TUNDRA 3/2 ReadyLIFT (wheels & tires)
Discussion in 'Wheels & Tires' started by @TUNDRACRUZ, Sep 15, 2021.
  1. Sep 15, 2021 at 6:41 AM
    @TUNDRACRUZ
    @TUNDRACRUZ [OP] New Member
    2019 Tundra TRD off-road
    3/2 ReadyLIFT
    I have a 2019 Tundra TRD OFF-ROAD 4x4 with a 3/2 ReadyLIFT. I have sock wheels and tires (275 65 R18 +60 offset). I was rubbing on the skid plate at full lock. I trimmed the skid plate and painted it and have no more rubbing. But I noticed at full lock I’m like 2in away from the from the front stock sway bar. (If I get an 18x9 +12 offset and 275 70 R18mt will I have any rubbing???? PLEASE HELP)
  2. Sep 15, 2021 at 7:04 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    275/70/18 fit on stock wheels on a stock truck, no issues. They may look small however with 3 inch lift.
    The wheel offset of +12 could cause rubbing. Stock wheels are +60. Wheels in the range of +20 to +60 will cause less clearance issues.
    Check out the wheel/tire and suspension forum here to lots of info on different setups with pics.
    splitfuse and @TUNDRACRUZ[OP] like this.
  3. Sep 15, 2021 at 7:47 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    What about 3/2 ReadyLIFT with the stock wheels and 275 70 r18 mt ?
  4. Sep 15, 2021 at 7:52 AM
    frichco228
    would work fine, but again, you can run that size on a stock truck with no rubbing or issues, so if that is the tire you want to run, a lift is not needed.
  5. Sep 15, 2021 at 8:01 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Lol I already have the 3/2 ReadyLIFT. And the only reason I’m concerned is because after the lift I had rubbing on the skid plate at full lock. I cut the skid plate and have no more rubbing. I’m just worried about the front sway bar.
  6. Sep 15, 2021 at 8:03 AM
    frichco228
    Should not be an issue. Stock rims have more positive offset, so when lifted they can rub the skid.
  7. Sep 15, 2021 at 9:29 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Alrighty thanks for you help
  8. Sep 15, 2021 at 10:52 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    I really hope so. Thanks for the response.
  9. Sep 20, 2021 at 6:04 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    Thanks for the help. I will look those wheels up now.
  10. Sep 20, 2021 at 6:06 AM
    @TUNDRACRUZ
    3/2 ReadyLIFT
    I just looked up ray10 wheel and got all kinds of brands. What offset are they?
  11. Sep 29, 2021 at 5:53 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
