Truck steering issues
Discussion in '1st Gen Tundras (2000-2006)' started by 03tunradude, Aug 20, 2024.
  1. Aug 20, 2024 at 12:04 PM
    03tunradude
    03tunradude [OP] New Member
    2003 TUNDRA
    I could use y’all’s help if u have any ideas..
    I have an 03 tundra 4x4 v8…
    Things I have done
    OEM LBJ
    ALL NEW BRAKES all around CALIPERS/Rotors/Drums/Pads/wheel cylinders
    Tie rod ends
    New Tires
    Steering bushings
    New Power steering pump/lines/flush
    truck turns more to left than right. I can complete 2.5 rotations to the left with steering wheel, 1.75 to the right ..
    I have pulled steering rack and centered it but still continues to do the same thing.
    I’m having steering issues and brake issues still, they have been bled correctly.
    truck steering feels very loose
    “Spongey”, if I hit a bump the truck shoots to the left very aggressively , if I brake it pulls it back to the right.
    Also when I brake there is still shaking slightly at the end of brake.
    not sure what to do at this point. if u can help it would be greatly appreciated. Thanks in advance
  2. Aug 20, 2024 at 12:14 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Sounds like your tie rod ends are not installed properly.
    You didn't note brands for the parts or sizes for the tires. So it's hard to dissect.
    could be shit alignment? Could be shit parts? Bad install? Who knowssssss
  3. Aug 20, 2024 at 12:15 PM
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    Did you do an alignment after putting the rack back in?
    If the rack is centered, then I wonder if your toe adjustment / tie rods aren't adjusted properly. An alignment should fix that when the toe adjustment is done. If it's way out, then 1 wheel could be hitting the frame when turning to the right 1.75 rotations, but still allow 2.5 rotations when you turn left.
  4. Aug 20, 2024 at 12:37 PM
    03tunradude
    2003 TUNDRA
    Thanks for ur reply, yea I had an alignment right after replacing everything
  5. Aug 20, 2024 at 12:44 PM
    kentuckyMarksman
    Was the alignment before or after you pulled the rack back out and centered it?
  6. Aug 20, 2024 at 2:47 PM
    03tunradude
    2003 TUNDRA
    Alignment was done after everything was installed and rack and pinion centered . The tie rod ends are MOOG from Rock auto.
    kentuckyMarksman likes this.
  7. Aug 20, 2024 at 3:32 PM
    FishNinja
    Lee
    06DC2wd
    Are "steering bushings" steering rack bushing?
    Tunrod and Weagle like this.
  8. Aug 20, 2024 at 3:54 PM
    03tunradude
    2003 TUNDRA
    Yes.steering rack bushings.
  9. Aug 20, 2024 at 5:33 PM
    shifty` Animals and insects don't do drugs
    Ok, I'll ask. Take a ruler. Measure the exposed threads on your tie rod ends. Same/same? Or is one spun out farther?
  10. Aug 20, 2024 at 6:03 PM
    FishNinja
    Lee
    06DC2wd
    I was gonna ask but he said he got an alignment afterward. Sooo I figured those guys could catch that right?
    Weagle likes this.
  11. Aug 20, 2024 at 6:17 PM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    2.5 v 1.75?
    isn't that difference a full rotation on that steering rack? Seems like it is after rotating mine back and forth fully end to end to ensure mine was exactly centered. In my case, it was only then that I found the small little C on the steering rack to let me know when it was centered. I cant swear to it, but I'm thinking it was just over two full turns both ways lock to lock
    Sounds suspicious
    As shifty said, get a ruler and measure and/or count threads on the tie rod ends
    Hearing first hand heard how some shops do the alignment and having replaced my steering rack and the TRE's myself I can see a scenario where this could happen, depending on the knowledge of the mechanic and quality of the alignment
    shifty` likes this.
  12. Aug 20, 2024 at 6:24 PM
    Depends whether he went to a chain store where they just toe & go but DGAF about whether things are even or not.
