tsk tsk tsk sound from RF wheel
Discussion in '2.5 Gen Tundras (2014-2021)' started by FredD, Apr 8, 2019.
  1. Apr 8, 2019 at 8:24 AM
    FredD
    FredD [OP] New Member
    2016 Barcelona Red Ltd
    With the warmer weather (and the windows open), I just noticed a 'tsk tsk tsk' sound coming from my RF wheel (one 'tsk' per wheel revolution). It kind of sounds like something rubbing up against the brake shield, but I don't think that's the actual problem.
    I jacked up the truck and pulled off the wheel, and the wheel hub & rotor turns perfectly, with no noise. With the wheel back on, spinning it in the air, still no noise.
    There are no rocks or other objects in the tire tread.
    So the noise only presents itself with weight on the wheel. Any ideas? I'm going to rotate the tires in a couple days, to see if that makes any difference.
  2. Apr 8, 2019 at 8:35 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    My guess is something in the tire. If not a rock, then a piece of metal embedded in the tread that is not easily seen.
    Good Luck.
  3. Apr 8, 2019 at 8:46 AM
    blizz86
    blizz86 New Member
    Had this issue... turned out my TPMS sensor had a piece of broken plastic inside the tire.
