at 4:14 PM
    AlexOd
    It just displayed - NO Trailer
    Thank you.
  13. Aug 28, 2025 at 5:10 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Interesting ... I'll have to play with mine next time we tow the ATV'S with the 4 pin. Only way I can conceive a "no trailer " message is if you tried to setup trailer type and brakes through settings plugged into the 4 pin. But I could be wrong.
  14. Aug 28, 2025 at 5:45 PM
    AlexOd
    I tried, but it won't let me. It didn't do anything. Probably because it doesn't see a trailer .
  15. Aug 28, 2025 at 5:56 PM
    40man
    40man New Member
    Not only that, TSBs are only free during the warranty period. Hell, my 2016 Land Cruiser did not come with the towing harness (it was supposed to). Dealer confirmed the factory wire connectors were still on the plugs where the harness was supposed to plug in, and harness was not installed at port. Toyota still would not provide me with one because I was out of warranty. Toyota is definitely not the same company that made me a big Toyota fan.
    Tunrod[QUOTED] likes this.
  16. Aug 28, 2025 at 6:13 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Concur ... and Toyota consumer support is as worthless as tits on a bull hog
  17. Aug 28, 2025 at 7:44 PM
    Dusty4x4
    Dusty4x4 New Member
    My 2019 showed No Trailer the other day. I had not towed for a long time. It did show the little green trailer on the instrument display. But when I was driving and squeezing the trailer brake it displayed No Trailer. I went into the settings and added the size and brake type. That solved my problem.
    AlexOd[OP] likes this.
