Trying to use factory seat heat switch on my 2005
Discussion in '1st Gen Tundras (2000-2006)' started by AV8R4AA, Feb 1, 2021.
  1. Feb 1, 2021 at 9:03 AM
    AV8R4AA
    AV8R4AA [OP] New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Hello Guys,
    Doing a mid life crisis overhaul on my beloved Phantom Gray DC.
    I’m really wanting to use the factory heated set switches for this mod.
    My truck didn’t have any factory wiring. So I’m on my own as for that.
    The heated seat kit has a very nice wiring harness. Complete with a detachable
    Low,Off, and High 3 position switch. I’m trying to “wire in” the factory switch into the
    aftermarket kit. They both have exact same functions. Low, Off, and High.
    The kit has 4 wires going to the switch, the factory switch has 6 wires.
    I don’t know what I am doing here. Anyone have and insight?
  2. Feb 1, 2021 at 9:42 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Here's the FSM diagram for the pin outs on the switches.
  3. Feb 1, 2021 at 9:54 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Thank you so much.
    I looked over it and I’m a little less confused.
    I have a few electrical friends that can help me.
  4. Feb 1, 2021 at 10:07 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I realized I didn't attach the second part. Basically coming out of the passenger factory switch use the black/white tracer wire to the high heating element, red/light blue tracer to the low, then ground the seat heater to wherever is convenient. Repeat on the drivers switch but the high there is the light green wire.
    If you're truck didn't come with heated seats see if you can find a wrecked truck and get at least the switches and a 6 inch or so pigtail, that would make it easier.
  5. Feb 1, 2021 at 11:02 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I have a set of factory switches. I have a foot of pigtails on each left and right connector.
    I did the continuity test. Both switches the 1-2 don’t test. I’m thinking that is the background lighting.
    I can live without that. I also tested the low and high bulbs and ops check good.
    So basically I’m using pins 3-4-5-6 only. Is that correct?
  6. Feb 1, 2021 at 11:34 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    Correct. So you'll want the 12v+ output of your relay going to the light blue wire and a ground going to the white/black tracer in the pigtails.
  7. Feb 5, 2021 at 7:48 AM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I got the switches wired up to the kit harness. Tested it with a motorcycle battery.
    Both low, and high functions and lights work. Had the Mrs. sit in the heat pads to confirm
    Proper operation. She has some light charring and a wavy tattoo. Pictures coming soon.
  8. Feb 7, 2021 at 8:36 PM
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    I'm going to be wiring mine up this coming week and dont have the factory wiring in my DC either. I got some factory switches with a little bit of pigtail and I'd LOVE if you could share the wiring with me either here or by PM. Thanks!
  9. Feb 7, 2021 at 8:50 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    Get the kit you are going to use. Once you get that, and lay it out, it seems much less scary.
    Since you don’t have any factory wiring, you just use the wiring from the kit.
    MAKE SURE your choice of seat heaters have 3 positions ONLY.
    LOW, OFF, and High. Also I didn’t know how to wire up the background lighting
    of the switch. You WILL get the low and High Factory switch illumination light.
    Overall I’m very satisfied with the Dorman universal kit.
    Rock auto has them for 33 each, Amazon has them for 45 a pop.
    another poster sent me the Toyota factory wiring diagram and test procedure.
    Will need an email because it’s a PDF
    speedtre and 912 like this.
  10. Feb 7, 2021 at 8:54 PM
    2005 DC 4x4
    Gotcha, ok. I've already got the heaters installed, I was referring to the wires coming out of the switch corresponding to which function ign/gnd/high/low, but it looks like i can figure it out from the info up above. I'll update this week as I get the time to get back at it. How are your seats coming? You're doing a leather upgrade, right?
  11. Feb 7, 2021 at 8:59 PM
    2005 DC 4x4
    Oh yeah, I missed the PDF of the seat switches above - I should be all good! Thank you @Festerw! I'll be using the factory switch for my passenger heat and using the katzkin 6 position momentary switch and ecu fo the driver's heat/ventilated seat.
  12. Feb 7, 2021 at 9:14 PM
    AV8R4AA
    Greg
    Justin Texas
    2005 Tundra XSP
    I remember blue ( pin 4) is the hot wire. Pins 1 and 2 are for backlighting. Thinking pin 6
    is ground. That leaves 3 and 5. They are low and high, not sure which is which though.
    912 likes this.
