Tundra AC problem
Discussion in '1st Gen Tundras (2000-2006)' started by Pcase28, Jul 15, 2022.
  1. Jul 15, 2022 at 10:29 AM
    Pcase28
    Pcase28 [OP] New Member
    I have a 2005 tundra that the AC was working fine when the truck was shut off and did not come back on when restarted the fan switch won’t run the fan and the AC switch does not have power. Any ideas what might be wrong.
  2. Jul 15, 2022 at 12:23 PM
    shifty` All my rowdy friends have settled down
    Are all harnesses firmly seated on the back of the climate controls?
    Are all in-dash fuses good?
    Are all under-hood fuse/relays good?
  3. Jul 15, 2022 at 1:36 PM
    Pcase28
    I have checked all of the fuses in the cab and under the hood and they are good I have not checked any relay’s yet. I’m not sure which relay to check nothing marked AC.
  4. Jul 15, 2022 at 2:36 PM
    I don't remember if there is a relay used under the hood. There have been other threads which touched on the wiring side of things posted very, very recently but I'm too lazy to dig those up.
  5. Jul 15, 2022 at 3:56 PM
    Pcase28
    Thank you for the info. I think at this point I will give in and take it to the shop.