    Better to confirm, honestly. Only takes a minute. If he was 3 threads off in either direction, it wouldn't be blatantly obvious visually, but the end result would be extremely close to what he's explaining with 1.75 and 2.5 rotations lock to lock L/R. Or at least *I* think it would be close, mental-math-wise.
    Weagle likes this.
  13. Aug 20, 2024 at 6:26 PM
    Weagle
    Prattville, AL
    By the way, if that is the case, I would be very wary of the potential to break the clock spring when this is corrected
    shifty` likes this.
  14. Aug 20, 2024 at 6:28 PM
    Suddenly "ah fuck my horn don't work, and I've got an airbag light, wtf?!" :rofl:
    Weagle[QUOTED] likes this.
  15. Aug 21, 2024 at 3:58 PM
    Weagle
    Prattville, AL
    Any luck with this? I'm very curious since I just recently replaced the steering rack and TRE's and had to work through the process of making sure all was aligned equally
    I would be very surprised if the TRE's have anywhere near the same number of threads showing
    it should be a very quick visual check from underneath
  16. Aug 23, 2024 at 3:07 PM
    03tunradude
    2003 TUNDRA
    Passenger side has waaaaaay more thread than than the driver side. It’s threaded just about as far out as you can go
    kentuckyMarksman and Weagle like this.
  17. Aug 23, 2024 at 3:10 PM
    kentuckyMarksman
    Yep, whoever did your alignment did a crap job on the toe adjustment. Have them fix it.
    Weagle likes this.
  18. Aug 23, 2024 at 3:10 PM
    Weagle
    Prattville, AL
    That's what I was waiting for. Alignment shop owes you a free alignment
    someone else might could tell you if that's a concern with the clock spring. I don't know how you would tell when it is in the middle. Could possibly require disconnecting the steering from the steering rack.
    if that's not an issue I believe that alignment shop should simply get the wheels turned with the steering wheel One full turn Different (in the direction where you don't get a full turn) from now and then get the tie rod ends even. Should most likely be the same number of threads on each side.
    i'm sure someone else can give you A more eloquent explanation and more specific details
  19. Aug 23, 2024 at 3:38 PM
    03tunradude
    2003 TUNDRA
    I definitely will get it checked out, but the main thing is it drives straight but when I hit a bump it shoots left VERY aggressively, then if I press the brakes it brings it back to the right and my steering wheel is turned 1/4 to the right as it drives straight it makes no sense
    Weagle likes this.
  20. Aug 23, 2024 at 3:39 PM
    03tunradude
    2003 TUNDRA
    The whole steering feels wierd like loose af
    Weagle likes this.
  21. Aug 23, 2024 at 3:50 PM
    Weagle
    Prattville, AL
    One of your settings on alignment is off. Make them give you an alignment sheet. You wouldn't believe What I have seen. But let's just say mine was doing the same thing and it was corrected once they did the alignment properly
    I believe mine was the camber that made it pull hard in One Direction if you had a bump. And yes, I seen her call the brakes doing something in the other direction.
  22. Aug 23, 2024 at 4:07 PM
    Weagle
    Prattville, AL
    The bad alignment could at a minimum be contributing to that
    when mine was off, especially the caster, it felt so unstable I didn't want to drive it
  23. Aug 23, 2024 at 4:23 PM
    As expected!
    The only thing you can really do in this case would be to measure or count the exposed threads on one side, then the other, add them up and divide by 2, and get both sides dialed to that amount. That should, in theory, get you in the ballpark. Then you may need a fine tune.
    The factory service manual, which is readily available for download online, shows how to recenter if needed.
    Weagle likes this.
  24. Aug 23, 2024 at 6:33 PM
    03tunradude
    2003 TUNDRA
    I’ll try to tackle this weekend, I appreciate you all!!!
    Weagle and shifty` like this.
