Tuff country 4.5 inch lift
Discussion in 'Suspension' started by Phillipk98, Jul 23, 2017.
  1. Jul 23, 2017 at 6:19 PM
    Phillipk98
    Phillipk98 [OP] 05 sequoia
    2005 sr5 sequoia
    Tuff country seems to make a decent 4.5" lift kit. Does anyone know about it?
    Did you have to get new UCA's?
    Says must have 4.75" backspacing, I have stock 17"s with 5" backspacing (I think) think those Wil work?
  2. Jul 23, 2017 at 7:27 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You'd most likely need new UCA's.
    Good rule 3" or above needs UCA's.
    Backslider likes this.
  3. Jul 24, 2017 at 6:46 PM
    Phillipk98
    2005 sr5 sequoia
    Yeah that's what I thought too. I don't know maybe they have some kind of magic kit that let's you run stock lol. I'll more than like contact them before purchase.
  4. Jul 24, 2017 at 6:55 PM
    Phillipk98
    2005 sr5 sequoia
    Sure let me find it
  5. Jul 24, 2017 at 6:58 PM
    Phillipk98
    2005 sr5 sequoia
  6. Jul 24, 2017 at 7:06 PM
    TheBeast The Beach
    looks good on a gen 1 for sure.
  7. Jul 24, 2017 at 7:48 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Yep you'll most likely need new UCA's. Only way you'll be able to run stockies is with a taller knuckle. Problem with that is you'll need new wheels with the proper back spacing to fit.
    You'll have to pony up one way or the other.
  8. Jul 26, 2017 at 6:24 AM
    Phillipk98
    2005 sr5 sequoia
    Yeah I figured as much
  9. Jul 26, 2017 at 6:41 AM
    Phillipk98
    2005 sr5 sequoia
    But wait there is more! Lol I kept going over the kit and it includes upper ball joint spacers. I Googled them. Makes sense now. Part quality seems iffy.
  10. Jul 26, 2017 at 6:46 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That def looks sketchy. Do they have an option in the kit to provide longer spindles?
  11. Jul 26, 2017 at 6:54 AM
    Phillipk98
    2005 sr5 sequoia
    Not sure but that pic on Google takes you to a whole forum on this site about spindle spacers. Bump steer is explained well in there as well.
  12. Jul 26, 2017 at 6:58 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I would look into longer spindles. Usually larger lift applications like RC and Pro Comp come with these. Your truck is only as strong as your weakest link.
    Law323 likes this.
  13. Jul 26, 2017 at 7:03 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    yo! that looks like trouble waiting to happen!!
    boardude likes this.
  14. Jul 26, 2017 at 7:15 AM
    Phillipk98
    2005 sr5 sequoia
    Yeah thats what I'm reading. For 800 bucks more they offer a 5" lift with extend spindles. $1770.00
  15. Jul 26, 2017 at 8:16 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    There you go. Don't quote me on this but I THINK that the longer spindles will correct the angles of the UCAs when lifting so you could use the stock UCAs. The uppers will run you around 600 - 800 so if I'm not lying its a no brainer.
  16. Jul 26, 2017 at 8:49 AM
    Phillipk98
    2005 sr5 sequoia
    Yes sir! All of that is true.
  17. Jul 26, 2017 at 9:14 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Oh for Christs Sake...
  18. Jul 26, 2017 at 9:15 AM
    joem1cha3l
    Albany, NY
    Buy a Toyota and make it as reliable as a Suzuki....I'll never understand it
  19. Jul 26, 2017 at 9:27 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    :rofl::rofl::rofl::rofl:
  20. Jul 26, 2017 at 10:52 AM
    Phillipk98
    2005 sr5 sequoia
    Negative sir. That's why I am inquiring about certain. Parts. I'm a big fan of doing it right the first time.
  21. Jul 26, 2017 at 11:17 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Not sure if you're dead set on 4.5" of lift but personally I would steer away from any spacer lift. Here are a couple other options comparable in price that I would go with. These will make your truck look great and increase ride quality. Your truck will ride stiffer with the tuff country
    Boss Kit
    http://toyteclifts.3dcartstores.com/BOSS-Suspension-System-for-2000-2006-Tundra_p_1140.html
    Icons
    http://iconvehicledynamics.com/shop...-toyota-tundra-suspension-system-stage-2.html
  22. Jul 26, 2017 at 12:57 PM
    Phillipk98
    2005 sr5 sequoia
    Yeah man I appreciate it. I'm familiar with them. I'm sitting on 5100's all the war around. I'm only on the second notch because I don't have new UCAs and didn't want to go without them. I already want more lift lol. I've just never used a drop bracket lift before.
