Trying to add my oem style buttons need help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bullshawrk, Nov 15, 2024.
  1. Nov 15, 2024 at 8:30 PM
    Bullshawrk
    Bullshawrk [OP] New Member
    2015 limited tundra here
    Trying to figure out if the newer gen have more oem style buttons or an aftermarket one i can add.
    Should I just make a hole to fit a button
    I know I can add 3 more here by the looks of it
  2. Nov 16, 2024 at 4:06 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Are you referring to this panel? It’s from a 2020.
  3. Nov 16, 2024 at 5:54 AM
    Damn you have a mess going on there lol. As mentioned, the 2020 panel has more blank slots.
    https://www.sparksparts.com/oem-par...0dW5kcmEmeT0yMDIwJnQ9c3I1JmU9NS03bC12OC1nYXM=
    1lowlife likes this.
  4. Nov 16, 2024 at 7:25 AM
    Bullshawrk
    Lol ya it's a mess I'm about to clean it this weekend but install back tail gate automatic lock on today too.
    So can anyone confirm this will fit in my 2015 I guess I'll order and try hopefully everything can swap over !
  5. Nov 16, 2024 at 7:55 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It will fit.
  6. Nov 16, 2024 at 9:04 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    Anybody have the part number for the blank switch cover/cap? Or an Amazon link to the correct size that will fit?
  7. Nov 16, 2024 at 9:28 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  8. Nov 16, 2024 at 9:43 AM
    TacomaTRD4x402
    Southern California
    1lowlife[QUOTED] likes this.
  9. Nov 16, 2024 at 11:00 AM
    Bullshawrk
    Okay perfect I will order this part I think. Looks like I should rearrange maybe the traction control to there maybe?
    Do you know if I need to splice cables?
  10. Nov 16, 2024 at 11:32 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    The VSC button?
    On my 2014 yes you would have to extend the wiring quite a bit to get it to the center..
  11. Nov 16, 2024 at 12:24 PM
    Bullshawrk
    20241115_080951.jpgoh yes and maybe tow haul? I don't really use those buttons and would rather add something closer for new buttons maybe?
  12. Nov 16, 2024 at 3:36 PM
    Look for extension harnesses. I wouldn't do any cutting and splicing.
  13. Nov 16, 2024 at 6:03 PM
    Bullshawrk
    do you have any recomendations on where to look for extension harness?
  14. Nov 16, 2024 at 6:11 PM
    I believe @RainMan_PNW has a link for factory connectors so that you don't have to cut wires.
  15. Nov 16, 2024 at 6:18 PM
    Bullshawrk
    ok thanks i wonder if it can apply to most of those buttons for extensions
  16. Nov 17, 2024 at 4:33 AM
    bfunke
    South Carolina
    You may also have to swap out connectors if switching to USB-C outlets
