Tundra 2018 front wheel alignment
Discussion in 'New Member Introductions' started by juan40tundra, Jul 21, 2021.
  1. Jul 21, 2021 at 10:31 AM
    juan40tundra
    juan40tundra [OP] New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    Got my Tundra last year in April, used model 2018 with 26k miles on it, 4wd factory tires. Dealership installed new set of tires and performed the alignment which was part of the deal. Back in August last year had to bring it back to the dealership to re-do the alignment. It seems like the alignment is off again and the tires are getting worn out on the outside and it is making the same vibration between 64 to 70 miles per Hour. This vibration was originally there when I bought the truck, but after taking it back to the dealership, they cut the rotors, and proceed with alignment and that seems to make the vibration disappear. Is there anything that I should be looking for them check if I take it back for alignment.
    YardBird and RdKing like this.
  2. Jul 21, 2021 at 10:56 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware @juan40tundra
    My 2019 with the factory Bridgestone tires has a wobble at lower speeds & at 25k on the clock rotating them myself faithfully every 5k they have the same outside tread wear.
    Just like my 2016 Tacoma, when I replaced the tires with Michelins after the originals wore out.
    Bump the pressure up about 2 lbs and drive it.
    juan40tundra[OP] and YardBird like this.
  3. Jul 21, 2021 at 11:04 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Jul 21, 2021 at 11:21 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Get the print out, we don’t know what they do to it, they could do a half ass job and only did a toe set.
    RdKing likes this.
  5. Jul 21, 2021 at 1:45 PM
    juan40tundra
    Juan
    none
    thank you all for the response. RdKing, I will add some extra air and see what happens.
    Winning, I am with you. Dealerships always try todo their minimum to cut cost
  6. Jul 21, 2021 at 1:46 PM
    juan40tundra
    Juan
    none
    Thank you
    YardBird[QUOTED] likes this.
  7. Jul 21, 2021 at 2:57 PM
    Welcome from NY.
  8. Jul 21, 2021 at 4:14 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  9. Jul 22, 2021 at 4:07 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  10. Jul 22, 2021 at 5:15 AM
    juan40tundra
    Juan
    none
    thank you
  11. Aug 17, 2021 at 10:31 AM
    juan40tundra
    Juan
    none
    I did get the alignment done, only the right tire was off by not much. But it seems to be doing the same again. Someone recommended to get a whole new set of tires., should I go with bigger tires? maybe a 285 instead of 275 original equipt with
