Tundra + Airstream: Initial Impressions
Discussion in 'Towing & Hauling' started by robatumd, Sep 1, 2020.
  1. Sep 1, 2020 at 9:08 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    2020 Tundra SR5 CrewMax TRD Sport
    I just got back from my first camping trip with my new Tundra. Since there isn’t a lot of Airstream content on the forum I thought I would share my experience with the group. My hope is to do more camping/towing trips so will share more experiences when I can.
    Trip Details:
    • Approximately 300 mile trip from the DC suburbs to Shenandoah National Park
    • Trip included myself, wife and 2 dogs
    • We camped at the Luray KOA for 3 nights at a full hook-up patio site
    Vehicle Specifics:
    • 2020 Tundra TRD Sport Crewmax, Convenience and Upgrade packages including the 38 gallon fuel tank
    • 2019 Airstream International Signature 25FBQ (25ft, Front Bed Queen). Approx weight: 6,500lbs, 900lb hitch weight
    Accessories:
    Overall Thoughts:
    I would give the Tundra a solid B for the total trip. It handled the weight of the Airstream ok but it definitely needed to do some serious downshifting when hitting even small hills. It also squatted a full 2” in the rear when hitching the trailer. I don’t have previous experience with this but it did feel like it impacted the steering feel. I know changing the rear suspension could help but I would rather keep the vehicle as OEM as possible.
    The factory electric brake controller worked well and I love that the truck recognizes the trailer when you plug in the 7-pin. I started with a 5 on the brake pressure but moved to a 4 after the trailer tires squealed upon the first brake application at a 5.
    I wasn’t able to stop at a Cat Scale but I’m pretty sure we were over payload on this trip which is disappointing. When I ordered the Tundra Toyota’s website quoted ~1,500lbs payload for the truck but that was before any packages or accessories so the sticker on my truck has a payload of only ~1,200lbs. When you add a 900lb hitch weight + humans + dogs + 100lbs of gear we were over by ~300lbs. Add my ARE topper/cap and we’re now ~500lbs over payload. I guess that’s where the Brodozers in 3/4 ton diesels win arguments.
    We averaged 12 mpg on this trip which I was pretty happy with considering the hilly roads we took to get to the campground.
    CavGirl21, Jtundra81, Beesta and 34 others like this.
  2. Sep 1, 2020 at 9:16 AM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Nice setup!! And beautiful view. A weight distribution hitch will level the truck out to fix the squat, and make the steering feel more planted
  3. Sep 1, 2020 at 9:19 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Nice!
    Did you drop the transmission into S-4 when you encountered hills?
  4. Sep 1, 2020 at 9:22 AM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    What a gorgeous setup.
    twistedcricket and Rex Kramer like this.
  5. Sep 1, 2020 at 9:24 AM
    GreatBigAbyss
    GreatBigAbyss New Member
    2018 Tundra CrewMAX SR5 TRD Off-Road
    What a gorgeous combo. And Airstream is a lifegoal, for sure. They're beautiful trailers.
  6. Sep 1, 2020 at 9:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    you got 12mpg while towing?????
    robatumd[OP] likes this.
  7. Sep 1, 2020 at 9:40 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    We did use an Equalizer 6,000 lb WDH and still had a 2” squat. Could be the TRD Sport shocks aren’t setup as well for towing as other models.
    Medic343 likes this.
  8. Sep 1, 2020 at 9:52 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I was thinking the same thing. I only get 7-8 mpg when towing.
  9. Sep 1, 2020 at 9:53 AM
    TheBlackPearl
    La Gulf Coast
    Downhill both ways?
    Lake.Life24 and Armstrs like this.
  10. Sep 1, 2020 at 10:07 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    The 12mpg was the total weekend MPG. It includes 300 miles of towing and ~100 miles of driving.
    I did drive max 65mph while towing so not sure how fast others go.
  11. Sep 1, 2020 at 10:09 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Or it could be the 500lbs over payload :D
  12. Sep 1, 2020 at 10:18 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    In my experience, the squat is normal, hence the factory rake. I have the same squat but my WDH puts 80ish percent of the weight back on the front axle that the trailer takes off without the weight bars attached. I'm planning to put airbags on the truck not to "raise" the rear but to help stabilize the rear end over expansion joints and dips in the road at speed. I'll probably only have 20ish PSI in the bags but should help plant the rear more. Nothing wrong with downshifting for hills....gas motors make more torque and power in the upper RPM range...at least ours do. I use tow haul and s4 or s3 when pulling hills to keep it in the 4,000rpm range and just pulls right up, no big deal.
    tlakeTundra, Skey44 and Rex Kramer like this.
  13. Sep 1, 2020 at 10:18 AM
    timsp8
    NY
    900 lb hitch weight is pretty high. Not just what was in the truck, but anything you added to the trailer in front of the axle increased that number. You could’ve easily been more than 500 lb over payload. Were the tanks full?
    Cpl_Punishment likes this.
  14. Sep 1, 2020 at 11:02 AM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    There are lots of options to help with the sag. All will effect your daily ride. Toyota makes these things ride cushy spring rate wise to have a soft factory ride. As soon as you use it as a truck, you wish it was firmer.
    Beautiful camper and campsite by the way!
  15. Sep 1, 2020 at 11:09 AM
    robatumd
    robatumd [OP] A_B_C
    Rob
    I estimated the hitch weight at 900lbs. The factory manual states 791lbs for this model but I accounted for the fresh water at 20% full and the gear/food we had in the unit.
    Good to note in the S3 or S4 transmission settings. I left it in D (tow/haul mode) the entire time. It was in the 4K rpm range often when hitting the hills. I was ‘this’ close to adding in the factory TRD exhaust but after this trip I’m glad I didn’t.
