Trying to decide on a tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffro1225, May 2, 2015.
  1. May 2, 2015 at 10:00 AM
    jeffro1225
    jeffro1225 [OP] New Member
    Jeff
    Littleton, Colorado
    2015 Tundra Crewmax SR5 TRD OFF ROAD 4X4
    flow master outlaw exhaust, TRD cold air intake, linex bed, nfab bars, husky floor liners, esp rear seat storage unit,
    I'm trying to decide on a tonneau cover for my 2015 crew max tundra. Mainly looking for something pretty sturdy and waterproof Just curious if anyone has any recommendations out there and pictures.
    JROCK915 likes this.
  2. May 3, 2015 at 4:17 AM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
  3. May 3, 2015 at 4:26 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have BAKFlip F1 and love it. But it's not water-proof. I could make it tighter, but I haven't needed it to be water-proof for my application.
    I would think fiber glass tonneau cover that sits on top of the side will come close to water proof.
  4. May 3, 2015 at 3:17 PM
    BPRescue
    BPRescue New Member
    2015 Tundra TRD Pro
    I had the A.R.E LSII on my old gen 2 and loved it. Perfect paint match, waterproof, kept almost all the dust out and when matched with the bedrug, was perfect for camping, boating, extended trips, etc. I had the keyless entry which works off of the Toyota remote. It was awesome as I never had to worry about it being locked, since it locked with the remote and did not have to lock the tailgate either. I also installed a light that was tapped into the bed light, so operates when doors open or via Toyota's switch. Fit, finish and function were awesome.
    The above said, I ordered an identical setup for my gen3 and not sure if my expectation is too high, but it does not appear to be installed over the rails like my gen2 and noticed some flaws. You can see them in my post below. It still is a nice tonneau, and I purchased the bedrug, keyless entry and once again added a light. My main disappointment is that it does not secure the tailgate, so during those moments I am at the lake, camping, roadtrip, etc. I have to remember to lock the tailgate. Likely small, but not what I am used to... Before these issues, I would have recommended it without hesitation, but with this unit, it does appear quality is slipping from the last one I owned. I do like the locking mechanism better, and do feel the piano hinge is stronger and better for rain runoff when opening it than the other models, but you can see flaws in the paint.
    https://www.tundras.com/threads/a-r-e-lsii-tonneau-on-gen3-installed-have-questions.1597/
  5. May 3, 2015 at 4:03 PM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    They wont call it water proof cuz the bottom of the bed has holes where water can get in. However it will keep it dry enough depends on your application. I have the solid fold its been great so far. Only real pain is the winter when the cover freezes to the tailgate and bed than you cant open it.
  6. May 3, 2015 at 4:17 PM
    pmedic048
    pmedic048 Pull away from the herd, drive a Tundra!
    SC
    2008 SR5 Dbl Cad, 2015 SR5 CrewMax 4x4 and 2016 TRD Limited 4x4
    3" front spacer lift and 2" rear spring lift. 20" Fuel rims with BF Goodrich G2 33.5s and Volant cold air intake.
    I have used this company for the last 10yrs, they are made very well and warranty for 5yrs.
    http://www.truxedo.com/
  7. May 3, 2015 at 4:32 PM
    BPRescue
    BPRescue New Member
    2015 Tundra TRD Pro
    Yes, just like dust, the tailgate allows it in, so I also purchased a dust baffle and have very little dust only barely noticeable on those 40 mile dirt roads... I have never noticed water in the bed from above, let alone the bed, though I have a bedrug so imagine there could be spots below I never noticed. It certainly did not come in from the tonneau and when the top is wet and or raining, it rolls over the hinge area where some of the covers lift up and away, so it can get in the bed. I know some will question rain in AZ, but monsoons last a few months, and we do get bad storms at any time. So, this thing is perfect for camping or boating in that it keeps all the elements out. The only issue in the winter would come from the lack of climate control; meaning don't put your ski boots back there unless you want to be cold for a long time...
    It does have a lifetime warranty as well.
    http://www.4are.com/product/lsii/
  8. May 4, 2015 at 10:37 AM
    Mudman
    Mudman New Member
    2015 tundra lmtd
    I have a bakflip g2. It leaks a bit. Otherwise works well.
