Trucks become bouncy....
Discussion in 'Suspension' started by HBdirtbag, Feb 22, 2020.
  1. Feb 22, 2020 at 12:43 PM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    Last few weeks I’ve noticed the front become stiffer and absorbs less. Last night after not driving it for a week it was unbearable.
    Took a look and no signs of leaking from the coilovers shock and springs show no damage. Anyone else experienced this? Wondering some options for when I can start digging in. Thinking:
    - bad coil spring (unlikely but possible
    - shocks lost nitrogen/oil somehow (but I think this would make it softer, no?)
    - steering rack issue (all looks fine)
    Truck has toytec/radflo coilovers up front with about 20k miles on them. Problem is def coming from front.
  2. Feb 22, 2020 at 12:50 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Holy bad threat title
    Darkness likes this.
  3. Feb 22, 2020 at 12:51 PM
    The coilovers most likely need to be rebuilt.
    You're going to have to inspect, see if there are signs of legit leaking, etc and go from there.
    Toytec can rebuild them
    HBdirtbag[OP] likes this.
  4. Feb 22, 2020 at 12:51 PM
    timsp8
    NY
    Flat spot on the tires from not driving it for a week?
  5. Feb 22, 2020 at 12:55 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Yea, I figure that’s gonna be the plan this week is to remove and heavy inspect with a rebuild in my future.
  6. Feb 22, 2020 at 12:57 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Def not a flat spot. My truck which is ironically my daily...gets driven the least. Never had flat spotting issues and a flat spot will generally round itself out after a few miles (plus, issue is over bumps)
  7. Apr 24, 2020 at 6:56 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    So, shocks were shot, most gaskets were completely blown out. ALso swapped from 700lb springs to 600lb springs. drove about 100 miles yesterday on pavement, so much better :)
    BTBAKER, TXTundra2722 and Boerseun like this.
  8. Apr 24, 2020 at 11:16 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    Wow, so after 20k miles the Radflo Coilovers were shot?
  9. Apr 27, 2020 at 8:51 AM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    yep, but i'll also admit, trucks gotten airborne a few times
