Tundra 2018 4wd Left Front Axle
Discussion in 'General Tundra Discussion' started by juan40tundra, May 28, 2025.
  1. May 28, 2025 at 10:54 AM
    juan40tundra
    juan40tundra [OP] New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    Friends
    I am back again.
    Going to replace front bearing (Left side) with ECGS bushing, however, also thinking about replacing the axle. Any recommendations for a good off brand close in quality to OEM. Right axle was replaced by Toyota few months back
    Should I stay with OEM for the left side as well?
    How detrimental is to have an off brand
    Thank you in advance.
  2. May 28, 2025 at 11:02 AM
    AZBoatHauler
    So.Arizona
    I'd stick OEM. Both sides are the same - there is no right or left.
    2mchfun likes this.
  3. May 28, 2025 at 11:16 AM
    juan40tundra
    Juan
    none
    thank you
    2mchfun likes this.
  4. May 28, 2025 at 11:27 AM
    blenton
    blenton New Member
    Another vote for OEM. Get new boots and repack with grease if you would like to dig in to them as long as everything else is good.
    The ECGS bushing is a good way to go; it takes more work to get the front axle out than it does to swap the bushing. Super simple.
    2mchfun likes this.
  5. May 28, 2025 at 11:37 AM
    2mchfun
    If you can't get or rebuild OEM, Napa has decent axle reputation.
    blenton likes this.
  6. May 28, 2025 at 12:22 PM
    juan40tundra
    Juan
    none
    even that I have a brand new OEM on the right side? will that be ok?
  7. May 28, 2025 at 12:24 PM
    juan40tundra
    Juan
    none
    Man, I heard so many bad stories about repacking those axles, that simply makes me want to break into the piggy and purchase new axles, my debate is whether go with OEM or aftermarket
  8. May 28, 2025 at 12:25 PM
    juan40tundra
    Juan
    none
    Besides NAPA, who else is second or first best on aftermarket
  9. May 28, 2025 at 2:05 PM
    AZBoatHauler
    So.Arizona
    2mchfun likes this.
  10. May 28, 2025 at 2:21 PM
    juan40tundra
    Juan
    none
    2mchfun likes this.
  11. May 28, 2025 at 7:43 PM
    2mchfun
    You can most likely rebuild what you have. Check out carcare nut channel on YT. He's got a no nonsense video library at your fingertips. Just buy grease, boots, and clamps. Maybe a tool to clamp if you don't have one. The screw type clamp tool is pricey but worth every penny. Let me know if you need help finding one.
  12. May 28, 2025 at 7:44 PM
    2mchfun
    Yes, fine
  13. May 29, 2025 at 5:15 AM
    2mchfun
  14. May 29, 2025 at 5:17 AM
    2mchfun
  15. May 29, 2025 at 5:46 AM
    2mchfun
    Maybe not the ideal video, but it does detail several steps. Just pull out the whole axle, rebuild, and engage the 4x4 when you go to put it back into the differential, this will keep the female spline from spinning around. Also line up the clip with the opening down so gravity will not make it droop excessively as you insert the male axle spline into the female diff spline. Many folks find themselves fighting it because that clip droops quite a bit with the opening facing up.
  16. May 29, 2025 at 3:46 PM
    panterahead79
    panterahead79 New Member
    2004 tundra sr5 dual cab 4x4
    @2mchfun Been there done that for sure on my old civic spent an hour trying to beat that damm cv axle back in and magically it went right in with a tap when clip was in the correct position.
    2mchfun likes this.
  17. Jun 2, 2025 at 8:46 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    CVJ is another option, he does factory remans.
