Tundra Dad
Discussion in 'New Member Introductions' started by Adamkhan, Apr 19, 2024.
  1. Apr 19, 2024 at 9:36 PM
    Adamkhan
    Adamkhan [OP] New Member
    2011 Tundra
    Hi all, I chose to join this forum because of my sons 2011 Tundra 4x4 with AB60E that I'm having issues with. It had a P2714 code which I replaced the F-Trim solenoid and now has a P0761. It won't shift past 3rd. I used to be able to clear it and get it to shift to 4th but it gotten worse & doesn't improve after clearing. I've changed the filter & flushed the fluid. Even disassembled, cleaned & rinstalled the valve body. I ordered a C solenoid and will replace that along with the output speed sensor. This will be my final attemps as this trans has over 400k. Maybe a TCM. It's flashing the Hi/Lo light sporadically. One thing I noticed that there were only 7 Check balls in the upper valve body & most if the diagrams I've seen have 8 check balls. Anyone else have pics of 7 or 8 in their valve bodies? I have alse removed, cleaned & checked all connectors associated with the transmission & tcm. If the sensors or TCM don't fix it, time for another transmission. Im open to Any tips & tricks to try before throwing in the towel. Thanks in advance.
  2. Apr 20, 2024 at 2:59 AM
    Welcome from NY.
    Adamkhan[OP] likes this.
  3. Apr 20, 2024 at 7:25 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! This is the New Intros forum. Try posting your question in the 2nd Gen forum.
  4. Apr 20, 2024 at 7:28 PM
    Markus
    Markus Hermitic Member
    Mark
    Boring, MO
    2 1794 Tundys 2014 and 2023 AG TRD
    A few
    Welcome from West MO