  9. May 4, 2015 at 5:46 PM
    Mike Tread lightly.
    south carolina
    I have a are on mine. Doesnt leak or anything. I have a bedrug so I have not noticed any dust or anything getting back into the bed section always clean and dry. Are products are very solid to the leer. My leer(tacoma) leaked took awhile to get it sealed all the way.
  10. May 4, 2015 at 6:15 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I had a bakflip HD on my 2013 Taco, was excellent, water proof ,well made and strong enough for me and the wife to lay on. ;)
    Waiting for bakflip to start shipping the Revolver X2 . That will be what goes on the Tundra.
  11. May 11, 2015 at 5:02 PM
    Mirage
    Mirage New Member
    NYC
    2014 SR5 Double Cab TRD Black
    BakFlip VP. I've had it a year, no leaks, secure and you can stand on it.
  12. May 11, 2015 at 5:20 PM
    Tufftruck
    Tufftruck New Member
    2015 Bronze 1794
    I searched for several weeks prior to purchasing my truck. I wanted a retractable/folding cover that not only looked good, but was tough. Almost pulled the trigger on a power retractable, but just couldn't justify it and all of them I looked at rattled. Looked at the BakFlip VP, but then watched the video of a guy breaking into it with a coat hanger. Nope, needed more security for the golf clubs. Then I found and ultimately purchased the Fold-a-Cover G4. So easy to install.....even a caveman.....! Lots of videos about the product. Good sale price on them right now.
  13. May 12, 2015 at 2:06 PM
    CincyCrewMax
    CincyCrewMax New Member
    Cincinnati, OH
    2014 White CrewMax LTD.
    Extang Solid Fold 2.0 Received yesterday and really like it! I can get you more pictures if you would like. Just let me know!
  14. May 12, 2015 at 7:40 PM
    NewGuy19
    NewGuy19 New Member
    2014 Black SR 3" lift
    3" leveling kit (front), Added rear leaf, Flares, K&N filter, Tonneau, Tint
    I have a Truxedo 'roll-up/velcro' on my 2014. I never thought I would own a cover, but absolutely LOVE it!!! It keeps things dry, my bed doesn't fill up with snow, and I can just roll it up to haul my bike/ 4-wheeler/etc.
  15. May 12, 2015 at 10:15 PM
    JROCK915
    JROCK915 Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Just got the Bakflip Fibermax! LOVE IT!
  16. May 13, 2015 at 7:03 PM
    msg148
    msg148 Hulk Smash
    Philadelphia
    15 Tundra Platinum Package
    7" BDS coilover lift kit w/Fox front and rear suspension, 20" Monster 2 Rims, 37" Deegan Tires, TRD Exhuast, TRD Intake, Bushwacker Pocket Flares, Blacked out Mirrors/Door handles, LED interior lights, Stubby Antenna, Bakflip F1 Tonneau Cover, 20% Tint Front windows
    I ordered the Backflip F1. Should be here by early next week. I had the same setup on my previous truck and loved it
  17. May 18, 2015 at 8:06 PM
    LM_Tundra
    LM_Tundra New Member
    Richard
    Southern California
    Tundra 1794
    I put an UNDERCOVER FLEX on mine and so far I love it. It keeps things out of sight. It's a three-plank cover. It's very low profile. If you're not in an SUV or another truck, you don't know it's there. I do have to say this: you lose your cargo management rails if you have them. The fasteners attach directly on them.
    Ianspei likes this.
  18. May 26, 2015 at 10:51 AM
    msg148
    msg148 Hulk Smash
    Philadelphia
    I got the Bakflip F1 last week and it is awesome!! The cover comes with a spacer to lower cargo rails, so you do not lose them. Super low profile and very sharp looking. I can post pics if you would like.
    LM_Tundra likes this.
  19. May 26, 2015 at 6:40 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Loving all the feedback in here...
  20. May 26, 2015 at 8:12 PM
    I've only had my Extang Revolution for a couple of days now and it seems to be fairly water resistant. It just rained real hard a few minutes ago and was dry inside. I think it has a life time warranty but don't know if it transferable. Definitely better than my Velcro roll up I had on my Tacoma. Forgot the brand. The Extang is tight,flat as a pancake for a roll up.
  21. May 28, 2015 at 8:14 AM
    TopJimmy5150
    TopJimmy5150 New Member
    Jay
    Red 2015 SR5 Crewmax
    LineX Bedliner, Bak-Flip FiberMax, Dancing Hula-Girl on dash.
