Tundra 4.6l cold air intake causing hesitation?
Discussion in 'Performance and Tuning' started by YOTA2015, Mar 30, 2016.
  1. Mar 30, 2016 at 9:57 AM
    YOTA2015
    YOTA2015 [OP] New Member
    Tyler
    2015 tundra sr double cab 2wd
    Stock
    I have a 2015 tundra double cab 4.6 I had a k&n cold air installed and it seems to bogg and hesitate in slow conditions anyone out there know about these thanks
  2. Mar 30, 2016 at 10:14 AM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    That's because you loose low end power and torque with pretty much every CAI. That's why you never see the full dyno charts from K&N. They only show the charts in higher RPM ranges.
    NewImprovedRon likes this.
  3. Mar 30, 2016 at 11:44 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 Mall Crawler Extordinare
    All Pro Long Travel with Walker Evan Coil Overs, All Pro Expedition Leaves with Walker Evan Resi Shocks, All Pro IFS, transmission and E-Locker skid plates/guards, ARB Bumper with Kragen LED flood lights, 10,000lb SuperWinch, All Pro Rear Bumper, All Pro Sliders, Custom RTT Rack with Roto Pack, ARB Simpson RTT, Bed Tray. 285x75R16 Mickey Thompson MTZs and 285x75R16 Yokohama Geolander it g072. Airaid Short ram intake, Intake manifold spacer, Borla Cat back Exhaust.
    Check to make sure all your hoses are clamped down and nothing is loose or disconnected. Vacuum leaks will bog you down.
  4. Mar 30, 2016 at 1:26 PM
    YOTA2015
    Tyler
    Stock
    Ok thanks for all the info it's much appreciated
    Krazie Sj likes this.
  5. Jul 10, 2016 at 3:20 PM
    linda
    linda New Member
    linda
    2016 tundra dc
    suga top
    no matter what you do a 4.6 is a slow dog
    Black Wolf likes this.
  6. Jul 10, 2016 at 11:10 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    First post... Dayum, Linda!
    Harris1881 and BlueFalconActual like this.
  7. Jul 11, 2016 at 6:54 AM
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    I have a 5.7 with the k&n intake and had the same issue. Wish I hadn't wasted my money. Even with the unichip and cat back exhaust, I still can tell there isn't as much low end torque. Will likely go back to the stock intake box.
  8. Jul 11, 2016 at 7:30 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have the TRD intake and have no such issues. I do not feel any low end torque loss (according to my butt-o-meter, haha).
    Actually, 4.6 is what convinced me to get a Tundra instead of Tacoma. Then reading through various forum pushed me toward 5.7. I think 4.6 is a pretty powerful engine as long as you don't go too high and big.
  9. Jul 18, 2016 at 4:58 PM
    Clarker2000
    Clarker2000 New Member
    2012 Tundra TRD Reg Cab
    3" lift. 35's.
    I just had my k & n put in this past week and I do have the same issue. My truck rocks off the line at full throttle like a beast. But when it's reached max rpm and shifts the truck Boggs down almost to the point of near zero power. I had to let off severely to get it to react. It's extremely bad. I haven't checked all the lines for tightness but will do ASAP. I also added a dual flow master system today and still same issue. I have had numerous k & n products on others cars and none acted like this.
  10. Jul 18, 2016 at 5:00 PM
    ^^^ Calibrate your speedo. Thats due to the bigger tire size.
  11. Jul 18, 2016 at 6:35 PM
    This all comes back to upgrading to an after market CAI even though our Tundras com with a true CAI. I used a K&N drop in and called it day.