    Txexplorer23 and Skey44 like this.
  16. Sep 1, 2020 at 11:32 AM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    2017 Silver CrewMax 5.7L 4x4
    Amp research power steps OEM tow mirrors OEM tonneau cover TRD Sway Bar Black Texas Lone Star plates :) Auto tail gate lock KB Voodoo 22” aluminum bed rack TRD Pro headlights Katzkin seats Black badges
    Hey I just did 2000 miles to Colorado and back last week with my 2017 Tundra and Airstream 25FB. I only got 10.6 mpg through the mountains. I was constantly manually down shifting downhill, but thought the truck did ok.
  17. Sep 1, 2020 at 11:40 AM
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Air bags will be your friend. Nice set up.
    Don't forget the weight of the fuel, with a full tank my DS rear drops by 1.5"
    twistedcricket likes this.
  18. Sep 1, 2020 at 11:49 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Beautiful combo you got there! The wife and I talked about wanting to purchase an Airstream, but we have no where to store it so we bought a Porsche Macan instead … lol.
    Someday maybe I'll get that Airstream. I was thinking about the 22FB Caravel or 25FB Flying Cloud. That International has got to be beautiful inside!
    tlakeTundra and Pyrite Tundy like this.
  19. Sep 1, 2020 at 11:53 AM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    Airbags are definitely next on MY wish list. That tongue weight meant I was about 300 pounds over too.
    Oh and I highly recommend the OEM tow mirrors. Those plus the Airstream camera mean zero issues maneuvering through traffic.
    How are you liking your 25FBQ?
  20. Sep 1, 2020 at 12:07 PM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I installed SumoSprings on my truck, and am very happy with them. Towing my boat with the truck box and back seat area full of stuff for our vacation, I only had 1.25 inch of squat. I have the black Sumo's (1500lb) and they provide a excellent loaded ride, although I would say unloaded they do provide a little rougher ride it's not enough to bother me. It's a truck, and I don't mind it riding like a truck, YMMV.
    UNTMatt likes this.
  21. Sep 1, 2020 at 12:13 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    Beautiful rig but definitely over payload.
  22. Sep 1, 2020 at 12:28 PM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    That's a beautiful trailer!!! Any pics of the inside?
    Isn't tongue weight generally targeted to be around 10% of the trailer weight? It seems like perhaps you could shift some weight towards the wheels and gain some margin on your payload.
  23. Sep 1, 2020 at 1:20 PM
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
    Beautiful Airstream! I've loved them for a while, and REALLY want one instead of my 2018 Mallard M28. I have airbags and a very good weight distribution hitch, and that makes all the difference in the world. To help with payload, whatever you can throw into the camper, do that. Also, make sure your hitch is setup properly. I have an Android phone and use that to monitor temps when I'm towing as well. Besides that, have fun with it.
  24. Sep 1, 2020 at 1:29 PM
    Armstrs
    Armstrs New Member
    Steven
    East Texas
    ^^^ This. My equalizer hitch was not setup correctly by the dealer. The ball was over an inch lower than the trailer hitch (when trailer is level) and the trailer was not level when hooked up. Got it adjusted and the trailer is level and the truck squat is reduced. And yeah, spread the weight around by throwing some of the truck gear in the trailer preferably above the wheels.
  25. Sep 1, 2020 at 1:50 PM
    robatumd
    robatumd [OP] A_B_C
    Rob
    Good tips on moving the gear. We had minimal stuff in the truck bed. 2 camp chairs, 10lbs dog food, small dog kennel.
  26. Sep 1, 2020 at 1:51 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Also wanted to say your hitch "looks" setup right because your rig is fully level. I have the K Source mirrors and I like them....but they only help to see around the back corner of the trailer. I have a camera setup on the rear of my camper now for when I double tow to monitor the ATV
  27. Sep 1, 2020 at 1:56 PM
    Spindifferent
    Spindifferent New Member
    This will tell you the actual tongue weight: https://www.etrailer.com/Tools/Sherline/5780.html
  28. Sep 1, 2020 at 2:00 PM
    Cement4WD
    Cement4WD New Member
    Cement TRD Off Road 4x4
    I installed icon add a leafs which add 1.5 inches of lift and when I hooked up my trailer the rear was perfectly level. Just another option besides airbags. I also have the equalizer hitch.
  29. Sep 1, 2020 at 2:35 PM
    CDinSeFl
    CDinSeFl New Member
    That is a beautiful trailer and truck combo!!! :yes:
    You are bringing back some memories and setting up some future plans. In 1976-77 my parents (I was 11-12) purchased a 31' Airstream and had it custom built. We picked it up at the factory in OH. My parents bought a brand-new 1976 Chevrolet Suburban 2500 (454 cu in gas) to tow it. They took my brother and I out of school for a year, shortly after purchase, and we traveled the lower-48 for 12 months. That was a great trip, and one I want to someday repeat and expand upon.
    When I was in college my parents often let my friends and I take trips in the truck and trailer. Great times.
    Like others, I think a weight-distributing hitch is a must when towing a trailer that size/weight or larger. Especially when using a truck that has the suspension of your stock Tundra.
    I hope you keep posting as I am very interested in knowing what changes you make and how it tows after your first trip.
    BTW, how much is a full hook-up site at KOA in/near Shenandoah now? I can't remember, but I'll ask my parents what sites cost back in 1977. Also, do hook-ups now include cable TV and internet?
    CavGirl21 likes this.
  30. Sep 1, 2020 at 6:07 PM
    robatumd
    robatumd [OP] A_B_C
    Rob
    Sounds like an awesome trip you took. Awesome way to see the country.
    We paid ~$90 per night for the premium patio site. They have cheaper sites but this was very nice and worth the extra $ IMO
    CDinSeFl likes this.
