Truck won’t start help *fixed*
Discussion in '2.5 Gen Tundras (2014-2021)' started by unclebeejo808, Dec 7, 2021.
  1. Dec 7, 2021 at 6:46 PM
    unclebeejo808
    unclebeejo808 [OP] New Member
    Oahu
    I have a 2016. The past few days stormed where I live, drove through some pretty deep puddles. Truck ran fine yesterday, today it started dying if I didn’t keep the rpm’s up. Got it home and let it sit for a while. Started it up and it ran fine for a good 10 mins. Went back out to start it up just now and it starts and immediately dies. Try start it up again and nothing, 4lo and 4hi are flashing and there’s the transmission high temp warning. Unplugged the battery and it did the same thing. No codes being thrown. Tried searching and couldn’t find anything. Any suggestions would be appreciated.
    edit- transmission high temp isn’t showing anymore, traction is lit up now.
  2. Dec 7, 2021 at 7:04 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    How deep is deep? I avoid deep water because the alternator is down low in the engine compartment.
  3. Dec 7, 2021 at 7:06 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Did you get water in the air filter?
  4. Dec 7, 2021 at 7:06 PM
    unclebeejo808
    Oahu
    Maybe a foot deep. Water was splashing and flying everywhere though.
  5. Dec 7, 2021 at 7:07 PM
    unclebeejo808
    Oahu
    No. Checked that and it’s all dry
  6. Dec 7, 2021 at 7:13 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Get battery checked, recharged or swap it for a new one... low and dying batteries do wonky things...
    frichco228 likes this.
  7. Dec 7, 2021 at 7:15 PM
    unclebeejo808
    Oahu
    Thanks! Will try that tomorrow.
  8. Dec 7, 2021 at 10:17 PM
    2mchfun
    You might try jumper battery to confirm before you buy a battery.
    unclebeejo808[OP] likes this.
  9. Dec 8, 2021 at 2:54 AM
    Adam New Member
    And don't forget to swap your rear diff oil. Unless you have already done the rear diff breather mod you probably sucked some water in there.
    2mchfun and unclebeejo808[OP] like this.
  10. Dec 8, 2021 at 3:02 AM
    timsp8
    NY
    Did you check for a hidden CEL? I think some readers can find one even if the light isn’t on.
    I’d guess water got in the AIP.
    Adam and unclebeejo808[OP] like this.
  11. Dec 8, 2021 at 3:32 AM
    blanchard7684
    blanchard7684 New Member
    Given the background I'd suggest looking deeper into the battery.
    After that it is likely water in a connector. I'd start with the speed sensors.
  12. Dec 8, 2021 at 4:15 AM
    unclebeejo808
    Oahu
    How do I check for a hidden cel?
    seen that graph, none match up to what I’m reading on my dash. I’m stumped. Gonna try put a jumper on the battery when I get home.
  13. Dec 8, 2021 at 5:02 AM
    timsp8
    NY
    Some code readers can do it. I think if you go to an auto parts store, they will check for free, but the truck has to start first to get there. Maybe see if an auto parts store that does loaner tools has one.
  14. Dec 8, 2021 at 6:50 AM
    unclebeejo808
    Oahu
    I tried 2 obd scanners and both had no codes.
  15. Dec 8, 2021 at 9:24 AM
    unclebeejo808
    Oahu
    Now both obd scanners won’t read. :confused:
    hooked up a battery jumper and no change
  16. Dec 9, 2021 at 2:44 PM
    Adam New Member
    Damn dude, this sucks. How fast were you going when you hit the water?
  17. Dec 9, 2021 at 10:04 PM
    Tundraction
    Tundraction New Member
    Duane
    Minnesota
    2014 SR5 DBL MGM 4x4 5.7
    Phone Charger
    So your saying that the scan tools say "no communication with the vehicle" ?
    If so you need to figure out why. Get ahold of shop manual for your year truck and go through the flow chart diagnosis. You gonna need a dvom
  18. Dec 9, 2021 at 11:46 PM
    unclebeejo808
    Oahu
    20-25mph. My daughter likes flying through puddles, won’t be doing that again. Lol
  19. Dec 9, 2021 at 11:47 PM
    unclebeejo808
    Oahu
    Everything worked intermittently, scanner worked today. Still no codes
  20. Dec 10, 2021 at 8:46 AM
    unclebeejo808
    Oahu
    Problem solved. Looks like it was the hypertech power programmer. Not sure if it’s coincidence it happened after the storm or if it just crapped out. Removed it and all lights on dash are gone and runs like a champ.
  21. Dec 10, 2021 at 11:40 AM
    Tundraction
    Duane
    Minnesota
    Phone Charger
    Glad to hear it!
  22. Mar 15, 2022 at 8:13 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I was just given one by a guy who sold his truck. Was looking up reviews and found this thread.
    Seems it has two units that work together. One is mounted in the engine bay, the other is in the driver footwell area.
    From where it suggests I mount the engine bay unit it looks like it would get wet from driving through deep water at a fast rate.
    Besides this issue, how did it work for you? Worth the trouble to put on?
