Truck shakes while braking
Discussion in '2nd Gen Tundras (2007-2013)' started by V10Ace, Mar 5, 2019.
  1. Mar 5, 2019 at 8:25 PM
    V10Ace
    V10Ace [OP] New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Hello all,
    My truck intermittently shakes while braking. The steering wheel doesn't shake, the whole truck does. I don't feel anything in the steering wheel or the pedal. Could I potentially have air in the brake lines? It's more of a front to back shake like I lose braking power for a split second over and over again. I have Powerstop drilled/slotted rotors front and back with hawk pads. It was installed roughly 3000 miles ago and I seem to remember it did it slightly then and now it just seems to be getting worse. I also have 1.25" Bora spacers that were installed after the brakes and was told by the guys who installed them that I shouldn't need them re torqued after x amount of miles.
    Thanks for any input
  2. Mar 5, 2019 at 11:19 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sounds like warped rotors. Any pulsing through the pedal?
    Joe Dirt, chugs and easleycrawler like this.
  3. Mar 5, 2019 at 11:39 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    My guess would be rotors as well.
    chugs likes this.
  4. Mar 6, 2019 at 4:15 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Your rear rotors are warped. Front rotors you feel in the steering wheel. Rear you feel through the truck/seats. Or a rear caliper is sticking. Either way, the vibration you’re feeling is stemming from the rear.
  5. Mar 6, 2019 at 5:04 AM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    No pulsing through pedal and no steering wheel shake
  6. Mar 6, 2019 at 5:06 AM
    V10Ace
    Salem, Oregon
    '21 TRD PRO
    Thanks for your input fellas. Going to have the rotors checked out today
  7. Mar 6, 2019 at 6:57 AM
    FXFormat
    FXFormat New Member
    Check for sticking caliper pistons, there's 4 on each side of the brake, if one or two is not doing its job it'll unevenly press against the rotor and could cause shaking. Check your ball joints, control arms, axles, warped rotors. It could be a lot of tracing to get to the source, good luck.
  8. Mar 6, 2019 at 7:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Did you bed them in properly?
