Trying to understand what I can tow
Discussion in 'Towing & Hauling' started by sw157, Jun 12, 2023.
  1. Jun 12, 2023 at 7:25 AM
    sw157
    sw157 [OP] New Member
    I have a 2020 Tundra, payload on the sticker is 1235lbs.
    We are looking at getting a hybrid trailer, https://forestriverinc.com/rvs/travel-trailers/rockwood-roo/19/959.
    The dry weight of the trailer is 4298 lb
    The hitch weight of the trailer is 434lb
    The CCC is 1416 lb
    We will tow with the water tanks empty, but would have batteries, propane, 4 bikes and regular camping stuff. Our trips are only 2-5 nights so we don't need much stuff
    Would it be reasonable to assume we will load the trailer with about 600-700 lb?
    This would put us at 5000lb, the hitch weight at 12% would then be 600 lb.
    In my truck we have 600lb in passengers, I wouldn't carry anything in the bed.
    I don't know if my numbers are right, I would be completing off on how I understand the weight in the trailer transferring to the trailer hitch. I'm just guessing on the bit I've been reading but need some advice from someone who actually understands this
  2. Jun 12, 2023 at 7:30 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I suspect in calculating your hitch weight, you might be missing propane, batteries, spare tire or anything else on the hitch or near the front of the trailer.
    Mattedfred likes this.
  3. Jun 12, 2023 at 8:09 AM
    CTundraForMe
    CTundraForMe New Member
    Tundras can tow an immense amount, if you can avoid any tongue weight.
    And therein lies the problem.
    FlyingWolfe and Mattedfred like this.
  4. Jun 12, 2023 at 8:11 AM
    Your 4300# camper will tow just fine. Hell, you could even fill the water tanks. A WDH will even put some of that weight back on the trailer axle to help you out.
  5. Jun 12, 2023 at 8:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    You are fine....with a WDH i doubt you would have much/any squat in the back.
    Throw it in S5 with Tow Haul on and go for it!
    I tow a 6k lb trailer (dry), thats the most i want to tow.
  6. Jun 12, 2023 at 8:50 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 TRD Off-Road Inferno
    I tow our 6500# camper with a wdh and 8k# tractor and trailer with no issues. Just make sure the tongue isnt overweighted like mentioned and let er rip, tater chip!
    Terndrerrr likes this.
  7. Jun 18, 2023 at 5:06 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Agreed. I have a similar weight travel trailer, with WDH, and drag it all over the place. Also have a tractor on 20’ flatbed that weighs about the same. I’m careful with loading for weight distribution, but it travels really well.
  8. Jun 18, 2023 at 5:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I would definitely look at a tent bed trailer if i were doing it again. I like those. From the specs it looks like a single axle? I have a 16 ft single axle. I would not buy a single axle trailer again if i were restarting. It is so easy to go over max weight. My kids and wife were able to pack enough crap and clothes to blow right past the gawr. Single axles also ride way worse than a heavier dual axle im used to
