Tundra 2007+ Coachbuilder Steering kits
Discussion in 'Ekstrom Design' started by Coachbuilder1, Jul 3, 2015.
  1. Jul 3, 2015 at 11:35 AM
    Coachbuilder1
    Coachbuilder1 [OP] Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    We have come up with a very heavy duty outer tie rod replacement kit. This kit is offered in 3 sizes and will cover the following applications. All applications mount to the top of the spindle except when using factory OE spindles.
    Factory OE Replacement with OE spindles including TRD PRO.(Bottom Mount)
    Coachbuilder OE Replacement Steering Kit, Tundra 2007-2021 Including T – Shop Coachbuilder
    Long Travel Kits ( Total Chaos +2.50", Camburg +2.50"
    Coachbuilder Long Travel Replacement Steering Kit - +2.50" - Tundra 20 – Shop Coachbuilder
    Dirt King +3.154" ( Bottom Mount )
    CST & Maxtrac 2wd spindles ( Top Mount )
    BDS , ZONE & Procomp lifts. (Top Mount )
    Coachbuilder Steering Kit BDS 4.5"-7" ProComp 6"-7" Zone 5" – Shop Coachbuilder
    Bulletproof 6"-8" & 10"-12" lifts ( Top Mount )
    Coachbuilder Steering kit ( BulletProof 6"-8" & 10"-12" ) Tundra 2007+ – Shop Coachbuilder
    All Kits are fully Rebuildable
    Coachbuilder Steering kit ( Rebuild kit 1 Unit ) – Shop Coachbuilder
    Please feel free to Call or Email with questions.
    David
    Ekstrom Design
    801.635.4872
    ekstrom_design@yahoo.com
    www.shopcoachbuilder.com
  2. Feb 12, 2016 at 7:17 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Do you have a pic with a comparison between the stock and these?
    DVYota likes this.
  3. May 23, 2017 at 9:56 AM
    TheBeast The Beach
    would it be a good choice to replace OEM ones with those ones when lifting truck 2.5 -3" with coilovers or is it overkill ?
    papasmurf likes this.
  4. May 23, 2017 at 10:54 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    it will help for sure. allowing the tie rod to travel more and let the suspension move . I had a set of these for my BDS kit and now i have another set for my new suspension setup and let me tell you they are awesome and David is awesome to work with, you will not be disappointed
    @Coachbuilder1
    Coachbuilder1[OP] likes this.
  5. May 23, 2017 at 10:55 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    @Coachbuilder1 you forgot to list the ones for Total Chaos and Camburg Long travel as well. He makes those too! :)
  6. May 23, 2017 at 11:14 AM
    Coachbuilder1
    David
    Salt Lake City UT
    We normally take the type of suspension being used into consideration and not just the amount of lift. if you're using a high quality coilover, (Fox,King,Icon,ADS) and or using a UCA you will notice the steering being hung up by the lack of travel. The outer tie rod is the smallest joint and really feels the pull quick. Our Coachbuilder steering kit provides just over 27 degrees of travel compared to 19 degrees from the factory rod ends.
  7. May 23, 2017 at 11:23 AM
    TheBeast The Beach
    @Coachbuilder1 yes Kings COilovers and TC UCAs. which model do you recommend for the tie rods ?
  8. May 23, 2017 at 11:27 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    you will run the stock replacement version... you will notice a nice gain in steering feel and move travel as you will not get hung up on the tie rod end
  9. May 23, 2017 at 11:29 AM
    TheBeast The Beach
    sweet...:burnrubber::mudding:
  10. May 23, 2017 at 8:31 PM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
  11. May 23, 2017 at 8:41 PM
    Tundra4us
    Tundra4us New Member
    "D"
    Hey Papasmurf, did these tie rod ends help get you more clearence at full lock on your coil overs of the BDS lift kit?
  12. May 23, 2017 at 9:21 PM
    TheBeast The Beach
  13. May 23, 2017 at 9:39 PM
    Porschetech29
    Francis
    It's an easy swap but make sure to perform an alignment to correct the toe.
    TheBeast[QUOTED] likes this.
  14. May 23, 2017 at 10:00 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    They do the exact opposite. These will rub on your coilovers and chip away at the paint. Mine have been doing that since day one but I don't really care for it. There's some surface rust in the spots where the paint chipped.
  15. May 24, 2017 at 4:16 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    no flats out?
    pics?
