Tundra doesnt start in the heat
Discussion in '1st Gen Tundras (2000-2006)' started by Ranger47, Apr 23, 2019.
  1. Apr 23, 2019 at 8:08 AM
    Ranger47
    Ranger47 [OP] New Member
    2001 Toyota Tundra
    Live in Southern Arizona. It gets hot here from time to time. Replaced the charcoal canister with a toyota charcoal canister. Ever since then, anytime the temperature gets above about 90 degrees, the truck wont start in the afternoon. Cranks up fine in the morning, and later in the evening, but getting it to start during the heat of the day or mid afternoon is about a 10 minute process(makes me think vapor lock). I've looked into it a little and have narrowed it down to maybe fuel filter, fuel pump, charcoal canister, or vacuum leak. Any help would be appreciated. Thanks
  2. Apr 23, 2019 at 8:11 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Have you had the battery tested? Heat and batteries don’t mix well...
  3. Apr 23, 2019 at 8:14 AM
    Ranger47
    2001 Toyota Tundra
    Battery has been tested. A new battery was put in about a year ago.
  4. Apr 23, 2019 at 8:54 AM
    15whtrd
    15whtrd Mr. Blonde
    I guess it’s possible that the new charcoal canister is failing. Do you top off when you get fuel or do you just let the pump shut down and call it good enough?
    NewImprovedRon likes this.
  5. Apr 23, 2019 at 10:23 AM
    Ranger47
    2001 Toyota Tundra
    As soon as the pump shuts off I stop. I dont add anything extra
    15whtrd likes this.
  6. Apr 23, 2019 at 10:28 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Have you checked/replaced battery cables? When cables are hot, resistance increases and if there is any corrosion, it could be enough resistance to cause it to not have enough power. I dealt with that issue on my '40 Chrysler when I reused a starter cable on the big block I put in it.
    15whtrd likes this.
  7. Apr 23, 2019 at 10:41 AM
    15whtrd
    15whtrd Mr. Blonde
    So when it doesn’t start in the heat of the day, is it turning over like a champ just no start? Or does it sound sluggish?
  8. Apr 23, 2019 at 12:32 PM
    Ranger47
    2001 Toyota Tundra
    It has a great crank. Sounds like it tries to start but there is no fuel, which leads me to believe its vapor locking or there is a leak somewhere in the fuel system. I will sit there and pump the gas pedal a few times and crank and nothing. After doing this about 4 or 5 times it will sluggishly turnover and then die and then roars to life on the next turn of the key.
  9. Apr 23, 2019 at 12:34 PM
    Ranger47
    2001 Toyota Tundra
    I have not checked the cables at all. Never thought about it because it only does it during the heat of the day during summer. But I would think if it was cables or battery it would happen everytime, not just during the afternoon on hot days
  10. Jul 14, 2020 at 8:37 AM
    realtormarcos
    realtormarcos New Member
    Marcos
    2000 Tundra extended cab 4x4
    Did you ever figure this out?
    I'm having the same issue. In NM (currently about 100 degrees). First start of the day it starts fine. I'll run it around town, if I let it sit for an hour, it will crank over for 3-4 seconds, then have a weak start...and then it runs fine. If I kill it, and start it immediately it starts right up.
    Frustrating. I have a new: fuel pump, filter, fuel pump resistor, and fuel injection pressure damper. Mechanic couldn't replicate the problem...its back a the shop now. Would love to know if you figured it out.
    2000 Tundra 4.7 extended cab 4x4
  11. Jul 14, 2020 at 4:29 PM
    Professional Hand Model
    Hand Protectors
  12. Aug 25, 2021 at 11:02 AM
    c2lewis
    c2lewis New Member
    2001 Toyota tundra limited.
    I am having this same issue in Tennessee during summer months. Anytime 90 or above truck doesn't want to start. Once i get it started if I turn my truck off then back on again immediately it starts fine. But anytime it is left for longer periods " cold start" during summer days it does not want to turn over.
  13. Aug 25, 2021 at 11:32 AM
    shifty` Animals and insects don't do drugs
    As in, you turn the key forward and everything goes dead, or it just doesn't crank? Or it cranks and it doesn't fire? Just curious.
    I wonder if @realtormarcos ever figured this one out.
  14. Aug 25, 2021 at 11:48 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Sounds like a fuel relay issue... I've had similar issues with my 1UZ... summer times are sluggish starts, starts then dies, turns over with no start and stalling.. early mornings were good starts but over time it spread to the mornings as well.. swapped thay relay out, problem solved.
  15. Aug 25, 2021 at 3:55 PM
    c2lewis
    c2lewis New Member
    Cranks good but does not fire. Sometimes cranks for 5 seconds or more before firing. Only does this when the truck has sat and it is very hot outside. Once it starts and say I go inside the store and come back out it starts just fine. Typically it is 90 + degrees when it does this and has sat for 4 to 5 hours. I'm thinking fuel pump. Considering it's the original with 275k miles.
  16. Aug 25, 2021 at 4:14 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    You should be able to check the fuel pressure with a loaner kit from one of the auto stores to rule that out. Actron makes one with the banjo bolt to schrader valve adapter you'll need to tap the fuel rail.
    I'd probably replace the fuel filter before the fuel pump.
  17. Aug 25, 2021 at 4:31 PM
    Could also be the relay or pump. Curious, when it actually fires up, if you jump out right away and smell the exhaust does it smell overly rich?
  18. Jun 7, 2023 at 5:48 PM
    Leadbitten
    Leadbitten New Member
    Phoenix,AZ
    2021 White Tundra Limited 4WD
    It’s a long shot but did you ever figure this out?
  19. Jun 8, 2023 at 5:16 AM
    blackdemon_tt
    Both haven't been seen since about a week after they posted. Never had a similar issue when I lived in Mesa, AZ. I would start in fuses and then relays, see if you have issues there, another issue might be the fuel resistor, or fuel ECU located near the gas tank under the bed.
    Leadbitten[QUOTED] likes this.
  20. Jun 8, 2023 at 6:27 PM
    This is also the 1st gen (2000-2006) subforum, but I see a 2021 linked in your profile. If you're dealing with your 2021, you may not find what you need in this forum, dealing with 15-21 year older trucks...
