Tundra 06 Limited 4WD--Ignition Switch question
Discussion in '1st Gen Tundras (2000-2006)' started by Cartour2020, Feb 5, 2021.
  1. Feb 5, 2021 at 8:56 AM
    Cartour2020
    Cartour2020 [OP] New Member
    Charles
    Hello everyone, question for you: I am about to install an auxiliary battery Relay, the Blue Sea ML-ACR 7622 to be specific; the instructions call for the brown wire from the harness coming from the Relay to be hooked up at the start key switch or at the starter solenoid, BUT it must be connected to the wire that's hot (positive) ONLY when cranking the engine. Has anyone done this mod before? if so a little direction/help will be appreciated. If I can get away with doing the research it'll be great. thanks guys!!!