    Troysbama likes this.
  16. May 24, 2017 at 1:18 PM
    Porschetech29
    Francis
  17. May 24, 2017 at 2:27 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I wanted my tierods a little bit longer than the BDS set. I sent David my alignment sheet and he was able to give me what I wanted. Waiting to install at the same time as my coilovers.
  18. May 24, 2017 at 6:48 PM
    R0CKETMAN
    NGAMTNS
    Gotcha. I have mine fore and aft in order to see the coachbuilder logos
  19. May 24, 2017 at 6:55 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I may have to get some of these when I get my UCA's
    Coachbuilder1[OP] and TheBeast like this.
  20. May 24, 2017 at 7:32 PM
    Tundra4us
    "D"
    Thanks Spvrtan, Thats the most disappointing to me and the BDS lift. Its like they did not do a lot of R&D on this. My install shop added the spacers to the steering stops that came with the kit AND had to build up more to preventing it from hitting. This just makes the turning radius even worse!
  21. May 25, 2017 at 11:25 AM
    Coachbuilder1
    David
    Salt Lake City UT
    Our adapter tubes are a touch larger diameter than the BDS outers and can make contact just as you're describing. Usually if you back off on the castor it increases clearance between the two parts.
  22. Aug 10, 2017 at 12:32 AM
    Payaso 9394
    Payaso 9394 New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    Would I need these for my lift I feel it stretches a good amount when steering I'm running maxtrac spindles with icon coilovers. Just not sure if I would need them or if they would work on my lift
  23. Aug 11, 2017 at 1:57 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Thanks for the PM, replied.
  24. Apr 27, 2018 at 7:37 AM
    dongkatsu
    dongkatsu New Member
    Dong
    2017 Black Tundra Platinum
    7" bds gone due to issues and switched out the kit to Readylift 6" and up to 7"
    does this help with crappy bds lift kit with outside wear on the front tires?
  25. Apr 27, 2018 at 1:47 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Yes, This problem is extremely common with the BDS lift. Our Coachbuilder steering kit increases travel in the toe and will allow full cycle both up and down without fluctuating. Your cost is $399 and will include everything needed for installation. The second pic shows our rubber boot kit, all of our steering kits use the boot.
    What wheel size and offset are you running? we just need to be sure we have enough clearance above and around the BDS tie rod.
    Thanks!
    David
    Deaner and Kiddnapped Tundra like this.
  26. Apr 27, 2018 at 2:27 PM
    dongkatsu
    Dong
    Thanks DAVE!!! this is dong. I had a long chat with you about an hour ago. Again thanks so much and lets see what Darren has to say about this. I will send you pictures of the tires that I just took few minutes ago.
    Have a good weekend!!!!!!!!
  27. Apr 30, 2018 at 8:40 AM
    fishmando
    fishmando New Member
    Awesome thread! I'm about to get some of these.
  28. Jan 20, 2019 at 11:55 AM
    lostsamurai
    lostsamurai New Member
    jimmy
    2013 tundra DC
    5" zone lift, Bilstein 5100s mid setting, 4" skyjacker leafs 2" shackles, 20x12 rims, 35x12.5 tires
    hello I'm having issues with my new pro comp 6" coilovers hitting my outer tierods from my zone lift kit. (5") it seems I would need to something like the stock tierods. as in looks with the curved tierod
    so they don't hit. help please. would appreciate it
    Jcabanit75 likes this.
  29. Jan 21, 2019 at 11:27 AM
    Tundra4us
    "D"
    I had the same issue with my BDS 4.5" set up. I was frustrated that the tie rods where hitting my coilovers at full lock even after the shim was added to limit them from hitting. After looking at all kinds of lift kits done on Tundras, I had seen that Pro Comp is the only one that had addressed this issue with their outer tie rods by making them with the " off set/dog leg" needed to give the clearance! Get them from 4WP, cost is 90.99. Here is the part#, 90-40231B, Boxed Tie Rod Ends. Hope this helps you, as it did with me!
  30. Jan 26, 2019 at 12:44 PM
    Coachbuilder1
    David
    Salt Lake City UT
    Thanks for following up. the PC coilovers def use a lower perch and can cause some clearance issues. In most cases we can pull the caster down a touch and this will open up clearance. Do you have a recent alignment print out we can go over? Feel free to call in too if it helps. 801-635-4872 David
    831Tun likes this.