    Bakflip Fibermax here. Love it except that you have to close it after you close the tailgate.
  22. May 28, 2015 at 9:45 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    I have the Extang Solid Fold like CincyCrewMax and I really like it. It is very solid and keeps the bed very dry. I don't have any pictures of my own, but thanks to CincyCrewMax, you can see what it looks like. I liked that I could still use my bed rail and clips. The top comes with special clips to attach the top to the rail with. Simple pull to release on each side of the back to flip it up. Tri fold gives you almost full access to the bed, and with two more quick disconnects you can take the whole top off. I can handle it by myself (almost retirement age), but it is easier with two people as with sturdiness you also have a couple extra pounds. I am a little leary of the wear and tear on the rubber seal at the tail gate, as it flips back and forth when you use the tail gate, but if it does wear (no signs of it yet after a couple months), it is simple to replace.
  23. May 28, 2015 at 1:07 PM
    msg148
    msg148 Hulk Smash
    Philadelphia
    From the 2 pics you can really see how low profile the cover is.
    LM_Tundra and JROCK915 like this.
  24. May 31, 2015 at 9:17 PM
    2015TRSPROSD
    2015TRSPROSD 2015 Tundra TRD PRO
    2015 TRD PRO CREWMAX
    XPEL protective Film (XPEL.com) Whole vehicle Tundra stamped letter insert (black) TRD PRO bed stamp letter insert Punisher Hood Decal (Matte Black) Fender and side cladding (TrdSparks) Side steps (Iron Cross- Linex coating) Retrax Pro Bed tonneau cover (Black) Punisher skull hitch cover (color matched custom paint) Michelin Defender LTX MS 295/70/18 Toyota Tundra 14-15 LED Taillights - Dark Red Smoked Lens Opt7 Headlights (bright as the sun pure white light) Tundra center console decider TRD Cold Air Intake Stubby antenna Weather Tech all weather mats TRD Brake pads Titanium exhaust wrap (covers exhaust pipes) Painted Engine Cover (Color Matched) Optima battery Billet Aluminum Optima Battery cover (Skull design-Optimatrays.com) TRD Sway Bar Kit Headlight Revolution (Gen 2 fog lights) Headlight Revolution Stealth light bar Color stable window tint Door sill protective trim Drivers side Grip Assist Hamdle add on LED bulbs inside & outside placements Focal front speakers and tweeters Kicker rear speakers JL stealth box subwoofers Kicker 4 channel amp Kicker mono amp Rebadged Whole
    Can open with one finger slides on huge ball bearings weather tight locks in any position and holds 500 pounds of snow or weight in center. Slick and looks great.
    sqa4life likes this.
  25. May 31, 2015 at 9:59 PM
    Ianspei
    Ianspei New Member
    Ian
    Huntsville, Ontario Canada
    2013 White Platinum Crewmax Tundra
    Levelling kit front and rear, TRD exhaust, BMF 20" wheels with 305/55R20" tires.
    I have the Undercover FLEX. I love it.
  26. Jun 2, 2015 at 7:05 PM
    jeffro1225
    Jeff
    Littleton, Colorado
    I like the extang solid fold 2.0 and undercover flex, for you guys with these tonneau covers how weatherproof are they notice any leaks at all with either one.
  27. Jun 3, 2015 at 4:06 AM
    Ianspei
    Ianspei New Member
    Ian
    I haven't noticed any. The flex comes with drains. So if it gets water in the rails it drains out the the front of it.
  28. Jun 3, 2015 at 4:15 AM
    CincyCrewMax
    Cincinnati, OH
    I have had no issues whatsoever with the Extang 2.0. We have had a few really good rains and a trip or two through the car wash and no leaks at all. Best tonneau that I have owned.
  29. Jun 3, 2015 at 6:06 AM
    rr3311
    rr3311 Tundra Magic
    Ohio
    I am quite satisfied with my Extang Solid fold, but if I could have afforded it, I really like that ReTrax Pro like 2015TRSPROSD posted. The only water I have found with the Extang is at the tailgate, but I think it is just where water flips in when I open the wet tailgate. Otherwise the entire bed stays very dry in the hardest of rains.
  30. Jun 11, 2015 at 6:22 PM
    LM_Tundra
    Richard
    Southern California
    Tundra 1794
    I don't mind that a lot. I like my cover. It keeps things out of sight
