Truck topper weight estimate?
Discussion in 'Tonneau Covers, Caps and Shells' started by The Juice, Feb 19, 2021.
  1. Feb 19, 2021 at 8:06 AM
    The Juice
    The Juice [OP] THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    I'm calculating how much weight is on my truck when it's loaded.
    --Does any one have an estimate of what a hard shell topper weighs for a crew cab tundra? I want to set my new leafs up correctly the first time!! Thanks!!
  2. Feb 19, 2021 at 8:10 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    My century mid rise is ~250lbs for 6.5feet. I would assume yours is 175-225lbs
    The Juice[OP] likes this.
  3. Feb 19, 2021 at 8:14 AM
  4. Feb 19, 2021 at 8:23 AM
    ezdog
    ezdog New Member
    Gateway To The West
    If you want to set it up right then get the truck weighed.
  5. Feb 19, 2021 at 8:29 AM
    The Juice
    COLORADO NATIVE
    THANK YOU! It turns out I bought a used ARE for 400$. I checked ARE's web site to find it is a V Series cap. Then, jumped to the link you provided and got the exact weight! You saved me SO MUCH time thank you!!!!! 175lbs is the weight!:rockband::headbang::cheers::cheers::cheers:
  6. Feb 19, 2021 at 8:33 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Manufacturers are notorious for underselling the weights they claim just so you know.
    But I imagine it is close,maybe.
  7. Feb 19, 2021 at 8:38 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    ^ this. And they don't include clamps or options added to the canopy.
  8. Feb 19, 2021 at 8:51 AM
    The Juice
    COLORADO NATIVE
    Thank you all!!! I really just need to get in the ball park as all my other numbers are accurate. Now, I'm just trying to figure out the max lift in the rear for The OME shocks I have in the back to make sure that I don't over extend them when the truck isn't running with my full load.:benchpress:
  9. Feb 19, 2021 at 9:03 AM
    :hattip:
